Comprehensive Speedtest Script | network-speed.xyz | Share your bench
edited September 2023 in Technical
Hi All,
I present to you yet another damn speed test script. I understand there are many speed test scripts out there, but ... well I did it anyway. I've been working on this for a couple of months now and feel it is ready for public use now.
I built this on top of Teddysuns bench.sh - adding my code and removing unnecessary stuff.
All information can be found on https://network-speed.xyz/
Big Thanks and shout out to Crunchbits LLC (@crunchbits) for sponsoring the Hosting Infrastructure.
Test Locations
* North America
* South America
* Europe
* Asia
* Africa
* Australia
* GCC Middle East
* India
* China
* Iran
* Indonesia
* More coming soon!
Usage
For Global Test
wget -qO- network-speed.xyz | bash
For Regional Test
curl -sL network-speed.xyz | bash -s -- -r region_name
region_name = na, sa, eu, asia, africa, au, middle-east, india, china, iran, indonesia
Global Test Sample Output
---------------------------- network-speed.xyz ----------------------------
      A simple script to test network performance using speedtest-cli
 Version            : v2023.09.04
 Global Speedtest   : wget -qO- network-speed.xyz | bash
 Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
 CPU Cores          : 2 @ 2593.992 MHz
 CPU Cache          : 35840 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ✔ Enabled
 Total Disk         : 30.0 GB (7.8 GB Used)
 Total RAM          : 2.8 GB (729.9 MB Used)
 System uptime      : 2 days, 23 hour 11 min
 Load average       : 0.39, 0.25, 0.24
 OS                 : Ubuntu 22.04.3 LTS
 Arch               : x86_64 (64 Bit)
 Kernel             : 5.15.0-83-generic
 Virtualization     : KVM
 Basic Network Info
 Primary Network    : IPv6
 ISP                : Redoubt Networks
 ASN                : AS400304 REDOUBT NETWORKS
 Host               : Redoubt Networks
 Location         Latency     Loss    DL Speed       UP Speed       Server
 ISP: Crunchbits, LLC
 Nearest          16.96 ms    N/A     941.95 Mbps    1015.10 Mbps   Pendleton Fiber - Pendleton, OR
 Kochi, IN        217.95 ms   0.0%    585.28 Mbps    373.14 Mbps    Asianet Broadband - Cochin
 Bangalore, IN    253.82 ms   0.0%    748.31 Mbps    372.69 Mbps    Bharti Airtel Ltd - Bangalore
 Chennai, IN      274.76 ms   N/A     809.48 Mbps    396.58 Mbps    Jio - Chennai
 Mumbai, IN       254.87 ms   0.0%    865.36 Mbps    322.25 Mbps    i3D.net - Mumbai
 Delhi, IN        274.26 ms   0.0%    581.84 Mbps    313.11 Mbps    Tata Teleservices Ltd - New Delhi
 Seattle, US      10.26 ms    0.0%    928.17 Mbps    1003.84 Mbps   Ziply Fiber - Seattle, WA
 Los Angeles, US  35.94 ms    0.0%    885.51 Mbps    1020.57 Mbps   ReliableSite Hosting - Los Angeles, CA
 Dallas, US       68.50 ms    0.0%    855.47 Mbps    1098.01 Mbps   Hivelocity - Dallas, TX
 Miami, US        89.48 ms    0.0%    812.07 Mbps    1078.39 Mbps   AT&T - Miami, FL
 New York, US     82.31 ms    0.0%    950.73 Mbps    1091.45 Mbps   GSL Networks - New York, NY
 Toronto, CA      76.81 ms    0.0%    888.84 Mbps    1102.13 Mbps   Rogers - Toronto, ON
 London, UK       133.49 ms   0.0%    974.81 Mbps    819.59 Mbps    VeloxServ Communications - London
 Amsterdam, NL    142.53 ms   0.0%    978.69 Mbps    793.53 Mbps    31173 Services AB - Amsterdam
 Paris, FR        163.76 ms   N/A     984.88 Mbps    468.80 Mbps    Axione - Paris
 Frankfurt, DE    147.25 ms   0.0%    925.05 Mbps    541.13 Mbps    23M GmbH - Frankfurt am Main
 Warsaw, PL       186.08 ms   0.0%    663.15 Mbps    480.32 Mbps    UPC Polska - Warszawa
 Bucharest, RO    174.88 ms   0.0%    737.35 Mbps    312.08 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
 Jeddah, SA       203.45 ms   0.0%    890.21 Mbps    517.63 Mbps    Saudi Telecom Company
 Dubai, AE        256.86 ms   0.0%    821.44 Mbps    462.51 Mbps    du - Dubai
 Fujairah, AE     253.46 ms   0.0%    935.59 Mbps    453.69 Mbps    ETISALAT-UAE - Fujairah
 Tokyo, JP        115.01 ms   N/A     856.33 Mbps    654.26 Mbps    fdcservers.net - Tokyo
 Shanghai, CU-CN  191.28 ms   0.0%    578.51 Mbps    603.30 Mbps    China Unicom 5G - Shanghai
 Nanjing, CT-CN   206.55 ms   0.0%    694.05 Mbps    9.81 Mbps      China Telecom JiangSu 5G - Nanjing
 Hong Kong, CN    156.69 ms   N/A     896.45 Mbps    584.13 Mbps    STC - Hong Kong
 Singapore, SG    168.47 ms   0.0%    873.03 Mbps    554.05 Mbps    i3D.net - Singapore
 Jakarta, ID      203.15 ms   0.0%    619.90 Mbps    271.19 Mbps    PT. Telekomunikasi Indonesia - Jakarta
 Avg DL Speed       : 825.27 Mbps
 Avg UL Speed       : 619.01 Mbps
 Total DL Data      : 32.31 GB
 Total UL Data      : 23.53 GB
 Total Data         : 55.84 GB
 Duration           : 14 min 6 sec
 System Time        : 12/09/2023 - 20:01:16 IST
 Total Script Runs  : 23054
Regional Test Sample Output
NA: https://result.network-speed.xyz/r/1694522045_QVORYM_NA.txt
 Basic System Info
 CPU Model          : AMD Ryzen 9 3900X 12-Core Processor
 CPU Cores          : 1 @ 3799.998 MHz
 CPU Cache          : 512 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 19.6 GB (2.7 GB Used)
 Total RAM          : 457.8 MB (73.2 MB Used)
 Total Swap         : 1024.0 MB (8.5 MB Used)
 System uptime      : 11 days, 19 hour 16 min
 Load average       : 0.00, 0.00, 0.00
 OS                 : Debian GNU/Linux 12
 Kernel             : 6.1.0-11-amd64
 Basic Network Info
 ISP                : IncogNET LLC
 ASN                : AS210630 IncogNET LLC
 Host               : Incognet LLC
 Location (IPv4)    : Liberty Lake, Washington, US
 Speedtest.net (Region: NORTH AMERICA)
 ISP: IncogNET LLC
 Nearest          10.27 ms    0.0%    4388.07 Mbps   2078.65 Mbps   Intechtel - Managed IT Services - Coeur d'Alene, ID
