File sharing through browser
Hello,
I wanted something I could install on VPS where
  • I would need to login to upload a file: nothing complicated, simple login then you can upload whatever; this needs to be accessible through a public URL
  • once the file is uploaded, it needs to be able to provide links that can be shared with others; for downloading, no login should be required. Anyone with the link should be able to download.
Please suggest a simple solution. I have tried NextCloud in the past but I frequently run into problems with it, so I would prefer a simpler solution.
