Z Plus Black Friday 2024 - Storage $2/TB/Month
For Black Friday 2024 Z Plus is offering storage for $2/TB/Month - Recurring.
Deal is limited to 100TB total! There ARE additional black friday offerings that will pop up in the mega thread later!
2TB Plan
* 2 vCore (Fair use, ~33%) (Xeon E5-2690 V4)
* 2GB RAM
* 20GB NVMe Boot Disk
* 1 IPv4
* 2TB Volume (3x7 Raid-Z2 Volume)
* $2 / TB / Month
* Shared networking, 100mbps limit.
* Use promocode "20OFFBLACKFRIDAY2024"
YABS
Yet-Another-Bench-Script
v2024-06-09
Fri Nov 29 04:15:56 UTC 2024
Uptime : 0 days, 0 hours, 7 minutes
Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
CPU cores : 2 @ 2599.980 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 19.3 GiB
Distro : Ubuntu 24.04.1 LTS
Kernel : 6.8.0-48-generic
VM Type : KVM
ISP : Z Plus LLC
ASN : AS399266 Z Plus LLC
Host : Z Plus LLC
Country : United States
Block Size | 4k (IOPS) | 64k (IOPS) |
Read | 318.63 MB/s (79.6k) | 2.99 GB/s (46.7k) |
Write | 319.47 MB/s (79.8k) | 3.00 GB/s (47.0k) |
Total | 638.11 MB/s (159.5k) | 6.00 GB/s (93.7k) |
Block Size | 512k (IOPS) | 1m (IOPS) |
Read | 5.52 GB/s (10.7k) | 1.89 GB/s (1.8k) |
Write | 5.81 GB/s (11.3k) | 2.02 GB/s (1.9k) |
Total | 11.33 GB/s (22.1k) | 3.91 GB/s (3.8k) |
Read | 315.41 MB/s (78.8k) | 680.43 MB/s (10.6k) |
Write | 316.25 MB/s (79.0k) | 684.01 MB/s (10.6k) |
Total | 631.67 MB/s (157.9k) | 1.36 GB/s (21.3k) |
Read | 2.98 GB/s (5.8k) | 1.18 GB/s (1.1k) |
Write | 3.14 GB/s (6.1k) | 1.26 GB/s (1.2k) |
Total | 6.13 GB/s (11.9k) | 2.45 GB/s (2.3k) |
Provider | Location (Link) | Send Speed | Recv Speed | Ping |
Clouvider | London, UK (10G) | 98.3 Mbits/sec | 101 Mbits/sec | 92.2 ms |
Eranium | Amsterdam, NL (100G) | 102 Mbits/sec | 100 Mbits/sec | 100 ms |
Uztelecom | Tashkent, UZ (10G) | 92.7 Mbits/sec | 96.5 Mbits/sec | 180 ms |
Leaseweb | Singapore, SG (10G) | 61.2 Mbits/sec | 87.7 Mbits/sec | 253 ms |
Clouvider | Los Angeles, CA, US (10G) | 99.5 Mbits/sec | 101 Mbits/sec | 88.3 ms |
Leaseweb | NYC, NY, US (10G) | 107 Mbits/sec | 103 Mbits/sec | 72.5 ms |
Edgoo | Sao Paulo, BR (1G) | 98.4 Mbits/sec | 97.0 Mbits/sec | 133 ms |
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 4146
Multi Core | 7861
Full Test | https://browser.geekbench.com/v4/cpu/18313267
Test | Value
Single Core | 1159
Multi Core | 2020
Full Test | https://browser.geekbench.com/v6/cpu/9130949
YABS completed in 14 min 40 sec
5,10 and 20TB plans are available as well also priced at $2/TB/Month Order Page
Status Fraud
Status Fraud
Retry, there was a country on the block list that has been removed. Every other country has to stay on that list due to sanctions.
Order #1614571800
Invoice #135
Already registered and paid, waiting for service activation
First month $3.5 * 0.8=$2.8, and $5 * 0.8=$4 recurring, is that right?
Order #1641963952
Invoice #134
Any other bonus?
I forgot to use the coupon "20OFFBLACKFRIDAY2024" when placing the order. Can you add it for me? My friend!
Hello,
I replied to your ticket about the coupon - the easiest solution is to credit your account the difference and for me to apply it so the next due has the recurring discount. The cost of me refunding and having you re-order is like 20% of the cost of the entire order due to fees.
Everyone else that had their payment status as "completed" has had their order activated. I'm a lone operation so support isn't S tier, unfortunately. I try my best though.
Happy storage everyone!