 Vancouver, BC    14.23 ms    N/A     4254.83 Mbps   1868.32 Mbps   TELUS - Vancouver, BC
 Calgary, AB      25.67 ms    N/A     4364.03 Mbps   951.55 Mbps    Shaw Communications - Calgary, AB
 Winnipeg, MB     53.87 ms    0.0%    4272.62 Mbps   450.01 Mbps    Voyageur Internet - Winnipeg, MB
 Toronto, ON      57.44 ms    0.0%    4182.94 Mbps   426.85 Mbps    Bell Canada - Toronto, ON
 Montreal, QC     89.83 ms    0.0%    4156.79 Mbps   418.51 Mbps    Rogers Wireless - Montréal, QC
 New York, NY     77.75 ms    0.0%    3224.79 Mbps   517.52 Mbps    Surfshark Ltd - New York, NY
 Ashburn, VA      69.73 ms    0.0%    4216.00 Mbps   460.40 Mbps    Rackdog - Ashburn, VA
 Charlotte, NC    78.39 ms    0.0%    4039.11 Mbps   506.61 Mbps    Windstream - Charlotte, NC
 Atlanta, GA      70.17 ms    0.0%    3591.94 Mbps   302.66 Mbps    i3D.net - Atlanta, GA
 Miami, FL        90.52 ms    0.0%    2582.08 Mbps   495.01 Mbps    AT&T - Miami, FL
 Dallas, TX       68.19 ms    0.0%    3145.09 Mbps   445.25 Mbps    Hivelocity - Dallas, TX
 Houston, TX      64.35 ms    0.0%    3661.62 Mbps   514.67 Mbps    Ezee Fiber - Houston, TX
 Kansas, MO       51.98 ms    0.0%    3731.05 Mbps   824.11 Mbps    Xiber LLC - Kansas City, MO
 Minneapolis, MN  42.24 ms    0.0%    4137.50 Mbps   611.64 Mbps    US Internet - Minneapolis, MN
 Chicago, IL      57.96 ms    0.0%    3385.17 Mbps   563.70 Mbps    Enzu.com - Chicago, IL
 Cleveland, OH    65.96 ms    0.0%    3628.61 Mbps   628.28 Mbps    Windstream - Cleveland, OH
 Albuquerque, NM  52.43 ms    N/A     4213.14 Mbps   647.14 Mbps    Comcast - Albuquerque, NM
 Denver, CO       37.62 ms    0.0%    4383.44 Mbps   524.57 Mbps    T-Mobile Fiber | Intrepid - Denver, CO
 Portland, OR     14.54 ms    N/A     4342.97 Mbps   1669.50 Mbps   CenturyLink - Portland, OR
 Las Vegas, NV    37.90 ms    N/A     3785.99 Mbps   997.47 Mbps    Dish Wireless - Las Vegas, NV
 Salt Lake, UT    52.41 ms    N/A     3613.92 Mbps   837.56 Mbps    Novva Data Centers - Salt Lake City, UT
 Phoenix, AZ      51.21 ms    0.0%    4432.55 Mbps   757.47 Mbps    Xiber LLC - Phoenix, AZ
 Los Angeles, CA  35.60 ms    0.0%    4147.31 Mbps   921.31 Mbps    ReliableSite Hosting - Los Angeles, CA
 Santa Clara, CA  31.68 ms    0.0%    2812.62 Mbps   926.44 Mbps    AT&T - Santa Clara, CA
 San Jose, CA     30.04 ms    0.0%    3712.56 Mbps   1099.06 Mbps   Misaka Network, Inc. - San Jose, CA
 Seattle, WA      11.32 ms    0.0%    4219.65 Mbps   2260.36 Mbps   Misaka Network, Inc. - Seattle, WA
 Hermosillo, MX   65.15 ms    0.0%    3763.50 Mbps   595.44 Mbps    Megacable - Hermosillo
 Guadalajara, MX  87.52 ms    0.0%    1875.36 Mbps   449.49 Mbps    AT&T México - Guadalajara
 Mexico City, MX  79.24 ms    N/A     3946.76 Mbps   489.20 Mbps    INFINITUM - Mexico City
 Merida, MX       FAILED
 Avg DL Speed       : 3807.07 Mbps
 Avg UL Speed       : 807.96 Mbps
 Total DL Data      : 161.70 GB
 Total UL Data      : 35.72 GB
 Total Data         : 197.42 GB
 Duration           : 13 min 59 sec
 System Time        : 12/09/2023 - 18:04:05 IST
 Total Script Runs  : 23044
SA: https://result.network-speed.xyz/r/1694528715_JFU3T1_SA.txt
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
 CPU Cores          : 1 @ 2099.998 MHz
 CPU Cache          : 16384 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 7.2 GB (642.4 MB Used)
 Total RAM          : 244.1 MB (43.0 MB Used)
 System uptime      : 0 days, 15 hour 53 min
 Load average       : 0.14, 0.15, 0.10
 Virtualization     : LXC
 Basic Network Info
 ISP                : Zappie Host LLC
 ASN                : AS61138 Zappie Host LLC
 Host               : MicroLXC
 Speedtest.net (Region: SOUTH AMERICA)
 ISP: Zappie Host - Valdivia, Chile
 Nearest          74.64 ms    0.0%    4.91 Mbps      48.20 Mbps     Globalconnect SpA - Pucon
 Sao Paulo, BR    116.76 ms   0.0%    3.77 Mbps      45.46 Mbps     i3D.net - São Paulo
 Rio, BR          124.38 ms   0.0%    3.27 Mbps      49.00 Mbps     TIM Brasil - Rio de Janeiro
 Salvador, BR     262.67 ms   0.0%    4.92 Mbps      35.13 Mbps     Claro net vírtua - Salvador
 Buenos, AR       196.04 ms   0.0%    1.06 Mbps      46.95 Mbps     Claro - Buenos Aires
 Buenos, AR       89.43 ms    N/A     3.08 Mbps      48.60 Mbps     fdcservers.net - Buenos Aires
 Santiago, CL     70.83 ms    N/A     2.75 Mbps      50.09 Mbps     Claro Chile - Santiago
 Lima, PE         167.48 ms   0.0%    6.10 Mbps      41.54 Mbps     Claro Perú - Lima
 Quito, EC        181.04 ms   N/A     4.17 Mbps      50.65 Mbps     Movistar Ecuador - Quito
 Caracas, VE      208.42 ms   0.0%    2.11 Mbps      48.69 Mbps     WAVE.COM.VE - Caracas
 Bogota, CO       213.21 ms   0.0%    13.68 Mbps     47.18 Mbps     Claro Colombia - Bogotá
 Avg DL Speed       : 4.53 Mbps
 Avg UL Speed       : 46.50 Mbps
 Total DL Data      : 0.07 GB
 Total UL Data      : 0.66 GB
 Total Data         : 0.72 GB
 Duration           : 6 min 17 sec
 System Time        : 12/09/2023 - 14:25:13 UTC
 Total Script Runs  : 23053
EU: https://result.network-speed.xyz/r/1694529083_9KFDDK_EU.txt
 Basic System Info
 CPU Model          : Intel Core Processor (Broadwell, IBRS)
 CPU Cores          : 1 @ 2596.990 MHz
 AES-NI             : ✔ Enabled
 Total Disk         : 14.9 GB (2.8 GB Used)
 Total RAM          : 926.1 MB (308.6 MB Used)
 Total Swap         : 512.0 MB (1.1 MB Used)
 System uptime      : 15 days, 1 hour 7 min
 Load average       : 0.03, 0.01, 0.00
 Basic Network Info
 Primary Network    : IPv4
 ISP                : ColocationX Ltd.
 ASN                : AS208046 ColocationX Ltd.
 Host               : Alerdium LLC
 Speedtest.net (Region: EUROPE)
 ISP: ColocationX Ltd.
