2 cores + 512 MB RAM + large HDD/SSD + good internet speed is all you need.
1 core is also enough, but 2 is better. Download speed does not really change if you have 2 or more cores so dont worry about that, but it will limit the number of active torrents. So if you download 5 torrents with 50 max peers, you will get better speeds with 4 or more cores, but this is again limited by your disk speed. If you are using SSD + 1 Gbps (or higher) internet speed, then 4 cores are better.
If you run other applications, increase RAM accordingly as torrent can easily eat up 512 MB of ram.
If it’s not broken, keep fixing it until it is. Blink twice if you agree.
few years ago i'm running transmission-web+syncthing in ramnode's 128mb vps, it can seed 30+ torrent just fine.
It was difficult since the vps is too small to run some sort of RSS downloader (like deluge-daemon+rss plugin or flexget+transmission-web) since it consume too much RAM.
In current year, qbitorrent-nox already have RSS integration (after like a decade waiting lol), so now I have setup qbitorrent-nox + syncthing in virmach's 384MB ram, run just fine with +20 active seeding. can't add more since the disk is limited
My seedbox is a very old Atom C2350 Dual Core with 4GB of RAM and it works fairly well. The HDD on it is the limiting factor, but if I had an SSD I could probably max out the 1Gbps link it has. Only time it really shows its weakness on the CPU side is when decompressing large archives, so I pull those down locally and decompress.
Depends on how heavy the torrent stack is. Optimized client with nothing else running will be fine as long as you don't throw a bunch of torrents at it.
Yes, unless you wish to transcode
Speed will be limited as you have only 2 Cores.
P.S Also keep in mind, that apps will be slower than you expect, especially if you have large media.
1000 kilowatts.
1.21 JiggaWattz
URL Shortener | YetiNode
How are you... online?
MAX
No metal for you.
It depends. Is turbo on or off?
How much is this cost?
$3.50 per month?
I have a small vps C2338 2*1.8GHz, GB5 score 298, running transmission, and no problem at all. Speedtest reaches up to 928M( 1G port).
@Astro does these comments answer your question?