At first I was like:
But then:
☰ Probably the best Black Friday storage offers — AMD EPYC VDSes with NVMe slices (ref) from 250GB to 4TB and 500GB–10TB SAN disk. / Big HDD storage VPSes (ref) from $2.42/month per TB. / Storage dedis and hybrid VPS (SSD + HDD) are there as well.
so if I understand this correctly this offer is 2.8 usd/month for 2TB of storage , or do I need to attach storage as an addon to the vps ?
2TB plan -> $2 / TB / Month = $4 month
Okay I will bite where exactly is your cornfield?
Corn warriors will wield intel sticks to defend our solar panels
Michigan, routed through Frantech / BuyVM in NYC which is about 18-22ms. Sounds stupid, but it actually works out in my favor for hosting my own big data archives, so just using the same technique to host publicly now and passing the savings on.
Small update, I know it's a busy day.
A bit about the Garbage 2024 plan:
It was spawned by a yoursunny meme. It was going to be ipv6 only about $15 / year - then I bought one in my testing phase where I ensure smooth delivery and ran a YABS and the yabs was just so good I slapped each one an ipv4 and hence garbage was born. I'm limited in supply of ipv4 so while I do a lot of low end offers - I typically will not do anything under 2TB of storage or 2GB of ram, whichever is first.
And when I did the yabs, yeah it was great. It does come with the limitation that it's LXC containers, and the description is a machine generated mess, but accurate. It's part of the... artform.
The garbage machine is limited in RAM which means the total amount of slots offered here is also limited - I don't overprovision much. This also means that over half of the slots need to be coreblaster 9000's in order to actually make the other half sad, rather than just 3-4 bad apples on other systems.
I'm using Garbage 2024 as a testing system for things like automatic core limiting, network rate limiting, storage monitoring etc. Would be lovely to offer burstable network speeds on my bigger offerings without worrying about port blasters ruining the experience for everyone.
I also wanted to address a question I had someone ask in a voice call last night:
The hard caps on network speed on the storage offers is to prevent the ability of just a few people port blastering the rest of the infra. And ruining client experience in the process. It'd take a good number of people before it got sad at current settings.
Garbage yabs: 1600 single thread speed at burstable full core while host node runs stress on 5 threads.
v2024-06-09
Wed Nov 27 04:34:55 UTC 2024
Uptime : 0 days, 0 hours, 3 minutes
Processor : AMD Ryzen 5 5600U with Radeon Graphics
CPU cores : 1 @ 4241.836 MHz
AES-NI : ✔ Enabled
RAM : 2.0 GiB
Swap : 0.0 KiB
Disk : 29.4 GiB
Kernel : 6.8.12-4-pve
VM Type : LXC
ISP : Z Plus LLC
ASN : Unknown
Host : Z Plus LLC
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/pve-vm--10007--disk--0):
Test | Value
Single Core | 1694
Multi Core | 1698
Full Test | https://browser.geekbench.com/v6/cpu/9093640
YABS completed in 11 min 30 sec
Enjoy the sales guys, even if it ain't from me.
South Michigan could I throw a rock and hit a server? I am in North/Central.
No throwing rocks at my servers
I don't have enough bandwidth commit / business to justify the extra costs of BGP direct from my DC yet, but it's a planned thing. Would be quite nice.
Can I throw snowballs?
At me not the servers. Though I do have some old Xeon X5 servers laying around, we can build a fort with them. I've been using those old servers for hobby parts for a while now.
He talks about corn fields. Pretty sure he's confused and in Ohio. :P
Typical Buckeye can't tell his ass from his hands.
This yabs on NVME disk
And this YABS on addon disk 2 Tb
Thats great disk performance.
That cache really pulling it's weight. Sustained streaming writes to the disks should level off at around ~700-850MB/s aggregate per array, and there's a relatively limited amount of people on each array. The VMs are limited in overall bandwidth so streaming writes or reads should never be a limiter. Perhaps if i end up with another dedicated 10/10 line next summer I might start considering it as an issue.
I also extended the code's usage till Tues - had a couple requests and we hadn't sold out of the 100TB worth yet. Feel free.
Hello, is this a recurring discount or a one-time discount? I saw the recurring price on the order page is $25, and the current subtotal is $12.5
Coupon is expired. You're seeing a prorated price (from now until the 20th, which is 15 days, which is half a month, which is half the monthly price).
Well, what a pity. Recently I have only been following LET and not LES.
Use code "Imissedblackfriday" and enjoy. Should be active till end of week.
Ya'll are still hungry for this???
I kinda expected that people would be interested in the larger plans instead of a bunch of smaller ones, but the resource usage of the system looks to be in check so I added more available stock. Enjoy.
Uh ... It looks like your emails are being blocked by Crane Mail lol. Updated the filter to allow them 😅 @ZizzyDizzyMC
The duality of email. Sorry.