 Nearest          73.28 ms    0.0%    1644.95 Mbps   39.66 Mbps     Bakcell LTD - Baku
 London, UK       15.79 ms    0.0%    1931.65 Mbps   2924.81 Mbps   M247 Ltd - London
 Edinburgh, UK    27.08 ms    N/A     1472.68 Mbps   2686.71 Mbps   Vodafone UK - Edinburgh
 Dublin, IE       17.24 ms    0.0%    1888.37 Mbps   3055.84 Mbps   Three Ireland - Dublin
 Amsterdam, NL    3.84 ms     0.0%    1945.95 Mbps   3714.75 Mbps   GSL Networks - Amsterdam
 Dronten, NL      6.66 ms     0.0%    1985.75 Mbps   3897.00 Mbps   Serverius Connectivity - Amsterdam
 Paris, FR        15.08 ms    0.0%    2050.03 Mbps   3300.45 Mbps   ORANGE FRANCE - Paris
 Marseille, FR    23.75 ms    0.0%    1826.46 Mbps   2942.31 Mbps   GSL Networks - Marseille
 Madrid, ES       34.74 ms    0.0%    1895.49 Mbps   2574.43 Mbps   Orange - Jazztel - Madrid
 Barcelona, ES    30.87 ms    0.0%    2052.28 Mbps   1541.53 Mbps   Adamo - Barcelona
 Lisbon, PT       42.21 ms    0.0%    2009.91 Mbps   1894.51 Mbps   Edgoo Networks - Lisbon
 Rome, IT         30.46 ms    0.0%    2056.76 Mbps   2017.35 Mbps   TIM SpA - Rome
 Milan, IT        25.00 ms    0.0%    1940.20 Mbps   1986.02 Mbps   Vodafone IT - Milan
 Zurich, CH       20.26 ms    0.0%    2017.49 Mbps   2801.86 Mbps   Sunrise Communication AG - Zurich
 Frankfurt, DE    10.73 ms    0.0%    2126.02 Mbps   1660.52 Mbps   23M GmbH - Frankfurt am Main
 Berlin, DE       28.87 ms    0.0%    1839.04 Mbps   2826.73 Mbps   Misaka Network, Inc. - Berlin
 Vienna, AT       22.50 ms    0.0%    1820.73 Mbps   2607.84 Mbps   A1 Telekom Austria AG - Vienna
 Budapest, HU     23.51 ms    0.0%    1517.32 Mbps   3230.84 Mbps   ATW Internet Kft. - Budapest
 Gdansk, PL       29.24 ms    0.0%    1741.14 Mbps   2977.61 Mbps   T-Mobile Polska S.A. - Gdańsk
 Warsaw, PL       29.21 ms    0.0%    1713.35 Mbps   2730.05 Mbps   Orange Polska S.A. - Warsaw
 Lviv, UA         31.13 ms    0.0%    1980.51 Mbps   2113.50 Mbps   Kyivstar - Lviv
 Kyiv, UA         38.99 ms    0.0%    1998.03 Mbps   1155.71 Mbps   o3 - Kyiv
 Minsk, BY        32.83 ms    0.0%    1912.54 Mbps   1838.12 Mbps   A1 - Minsk
 Bucharest, RO    41.31 ms    0.0%    1956.94 Mbps   836.68 Mbps    Orange Romania Communications - Bucharest
 Iasi, RO         44.25 ms    0.0%    1903.17 Mbps   1545.38 Mbps   Digi
 Helsinki, FI     26.40 ms    0.0%    2041.33 Mbps   2465.11 Mbps   Elisa Oyj - Helsinki
 Stockholm, SE    24.10 ms    0.0%    2127.57 Mbps   3052.27 Mbps   i3D.net - Stockholm
 Oslo, NO         22.86 ms    0.0%    1922.89 Mbps   2091.63 Mbps   Speedtest.net - Oslo
 Moscow, RU       46.09 ms    0.0%    1897.71 Mbps   2170.97 Mbps   Rostelecom - Moscow
 Petersburg, RU   38.16 ms    0.0%    2005.69 Mbps   1745.40 Mbps   MTS OJSC - Saint Petersburg
 Istanbul, TR     51.45 ms    0.0%    2047.25 Mbps   1934.34 Mbps   Turkcell - Istanbul
 Tbilisi, GE      75.43 ms    N/A     1889.77 Mbps   1138.05 Mbps   Silknet JSC - Tbilisi
 Avg DL Speed       : 1911.22 Mbps
 Avg UL Speed       : 2296.81 Mbps
 Total DL Data      : 101.10 GB
 Total UL Data      : 100.78 GB
 Total Data         : 201.88 GB
 Duration           : 15 min 21 sec
 System Time        : 12/09/2023 - 20:01:51 IST
 Total Script Runs  : 23055
Asia: https://result.network-speed.xyz/r/1694528694_SIR554_ASIA.txt
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
 CPU Cores          : 4 @ 2199.986 MHz
 AES-NI             : ✔ Enabled
 Total Disk         : 55.1 GB (33.0 GB Used)
 Total RAM          : 7.8 GB (491.2 MB Used)
 Total Swap         : 4.0 GB (0 Used)
 System uptime      : 12 days, 7 hour 9 min
 Load average       : 0.03, 0.10, 0.13
 Kernel             : 5.15.0-82-generic
 Basic Network Info
 ISP                : Leaseweb Singapore
 ASN                : AS59253 Leaseweb Asia Pacific pte. ltd.
 Host               : Leaseweb Asia Pacific pte. ltd
 Speedtest.net (Region: ASIA)
 ISP: Leaseweb Asia
 Nearest          0.68 ms     0.0%    5810.81 Mbps   8619.99 Mbps   MyRepublic Singapore - Singapore
 Mumbai, IN       64.79 ms    0.0%    4330.23 Mbps   139.85 Mbps    i3D.net - Mumbai
 Chennai, IN      36.73 ms    N/A     4566.77 Mbps   2205.66 Mbps   Jio - Chennai
 Bangalore, IN    166.69 ms   0.0%    3705.27 Mbps   484.60 Mbps    Bharti Airtel Ltd - Bangalore
 Singapore, SG    0.83 ms     0.0%    5770.87 Mbps   8515.09 Mbps   MyRepublic Singapore - Singapore
 Singapore, SG    3.25 ms     N/A     7290.37 Mbps   1793.29 Mbps   StarHub Ltd - Singapore
 Tokyo, JP        75.96 ms    0.0%    5597.32 Mbps   1122.32 Mbps   Rakuten Mobile, Inc - Tokyo
 China Telecom    435.69 ms   11.9%   94.92 Mbps     0.66 Mbps      湖南电信5G - Changsha
 China Unicom     237.32 ms   N/A     2.87 Mbps      0.97 Mbps      湖南联通5G - Changsha
 China Mobile     FAILED
 Hong Kong, CN    36.47 ms    0.0%    3687.67 Mbps   2375.37 Mbps   i3D.net - Hong Kong
 Karachi, PK      76.91 ms    0.0%    2397.50 Mbps   503.05 Mbps    JAZZ - Karachi
 Islamabad, PK    105.24 ms   N/A     932.61 Mbps    253.79 Mbps    Telenor Pakistan - Islamabad
 Kathmandu, NP    210.52 ms   0.0%    928.88 Mbps    130.51 Mbps    Nepal Telecom - Hetauda
 Colombo, SL      49.18 ms    N/A     2843.06 Mbps   1837.13 Mbps   Airtel Lanka - Colombo
 Dhaka, BD        50.83 ms    N/A     3888.60 Mbps   1455.85 Mbps   Grameenphone Ltd - Dhaka
 Bangkok, TH      23.73 ms    0.0%    3404.93 Mbps   3434.33 Mbps   3BB - Bangkok
 Ho Chi Minh, VN  83.16 ms    0.0%    1243.44 Mbps   1339.76 Mbps   Viettel Network - Ho Chi Minh
 Hanoi, VN        64.52 ms    22.7%   91.27 Mbps     0.67 Mbps      Vietnamobile - Hanoi
 Manila, PH       39.39 ms    0.0%    4040.06 Mbps   1414.18 Mbps   PLDT - Manila
 Tapei, TW        184.05 ms   N/A     2980.94 Mbps   485.46 Mbps    Chunghwa Mobile - Taipei
 Jakarta, ID      12.63 ms    0.0%    3364.26 Mbps   5722.45 Mbps   Biznet Networks - Jakarta
 Surabaya, ID     23.66 ms    N/A     4297.83 Mbps   2865.90 Mbps   PT. Indonesia Comnets Plus - Surabaya
 Kuala Lum, MY    10.33 ms    0.0%    6233.27 Mbps   4779.49 Mbps   Telekom Malaysia Berhad - Kuala Lumpur
 Novosibirsk, RU  237.21 ms   0.0%    30.95 Mbps     475.41 Mbps    MegaFon - Novosibirsk
 Istanbul, TR     285.04 ms   1.3%    1154.09 Mbps   381.28 Mbps    Turkcell - Istanbul
 Dubai, AE        80.35 ms    N/A     4308.28 Mbps   967.82 Mbps    ETISALAT-UAE - Dubai
 Jeddah, SA       107.20 ms   0.0%    2931.15 Mbps   428.80 Mbps    Mobily - Jeddah
 Avg DL Speed       : 3182.53 Mbps
 Avg UL Speed       : 1916.07 Mbps
 Total DL Data      : 107.33 GB
 Total UL Data      : 53.97 GB
 Total Data         : 161.30 GB
 Duration           : 12 min 57 sec
 System Time        : 12/09/2023 - 19:54:52 IST
 Total Script Runs  : 23052
Africa: https://result.network-speed.xyz/r/1694537113_747AYT_AFRICA.txt
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz
 CPU Cores          : 1 @ 1350.000 MHz
 CPU Cache          : 6144 KB
 AES-NI             : ? Enabled
 VM-x/AMD-V         : ? Enabled
 Total Disk         : 4.9 GB (2.0 GB Used)
 Total RAM          : 128.0 MB (86.2 MB Used)
 System uptime      : 76 days, 15 hour 46 min
 Load average       : 0.19, 0.16, 0.14
 OS                 : Ubuntu 20.04.5 LTS
 Kernel             : 5.4.0
 Virtualization     : OPENVZ
 Basic Network Info
 ISP                : OVH SAS
 ASN                : AS16276 OVH SAS
 Host               : OVH Ltd
 Speedtest.net (Region: AFRICA)
 ISP: OVH SAS
 Nearest          0.38 ms     0.0%    897.09 Mbps    231.58 Mbps    FlawCra - London
 Cape Town, ZA    180.45 ms   0.0%    949.51 Mbps    220.12 Mbps    MTN SA - Cape Town
 Cape Town, ZA    148.89 ms   0.0%    952.90 Mbps    239.20 Mbps    Vodacom - Cape Town
 Johannesburg, ZA 172.25 ms   0.0%    924.08 Mbps    234.63 Mbps    i3D.net - Johannesburg
 Harare, ZW       195.55 ms   0.0%    450.94 Mbps    4.74 Mbps      Econet Wireless Zimbabwe - Harare
 Maputo, MZ       266.59 ms   14.5%   477.86 Mbps    1.25 Mbps      TMCEL - Mo�ambique Telecom - Maputo
 Antananarivo, MG 193.88 ms   3.2%    802.97 Mbps    190.10 Mbps    Orange Madagascar - Antananarivo
 Darusalaam, TZ   139.81 ms   0.0%    869.31 Mbps    240.66 Mbps    Vodacom Tanzania Ltd - Dar es Salaam
 Nairobi, KE      151.39 ms   0.3%    621.74 Mbps    230.99 Mbps    Airtel Kenya - Nairobi
 Addis Ababa, ET  89.57 ms    N/A     833.43 Mbps    231.13 Mbps    Ethio Telecom - Addis Ababa
 Cairo, EG        59.57 ms    0.0%    937.25 Mbps    234.87 Mbps    Vodafone Egypt - Cairo
 Alexandria, EG   FAILED
 Rabat, MA        43.53 ms    0.0%    945.89 Mbps    247.27 Mbps    Maroc Telecom - Rabat
 Algiers, DZ      65.75 ms    0.4%    939.95 Mbps    200.52 Mbps    Ooredoo Algeria - Algiers
 Lagos, NG        114.07 ms   0.0%    18.18 Mbps     182.37 Mbps    MTN NIGERIA COMMUNICATIONS LTD - Lagos
 Avg DL Speed       : 758.65 Mbps
 Avg UL Speed       : 192.10 Mbps
 Total DL Data      : 15.81 GB
 Total UL Data      : 3.83 GB
 Total Data         : 19.64 GB
 Duration           : 7 min 27 sec
 System Time        : 12/09/2023 - 16:43:16 UTC
AU: https://result.network-speed.xyz/r/1694536652_DGXND8_AU.txt
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
 CPU Cores          : 2 @ 2699.998 MHz
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ❌ Disabled
 Total Disk         : 52.1 GB (19.2 GB Used)
 Total RAM          : 2.4 GB (575.0 MB Used)
 Total Swap         : 2.0 GB (75.2 MB Used)
 System uptime      : 2 days, 22 hour 45 min
 Load average       : 0.36, 0.37, 0.31
 Basic Network Info
 ISP                : Multacom Corporation
 ASN                : AS35916 MULTACOM CORPORATION
 Host               : Multacom Corporation
 Location (IPv4)    : Los Angeles, California, US
 Speedtest.net (Region: AUSTRALIA/NZ)
 ISP: Multacom Corporation
 Nearest          42.29 ms    0.0%    557.25 Mbps    920.97 Mbps    Ideatek Telcom - Wichita, KS
 Brisbane         167.06 ms   0.0%    406.70 Mbps    527.94 Mbps    APNIC Pty Ltd - Brisbane
 Sydney           133.57 ms   0.0%    903.26 Mbps    230.42 Mbps    GSL Networks - Sydney
 Sydney           154.68 ms   0.0%    809.86 Mbps    582.16 Mbps    Telstra - Sydney
 Perth            194.12 ms   0.0%    521.59 Mbps    480.49 Mbps    Aussie Broadband - Perth
 Perth            FAILED
 Melbourne        160.21 ms   0.0%    634.33 Mbps    528.74 Mbps    Digital Pacific - Melbourne
 Melbourne        166.33 ms   0.0%    692.08 Mbps    560.47 Mbps    Telstra - Melbourne
 Adelaide         173.68 ms   0.0%    505.10 Mbps    507.53 Mbps    Exetel - Adelaide
 Canberra         152.12 ms   0.0%    739.89 Mbps    601.24 Mbps    Telstra - Canberra
 Auckland         136.19 ms   0.0%    791.04 Mbps    541.41 Mbps    One New Zealand - Auckland
 Auckland         124.08 ms   0.0%    935.37 Mbps    442.25 Mbps    MyRepublic Group Ltd - Auckland
 Avg DL Speed       : 681.50 Mbps
 Avg UL Speed       : 538.51 Mbps
 Total DL Data      : 10.86 GB
 Total UL Data      : 8.31 GB
 Total Data         : 19.17 GB
 Duration           : 5 min 48 sec
 System Time        : 12/09/2023 - 22:07:31 IST
 Total Script Runs  : 23062
GCC: https://result.network-speed.xyz/r/1694531543_BZ6K6M_MIDDLE-EAST.txt
 Basic System Info
 CPU Model          : AMD EPYC 7452 32-Core Processor
 CPU Cores          : 1 @ 2349.998 MHz
 CPU Cache          : 512 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 24.5 GB (2.1 GB Used)
 Total RAM          : 1.9 GB (619.0 MB Used)
 System uptime      : 12 days, 21 hour 36 min
 Kernel             : 6.1.0-10-amd64
 Basic Network Info
 ISP                : Maximilian Jacobsen
 ASN                : AS206075 Maximilian Jacobsen
 ASN (IPv4)         : AS13335 Cloudflare, Inc.
 Speedtest.net (Region: GCC MIDDLE EAST)
 ISP: server-factory.com
 Nearest          0.55 ms     0.0%    992.39 Mbps    1040.93 Mbps   Bahnhof AB - Stockholm
 Abu Dhabi, AE    151.85 ms   0.0%    442.17 Mbps    643.17 Mbps    du - Abu Dhabi
 Dubai, AE        137.71 ms   0.0%    988.05 Mbps    150.14 Mbps    i3D.net - Dubai
 Fujairah, AE     149.77 ms   0.0%    424.39 Mbps    681.76 Mbps    ETISALAT-UAE - Fujairah
 Muscat, OM       142.23 ms   0.0%    459.76 Mbps    640.28 Mbps    OmanTel - Muscat
 Seeb, OM         141.16 ms   0.0%    982.74 Mbps    192.14 Mbps    Ooredoo Oman - Seeb
 Sanaa, YE        164.83 ms   2.9%    457.44 Mbps    206.34 Mbps    Yemen Net - Sanaa
 Doha, QA         160.63 ms   0.0%    401.23 Mbps    689.61 Mbps    Ooredoo Qatar - Doha
 Lusail, QA       FAILED
 Manama, BH       146.16 ms   0.9%    432.42 Mbps    498.97 Mbps    ZainBH - Manama
 Rifa, BH         123.94 ms   0.0%    375.79 Mbps    618.06 Mbps    stc Bahrain - Riffa
 Kuwait, KW       170.76 ms   0.0%    985.40 Mbps    181.95 Mbps    Zain Kuwait - Kuwait City
 Kuwait, KW       123.71 ms   N/A     986.56 Mbps    50.23 Mbps     Ooredoo Kuwait - Kuwait City
 Riyadh, SA       100.26 ms   0.0%    434.83 Mbps    691.24 Mbps    Mobily - Riyadh
 Dammam, SA       113.12 ms   0.0%    990.53 Mbps    234.76 Mbps    Saudi Telecom Company
 Jeddah, SA       126.99 ms   0.8%    442.16 Mbps    686.97 Mbps    Zain KSA - Jeddah
 Jeddah, SA       99.17 ms    0.0%    1012.35 Mbps   249.05 Mbps    Saudi Telecom Company
 Avg DL Speed       : 675.51 Mbps
 Avg UL Speed       : 465.98 Mbps
 Total DL Data      : 14.95 GB
 Total UL Data      : 10.61 GB
 Total Data         : 25.56 GB
 Duration           : 7 min 43 sec
 System Time        : 12/09/2023 - 17:12:21 CEST
 Total Script Runs  : 23058
India: https://result.network-speed.xyz/r/1694530534_3C9IAU_INDIA.txt
 Basic System Info
 CPU Model          : CPU model not detected
 CPU Cores          : 3
 AES-NI             : ✔ Enabled
 Total Disk         : 48.4 GB (15.3 GB Used)
 Total RAM          : 17.5 GB (2.2 GB Used)
 System uptime      : 2 days, 21 hour 0 min
 Load average       : 0.34, 0.32, 0.33
 Arch               : aarch64 (64 Bit)
 Kernel             : 5.15.0-1040-oracle
 Basic Network Info
 ISP                : Oracle Corporation
 ASN                : AS31898 Oracle Corporation
 Host               : Oracle Cloud Infrastructure (ap-hyderabad-1)
 Speedtest.net (Region: INDIA भारत)
 ISP: Oracle Cloud
 Nearest          0.65 ms     0.0%    806.47 Mbps    922.41 Mbps    Excitel - Hyderabad
 Mumbai, MH       13.42 ms    0.0%    2885.13 Mbps   834.37 Mbps    Tata Teleservices Ltd - Mumbai
 Mumbai, MH       16.66 ms    0.0%    2861.96 Mbps   1143.22 Mbps   Airtel Broadband - Mumbai
 Pune, MH         26.67 ms    0.0%    2976.98 Mbps   730.39 Mbps    Tata Play Fiber - Pune
 Hyderabad, AP/TL 1.37 ms     N/A     1585.11 Mbps   1693.84 Mbps   Airtel Broadband - Hyderabad
 Bangalore, KA    18.81 ms    5.7%    2973.75 Mbps   796.04 Mbps    Bharti Airtel Ltd - Bangalore
 Bangalore, KA    10.15 ms    0.0%    2920.86 Mbps   1126.20 Mbps   ACT FIBERNET - Bangalore
 Mangalore, KA    16.71 ms    0.0%    1436.57 Mbps   479.96 Mbps    BBNL - Mangalore
 Chennai, TN      38.96 ms    N/A     3013.24 Mbps   782.67 Mbps    Jio - Chennai
 Coimbatore, TN   FAILED
 Madurai, TN      172.70 ms   0.0%    2651.04 Mbps   316.86 Mbps    Vi India - Madurai
 Kochi, KL        32.22 ms    N/A     2969.97 Mbps   756.55 Mbps    Jio - Kochi
 Kochi, KL        24.34 ms    0.0%    3031.87 Mbps   691.95 Mbps    Asianet Broadband - Cochin
 Trivandrum, KL   35.34 ms    0.0%    1968.42 Mbps   604.54 Mbps    Keralavision Broadband - Trivandrum
 Kolkata, WB      33.87 ms    0.0%    2559.87 Mbps   539.00 Mbps    Alliance Broadband Services Pvt Ltd - Kolkata
 Delhi, DL        40.88 ms    0.0%    2061.72 Mbps   155.79 Mbps    Extreme IX - New Delhi
 Gurgaon, HR      23.96 ms    0.0%    2761.97 Mbps   522.31 Mbps    Powernet - Gurgaon
 Patna, BH        76.64 ms    N/A     2755.07 Mbps   216.12 Mbps    Vi India - Patna
 Avg DL Speed       : 2483.54 Mbps
 Avg UL Speed       : 724.25 Mbps
 Total DL Data      : 54.35 GB
 Total UL Data      : 18.78 GB
 Total Data         : 73.12 GB
 Duration           : 7 min 39 sec
 System Time        : 12/09/2023 - 20:25:32 IST
 Total Script Runs  : 23056
China: https://result.network-speed.xyz/r/1694528635_EI46XX_CHINA.txt
 Basic System Info
 CPU Model          : AMD Ryzen 9 5950X 16-Core Processor
 CPU Cores          : 1 @ 3393.592 MHz
 CPU Cache          : 512 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 456.1 GB (115.7 GB Used)
 Total RAM          : 1.4 GB (296.8 MB Used)
 System uptime      : 46 days, 20 hour 11 min
 Load average       : 0.66, 0.68, 0.68
 OS                 : Ubuntu 22.04.2 LTS
 Kernel             : 5.15.0-78-generic
 Basic Network Info
 ISP                : xTom Pty Ltd
 ASN                : AS3258 xTom Pty Ltd
 Host               : Virtual Machine Solutions LLC
 Speedtest.net (Region: CHINA 中華人民共和國)
 ISP: xTom Pty Ltd
 Nearest          0.70 ms     0.0%    804.22 Mbps    820.82 Mbps    GSL Networks - Tokyo
 CU - Shanghai    80.15 ms    0.5%    153.39 Mbps    71.08 Mbps     China Unicom 5G - Shanghai
 CT - Shanghai    FAILED
 CM - Beijing     108.49 ms   0.0%    684.01 Mbps    692.15 Mbps    China Mobile Group Beijing Co.Ltd - Beijing
 CU - Beijing     FAILED
 CT - Nanjing     35.39 ms    0.7%    520.91 Mbps    18.38 Mbps     China Telecom JiangSu 5G - Nanjing
 CU - Shenyang    91.04 ms    0.8%    47.63 Mbps     16.21 Mbps     Unicom - Shenyang
 CT - Suzhou      36.20 ms    N/A     459.57 Mbps    18.78 Mbps     China Telecom JiangSu 5G - Suzhou
 CT - Yangzhou    83.99 ms    7.3%    387.30 Mbps    1.80 Mbps      江苏电信5G - Yangzhou
 CM - Hangzhou    73.16 ms    0.0%    639.14 Mbps    694.23 Mbps    China Mobile Zhejiang 5G - Hangzhou
 CU - Zhengzhou   105.74 ms   N/A     522.65 Mbps    56.18 Mbps     China Unicom HeNan 5G - Zhengzhou
 CT - Changsha    63.56 ms    9.5%    58.04 Mbps     1.45 Mbps      湖南电信5G - Changsha
 CU - Changsha    92.86 ms    N/A     5.01 Mbps      32.65 Mbps     湖南联通5G - Changsha
 CM - Chengdu     103.71 ms   0.0%    733.53 Mbps    468.51 Mbps    China Mobile Group Sichuan - Chengdu
 CT - Wuhan       FAILED
 CM - Xi an       102.05 ms   0.0%    550.09 Mbps    647.96 Mbps    陕西移动5G - Xi'an
 CT - Hefei       38.38 ms    10.2%   543.13 Mbps    2.76 Mbps      China Telecom AnHui 5G - Hefei
 CT - TianJin     53.30 ms    9.8%    80.10 Mbps     4.19 Mbps      China Telecom TianJin-5G - TianJin
 CM - Kwai Chung  107.07 ms   5.9%    483.54 Mbps    371.89 Mbps    China Mobile Hong Kong - Kwai Chung
 CM - Hong Kong   82.23 ms    0.0%    476.20 Mbps    589.46 Mbps    China Mobile Hong Kong Boardband - Hong Kong
 Hong Kong        53.67 ms    0.0%    678.47 Mbps    848.06 Mbps    HKIX - Hong Kong
 Hong Kong        244.21 ms   N/A     375.86 Mbps    48.51 Mbps     fdcservers.net - Hong Kong
 Hong Kong        51.76 ms    0.0%    546.80 Mbps    396.74 Mbps    Misaka Network, Inc. - Hong Kong
 Avg DL Speed       : 437.48 Mbps
 Avg UL Speed       : 290.09 Mbps
 Total DL Data      : 13.08 GB
 Total UL Data      : 8.57 GB
 Total Data         : 21.65 GB
 Duration           : 11 min 7 sec
 System Time        : 12/09/2023 - 19:53:52 IST
 Total Script Runs  : 23051
Iran: https://result.network-speed.xyz/r/1694528246_6GOL8A_IRAN.txt
 Basic System Info
 CPU Model          : Intel Core Processor (Skylake, IBRS)
 CPU Cores          : 1 @ 3408.020 MHz
 AES-NI             : ✔ Enabled
 Total Disk         : 726.8 GB (380.5 GB Used)
 Total RAM          : 1.9 GB (633.3 MB Used)
 System uptime      : 2 days, 20 hour 22 min
 Load average       : 0.60, 0.54, 0.56
 OS                 : Ubuntu 20.04.6 LTS
 Kernel             : 5.4.0-162-generic
 Basic Network Info
 ISP                : Kuroit Limited
 ASN                : AS203363 Kuroit Limited
 ASN (IPv4)         : AS25369 Hydra Communications Ltd
 Host               : Kuroit Limited
 Speedtest.net (Region: IRAN ایران)
 ISP: Kuroit Limited
 Nearest          23.06 ms    0.0%    881.37 Mbps    702.97 Mbps    ADD39 - Coding SRL - Abbadia San Salvatore
 Tehran           87.77 ms    1.1%    601.46 Mbps    181.43 Mbps    MCI
 Tehran           88.55 ms    0.0%    881.51 Mbps    477.43 Mbps    Irancell - Tehran
 Tehran           84.87 ms    0.0%    163.94 Mbps    463.14 Mbps    HostIran.net - Tehran
 Shiraz           104.00 ms   0.0%    530.22 Mbps    388.79 Mbps    MCI
 Isfahan          99.80 ms    0.0%    523.11 Mbps    314.49 Mbps    MCI
 Tabriz           101.04 ms   0.0%    217.35 Mbps    162.56 Mbps    Maxnet - Tabriz
 Avg DL Speed       : 542.71 Mbps
 Avg UL Speed       : 384.40 Mbps
 Total DL Data      : 4.76 GB
 Total UL Data      : 4.03 GB
 Total Data         : 8.78 GB
 Duration           : 3 min 22 sec
 System Time        : 12/09/2023 - 19:47:25 IST
 Total Script Runs  : 23050
Indonesia: https://result.network-speed.xyz/r/1695397374_P9DYIL_INDONESIA.txt
Of course, I am actively developing and updating this regularly, so any feedbacks and suggestions are welcome!
«13456711
  • AlbaHostAlbaHost Hosting Provider
    Great work, just tested it and:
    https://cdn1.frocdn.ch/hyPGeIL7RuUQKsJ.txt
    Looks great.
    Thanked by (2)sh97 Not_Oles
    wWw.AlbaHost.Net .AL domains, Dedicated Servers, VPS/VDS and Hosting Services. Geo located in Albania.
  • edited April 2023
    I use it on my site https://KangServer.id. Keep the great work bro!
    AlphaVPS Ryzen VPS - USA (Los Angeles)
     Version            : v2023.04.25
     Basic System Info
     CPU Model          : AMD Ryzen 7 7700X 8-Core Processor
     CPU Cores          : 2 @ 4491.540 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 43.2 GB (5.4 GB Used)
     Total RAM          : 1.9 GB (189.1 MB Used)
     Total Swap         : 1024.0 MB (0 Used)
     System uptime      : 0 days, 2 hour 44 min
     Kernel             : 5.15.0-71-generic
     Basic Network Info
     ISP                : WebNX, Inc.
     ASN                : AS18450 WebNX, Inc.
     Host               : WebNX, Inc.
     ISP: WebNX
     Nearest          39.62 ms    0.0%    929.78 Mbps    887.67 Mbps    Ideatek Telcom - Wichita, KS
     Vancouver, BC    44.04 ms    N/A     928.81 Mbps    830.46 Mbps    TELUS - Vancouver, BC
     Toronto, ON      97.48 ms    0.0%    922.04 Mbps    812.98 Mbps    TELUS - Toronto, ON
     Toronto, ON      95.80 ms    0.0%    937.16 Mbps    810.45 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     85.75 ms    0.0%    924.18 Mbps    740.27 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     56.98 ms    0.0%    809.31 Mbps    800.91 Mbps    Clouvider Ltd - New York, NY
     Ashburn, VA      72.05 ms    0.0%    938.88 Mbps    800.22 Mbps    Rackdog - Ashburn, VA
     Charlotte, NC    54.09 ms    0.0%    942.79 Mbps    839.00 Mbps    Windstream - Charlotte, NC
     Atlanta, GA      50.47 ms    N/A     937.20 Mbps    813.01 Mbps    fdcservers.net - Atlanta, GA
     Miami, FL        62.13 ms    0.0%    937.32 Mbps    809.92 Mbps    AT&T - Miami, FL
     Dallas, TX       56.44 ms    0.0%    917.64 Mbps    809.58 Mbps    Hivelocity - Dallas, TX
     Kansas, MO       92.08 ms    N/A     950.61 Mbps    835.26 Mbps    Dish Wireless - Kansas City, MO
     Minneapolis, MN  49.97 ms    0.0%    938.86 Mbps    864.38 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      44.04 ms    0.0%    966.50 Mbps    897.72 Mbps    GSL Networks - Chicago, IL
     Cleveland, OH    64.31 ms    0.0%    947.63 Mbps    793.26 Mbps    Windstream - Cleveland, OH
     Albuquerque, NM  34.73 ms    N/A     928.31 Mbps    894.88 Mbps    Comcast - Albuquerque, NM
     Denver, CO       32.27 ms    0.0%    930.49 Mbps    907.54 Mbps    Comcast - Denver, CO
     Portland, OR     23.50 ms    N/A     947.40 Mbps    921.22 Mbps    CenturyLink - Portland, OR
     Las Vegas, NV    6.06 ms     N/A     949.19 Mbps    943.84 Mbps    Dish Wireless - Las Vegas, NV
     Phoenix, AZ      30.25 ms    0.0%    947.20 Mbps    909.77 Mbps    GSL Networks - Phoenix, AZ
     Los Angeles, CA  21.74 ms    0.0%    932.21 Mbps    918.59 Mbps    i3D.net - Los Angeles, CA
     Los Angeles, CA  14.46 ms    0.0%    933.70 Mbps    912.46 Mbps    ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     19.56 ms    0.0%    929.83 Mbps    918.05 Mbps    Misaka Network, Inc. - San Jose, CA
     Seattle, WA      39.28 ms    0.0%    954.09 Mbps    878.29 Mbps    GSL Networks - Seattle, WA
     Mexico City, MX  62.53 ms    0.0%    878.39 Mbps    770.72 Mbps    AT&T México - Mexico City
     Guadalajara, MX  50.52 ms    N/A     932.31 Mbps    824.36 Mbps    INFINITUM - Guadalajara
     Hermosillo, MX   30.30 ms    0.0%    941.20 Mbps    918.17 Mbps    Totalplay - Hermosillo
     Avg DL Speed       : 930.85 Mbps
     Avg UL Speed       : 854.19 Mbps
     Total DL Data      : 34.43 GB
     Total UL Data      : 29.13 GB
     Total Data         : 63.56 GB
     Duration           : 11 min 26 sec
     System Time        : 27/04/2023 - 13:02:50 UTC
     Total Script Runs  : 1080
     Result             : https://cdn1.frocdn.ch/cEfdXlg1Rr3rpvQ.txt
    KangServer.id - Doing some benchmarks on VPS / Server
    LowEnd VPS Deals - LowEnd / Cheap VPS Deals
  • Let's start network-speed.xyz bench thread.
    Thanked by (3)sh97 chimichurri Not_Oles
  • @dosai said: Let's start network-speed.xyz bench thread.
    Holy... Never thought this hahaha.
    Sounds like a good idea!
    @febryanvaldo would you like to do the honors? I think you are one of the first users and you use it a lot.
  • edited April 2023
    There seems to be some small problem
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
     CPU Cores          : 1 @ 2899.996 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 18,2 GB (2,1 GB Used)
     Total RAM          : 1,4 GB (644,4 MB Used)
     Total Swap         : 1,5 GB (0 Used)
     System uptime      : 93 days, 17 hour 42 min
     OS                 : Debian GNU/Linux 11
     Kernel             : 5.10.0-21-amd64
     Basic Network Info
     Nearest          0.40 ms     N/A     793.00 Mbps    802.12 Mbps    Netprotect - Los Angeles, CA
     Vancouver, BC    28.07 ms    N/A     358.60 Mbps    898.95 Mbps    TELUS - Vancouver, BC
     Toronto, ON      83.17 ms    0.0%    435.26 Mbps    686.20 Mbps    TELUS - Toronto, ON
     Toronto, ON      76.72 ms    0.0%    488.03 Mbps    858.41 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     76.42 ms    0.0%    37.52 Mbps     882.94 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     61.56 ms    0.0%    71.74 Mbps     785.50 Mbps    Clouvider Ltd - New York, NY
     Ashburn, VA      67.74 ms    0.0%    112.86 Mbps    725.99 Mbps    Rackdog - Ashburn, VA
    awk: line 1: 02911e+11923 : decimal overflow
     Charlotte, NC    54.86 ms    0.0%    102.78 Mbps    807.11 Mbps    Windstream - Charlotte, NC
    awk: line 1: 15144e+11123 : decimal overflow
     Atlanta, GA      50.20 ms    N/A     52.78 Mbps     814.91 Mbps    fdcservers.net - Atlanta, GA
     Miami, FL        59.96 ms    0.0%    303.41 Mbps    794.13 Mbps    AT&T - Miami, FL
     Dallas, TX       33.99 ms    0.0%    483.07 Mbps    905.09 Mbps    Hivelocity - Dallas, TX
     Kansas, MO       63.47 ms    N/A     226.38 Mbps    803.83 Mbps    Dish Wireless - Kansas City, MO
     Minneapolis, MN  49.69 ms    0.0%    57.53 Mbps     818.62 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      43.95 ms    0.0%    906.33 Mbps    801.76 Mbps    GSL Networks - Chicago, IL
    awk: line 1: 07826e+11812 : decimal overflow
     Cleveland, OH    79.03 ms    0.0%    261.81 Mbps    790.62 Mbps    Windstream - Cleveland, OH
    awk: line 1: 23815e+1095 : decimal overflow
     Albuquerque, NM  38.35 ms    N/A     100.56 Mbps    827.16 Mbps    Comcast - Albuquerque, NM
     Denver, CO       30.24 ms    0.0%    107.19 Mbps    908.49 Mbps    Comcast - Denver, CO
    awk: line 1: 3212e+1508 : decimal overflow
     Portland, OR     22.27 ms    N/A     893.12 Mbps    831.37 Mbps    CenturyLink - Portland, OR
    awk: line 1: syntax error at or near ;
     Las Vegas, NV    6.15 ms     N/A     377.87 Mbps    830.04 Mbps    Dish Wireless - Las Vegas, NV
     Phoenix, AZ      7.93 ms     0.0%    871.21 Mbps    831.17 Mbps    GSL Networks - Phoenix, AZ
    awk: line 1: 4561e+1087 : decimal overflow
     Los Angeles, CA  0.91 ms     0.0%    837.92 Mbps    831.53 Mbps    i3D.net - Los Angeles, CA
    awk: line 1: 9089e+11867 : decimal overflow
     Los Angeles, CA  0.55 ms     0.0%    877.18 Mbps    901.66 Mbps    ReliableSite Hosting - Los Angeles, CA
    awk: line 1: 00164e+11958 : decimal overflow
     San Jose, CA     7.13 ms     0.0%    456.02 Mbps    876.96 Mbps    Misaka Network, Inc. - San Jose, CA
     Seattle, WA      29.90 ms    0.0%    903.76 Mbps    888.39 Mbps    GSL Networks - Seattle, WA
     Mexico City, MX  60.61 ms    0.0%    577.85 Mbps    810.31 Mbps    AT&T México - Mexico City
     Guadalajara, MX  30.69 ms    N/A     79.70 Mbps     890.97 Mbps    INFINITUM - Guadalajara
     Hermosillo, MX   23.92 ms    0.0%    300.04 Mbps    836.41 Mbps    Totalplay - Hermosillo
    awk: line 1: runaway regular expression /1024; exit ...
    awk: line 1: 01943e+11921 : decimal overflow
     Avg DL Speed       : inf Mbps
     Avg UL Speed       :  Mbps
     Total DL Data      :  GB
     Total UL Data      :  GB
     Total Data         :  GB
     Duration           : 10 min 56 sec
     System Time        : 27/04/2023 - 17:25:56 CEST
     Total Script Runs  : 1112
     Result             : https://cdn1.frocdn.ch/aEYr9mLS1fhDFsJ.txt
    "He sounds like hearing him say to the liquor merchant: you who sell it what buys you better ?"
    F. De André --- Free NAT KVM
  • Virmach Frankfurt (region: EU)
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : AMD Ryzen 9 5900X 12-Core Processor
     CPU Cores          : 4 @ 3693.060 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 39.0 GB (3.5 GB Used)
     Total RAM          : 6.6 GB (174.2 MB Used)
     System uptime      : 5 days, 2 hour 34 min
     Kernel             : 5.15.0-70-generic
     Basic Network Info
     ISP                : Owl Limited
     ASN                : AS3214 xTom GmbH
     Location (IPv4)    : Frankfurt am Main, Hesse, DE
     ISP: xTom GmbH
     Nearest          0.63 ms     0.0%    936.14 Mbps    1870.45 Mbps   suec//dacor GmbH - Frankfurt
     London, UK       12.82 ms    0.0%    1862.62 Mbps   1867.87 Mbps   VeloxServ Communications - London
     Edinburgh, UK    27.63 ms    N/A     1688.79 Mbps   1656.31 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       31.22 ms    0.0%    1898.49 Mbps   1626.02 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.60 ms     0.0%    938.57 Mbps    1842.35 Mbps   GSL Networks - Amsterdam
     Paris, FR        12.03 ms    0.0%    937.68 Mbps    1872.71 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    16.39 ms    0.0%    933.74 Mbps    1853.63 Mbps   GSL Networks - Marseille
     Madrid, ES       28.87 ms    0.0%    936.17 Mbps    1847.17 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    30.92 ms    0.0%    1539.63 Mbps   1588.91 Mbps   Adamo - Barcelona
     Lisbon, PT       42.95 ms    N/A     1293.11 Mbps   1408.18 Mbps   fdcservers.net - Lisbon
     Rome, IT         23.72 ms    0.0%    1694.24 Mbps   943.93 Mbps    TIM SpA - Rome
     Zurich, CH       10.84 ms    0.0%    937.98 Mbps    1830.63 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.93 ms     0.0%    934.49 Mbps    1870.95 Mbps   23M GmbH - Frankfurt Am Main
     Berlin, DE       8.06 ms     0.0%    1875.67 Mbps   1835.94 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       12.23 ms    0.0%    923.29 Mbps    1822.42 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     18.47 ms    N/A     1701.66 Mbps   1784.73 Mbps   Yettel Hungary - Budapest
     Gdansk, PL       24.97 ms    0.0%    1829.32 Mbps   1735.99 Mbps   Orange Polska S.A. - Gdansk
     Warsaw, PL       20.14 ms    0.0%    1517.05 Mbps   1847.51 Mbps   UPC Polska - Warszawa
     Lviv, UA         27.98 ms    0.0%    1833.47 Mbps   938.29 Mbps    Kyivstar - Lviv
     Kyiv, UA         28.58 ms    0.0%    1349.52 Mbps   1290.55 Mbps   o3 - Kyiv
     Minsk, BY        27.70 ms    0.0%    1814.54 Mbps   1840.22 Mbps   A1 - Minsk
     Bucharest, RO    29.24 ms    0.0%    1440.46 Mbps   1600.66 Mbps   Orange Romania Communications - Bucharest
     Helsinki, FI     22.21 ms    0.0%    1168.53 Mbps   1845.49 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.17 ms    0.0%    1388.64 Mbps   1823.44 Mbps   i3D.net - Stockholm
     Oslo, NO         27.74 ms    0.0%    1204.03 Mbps   1814.12 Mbps   Speedtest.net - Oslo
     Moscow, RU       43.22 ms    0.0%    1191.55 Mbps   1715.22 Mbps   MTS - Moscow
     Moscow, RU       38.06 ms    0.0%    1487.68 Mbps   1485.81 Mbps   Rostelecom - Moscow
     Istanbul, TR     37.29 ms    0.0%    1824.76 Mbps   1451.27 Mbps   Turkcell - Istanbul
     Antalya, TR      47.08 ms    0.0%    891.42 Mbps    1342.94 Mbps   Vodafone TR - Antalya
     Avg DL Speed       : 1378.38 Mbps
     Avg UL Speed       : 1663.91 Mbps
     Total DL Data      : 50.85 GB
     Total UL Data      : 52.56 GB
     Total Data         : 103.41 GB
     Duration           : 10 min 47 sec
     System Time        : 27/04/2023 - 14:59:21 UTC
     Total Script Runs  : 1091
     Result             : https://cdn1.frocdn.ch/JtbM5Hploe0HAVv.txt
    Servarica Montreal (region: NA)
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
     CPU Cores          : 1 @ 2593.772 MHz
     CPU Cache          : 20480 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 500.0 GB (487.7 GB Used)
     Total RAM          : 927.2 MB (227.6 MB Used)
     System uptime      : 5 days, 2 hour 58 min
     Load average       : 0.36, 0.08, 0.03
     OS                 : Ubuntu 22.04.1 LTS
     Kernel             : 5.15.0-56-generic
     Virtualization     : XEN
     Basic Network Info
     ISP                : Rica Web Services
     ASN                : AS26832 Rica Web Services
     Host               : Rica Web Services
     ISP: Rica Web Services
     Nearest          3.94 ms     0.0%    95.83 Mbps     98.81 Mbps     i3D.net - Montréal, QC
     Vancouver, BC    66.84 ms    N/A     95.57 Mbps     97.18 Mbps     TELUS - Vancouver, BC
     Toronto, ON      14.02 ms    0.0%    96.09 Mbps     100.48 Mbps    TELUS - Toronto, ON
     Toronto, ON      8.03 ms     0.0%    96.94 Mbps     98.96 Mbps     Bell Canada - Toronto, ON
     Montreal, QC     13.53 ms    0.0%    97.02 Mbps     98.37 Mbps     Rogers Wireless - Montréal, QC
     New York, NY     85.96 ms    0.0%    99.16 Mbps     99.07 Mbps     Clouvider Ltd - New York, NY
     Ashburn, VA      14.35 ms    0.0%    97.14 Mbps     98.28 Mbps     Rackdog - Ashburn, VA
     Charlotte, NC    45.35 ms    0.0%    97.45 Mbps     96.93 Mbps     Windstream - Charlotte, NC
     Atlanta, GA      30.57 ms    N/A     99.56 Mbps     96.74 Mbps     fdcservers.net - Atlanta, GA
     Miami, FL        44.72 ms    0.0%    95.44 Mbps     84.28 Mbps     AT&T - Miami, FL
     Dallas, TX       43.22 ms    0.0%    96.12 Mbps     91.87 Mbps     Hivelocity - Dallas, TX
     Kansas, MO       42.62 ms    N/A     96.41 Mbps     97.83 Mbps     Dish Wireless - Kansas City, MO
     Minneapolis, MN  30.80 ms    0.0%    97.30 Mbps     101.17 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      18.07 ms    0.0%    102.74 Mbps    86.86 Mbps     GSL Networks - Chicago, IL
     Cleveland, OH    27.74 ms    0.0%    95.80 Mbps     97.18 Mbps     Windstream - Cleveland, OH
     Albuquerque, NM  57.38 ms    N/A     97.96 Mbps     95.20 Mbps     Comcast - Albuquerque, NM
     Denver, CO       50.31 ms    0.0%    96.98 Mbps     99.56 Mbps     Comcast - Denver, CO
     Portland, OR     81.76 ms    N/A     102.80 Mbps    98.02 Mbps     CenturyLink - Portland, OR
     Las Vegas, NV    90.11 ms    N/A     102.21 Mbps    97.49 Mbps     Dish Wireless - Las Vegas, NV
     Phoenix, AZ      85.75 ms    0.0%    103.61 Mbps    86.65 Mbps     GSL Networks - Phoenix, AZ
     Los Angeles, CA  81.62 ms    0.0%    98.79 Mbps     86.97 Mbps     i3D.net - Los Angeles, CA
     Los Angeles, CA  70.64 ms    0.0%    97.27 Mbps     59.98 Mbps     ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     70.14 ms    0.0%    98.99 Mbps     70.67 Mbps     Misaka Network, Inc. - San Jose, CA
     Seattle, WA      65.43 ms    0.0%    98.20 Mbps     95.93 Mbps     GSL Networks - Seattle, WA
     Mexico City, MX  95.40 ms    0.0%    98.90 Mbps     86.10 Mbps     AT&T México - Mexico City
     Guadalajara, MX  117.56 ms   N/A     100.63 Mbps    98.58 Mbps     INFINITUM - Guadalajara
     Hermosillo, MX   119.26 ms   0.0%    99.75 Mbps     95.02 Mbps     Totalplay - Hermosillo
     Avg DL Speed       : 98.32 Mbps
     Avg UL Speed       : 93.12 Mbps
     Total DL Data      : 2.99 GB
     Total UL Data      : 3.37 GB
     Total Data         : 6.36 GB
     Duration           : 11 min 35 sec
     System Time        : 27/04/2023 - 15:02:29 UTC
     Total Script Runs  : 1093
     Result             : https://cdn1.frocdn.ch/eeFRpnSKEKhJ7Ki.txt
    Hosthatch Amsterdam (region: GCC)
     Basic System Info
     CPU Model          : AMD EPYC 7551P 32-Core Processor
     CPU Cores          : 1 @ 1999.973 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 1.8 TB (1.7 TB Used)
     Total RAM          : 1.9 GB (277.9 MB Used)
     System uptime      : 30 days, 16 hour 52 min
     Load average       : 0.11, 0.04, 0.01
     Kernel             : 6.1.0-6-amd64
     Basic Network Info
     ISP                : HostHatch
     ASN                : AS63473 HostHatch, LLC
     Host               : HostHatch LLC
     Location (IPv4)    : Alkmaar, North Holland, NL
     ISP: HostHatch
     Nearest          1.41 ms     0.0%    2727.17 Mbps   8825.15 Mbps   Solcon Internetdiensten B.V. - Dronten
     Abu Dhabi, AE    133.50 ms   0.0%    4312.38 Mbps   111.52 Mbps    du - Abu Dhabi
     Dubai, AE        118.56 ms   0.0%    2119.67 Mbps   680.65 Mbps    i3D.net - Dubai
     Fujairah, AE     115.11 ms   0.0%    5883.15 Mbps   946.34 Mbps    ETISALAT-UAE - Fujairah
     Muscat, OM       175.29 ms   0.0%    1024.30 Mbps   408.12 Mbps    OmanTel - Muscat
     Seeb, OM         FAILED
     Sanaa, YE        209.91 ms   1.3%    1390.76 Mbps   10.62 Mbps     Yemen Net - Sanaa
     Doha, QA         121.74 ms   0.0%    3916.22 Mbps   483.86 Mbps    Ooredoo Qatar - Doha
     Lusail, QA       130.39 ms   0.0%    2520.42 Mbps   448.19 Mbps    Vodafone Qatar P.Q.S.C - Lusail
     Manama, BH       110.55 ms   0.0%    5600.36 Mbps   538.72 Mbps    ZainBH - Manama
     Rifa, BH         128.62 ms   0.0%    5421.88 Mbps   38.74 Mbps     stc Bahrain - Riffa
     Kuwait, KW       93.06 ms    0.0%    4786.17 Mbps   733.83 Mbps    Zain Kuwait - Kuwait City
     Kuwait, KW       105.47 ms   N/A     6061.77 Mbps   87.04 Mbps     Ooredoo Kuwait - Kuwait City
     Riyadh, SA       85.48 ms    0.0%    4996.45 Mbps   988.50 Mbps    Mobily - Riyadh
     Dammam, SA       87.04 ms    0.0%    5316.22 Mbps   1214.23 Mbps   Saudi Telecom Company
     Jeddah, SA       92.01 ms    0.0%    5051.15 Mbps   934.90 Mbps    Zain KSA - Jeddah
     Jeddah, SA       68.76 ms    0.0%    5932.80 Mbps   1577.30 Mbps   Saudi Telecom Company
     Avg DL Speed       : 4191.31 Mbps
     Avg UL Speed       : 1126.72 Mbps
     Total DL Data      : 97.50 GB
     Total UL Data      : 25.51 GB
     Total Data         : 123.01 GB
     Duration           : 8 min 18 sec
     System Time        : 27/04/2023 - 15:01:24 UTC
     Total Script Runs  : 1092
     Result             : https://cdn1.frocdn.ch/M7SDvBji9kWcGgP.txt
    Inception Phoenix (region: SA)
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
     CPU Cores          : 1 @ 2199.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 492.1 GB (485.7 GB Used)
     Total RAM          : 466.2 MB (77.3 MB Used)
     System uptime      : 6 days, 18 hour 47 min
     Load average       : 0.30, 0.07, 0.02
     Basic Network Info
     ISP                : Input Output Flood LLC
     ASN                : AS53755 Input Output Flood LLC
     Host               : Input Output Flood LLC
     ISP: Input Output Flood LLC
     Nearest          0.63 ms     0.0%    898.76 Mbps    935.81 Mbps    1GServers.com - Phoenix, AZ
     Sao Paulo, BR    158.32 ms   0.0%    685.52 Mbps    468.03 Mbps    i3D.net - São Paulo
     Rio, BR          162.61 ms   0.0%    593.31 Mbps    452.88 Mbps    TIM Brasil - Rio de Janeiro
     Salvador, BR     165.60 ms   0.0%    480.27 Mbps    462.56 Mbps    Claro net vírtua - Salvador
     Buenos, AR       199.62 ms   0.0%    493.44 Mbps    361.77 Mbps    Claro - Buenos Aires
     Buenos, AR       174.57 ms   N/A     707.80 Mbps    425.13 Mbps    fdcservers.net - Buenos Aires
     Santiago, CL     219.09 ms   N/A     548.69 Mbps    351.12 Mbps    Claro Chile - Santiago
     Lima, PE         123.00 ms   0.0%    785.78 Mbps    596.28 Mbps    Claro Perú - Lima
     Quito, EC        121.07 ms   N/A     540.26 Mbps    611.97 Mbps    Movistar Ecuador - Quito
     Caracas, VE      101.71 ms   0.0%    841.35 Mbps    721.22 Mbps    Movistar Venezuela - Caracas
     Bogota, CO       94.89 ms    0.0%    664.70 Mbps    744.90 Mbps    Claro Colombia - Bogotá
     Avg DL Speed       : 658.17 Mbps
     Avg UL Speed       : 557.42 Mbps
     Total DL Data      : 10.43 GB
     Total UL Data      : 8.15 GB
     Total Data         : 18.58 GB
     Duration           : 5 min 39 sec
     System Time        : 27/04/2023 - 16:53:48 CEST
     Total Script Runs  : 1089
     Result             : https://cdn1.frocdn.ch/HG8LDHOGrXvLWz9.txt
    Oracle San Jose (region: global)
     Basic System Info
     CPU Model          : AMD EPYC 7551 32-Core Processor
     CPU Cores          : 2 @ 1996.249 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 45.1 GB (31.8 GB Used)
     Total RAM          : 964.1 MB (316.3 MB Used)
     System uptime      : 61 days, 9 hour 17 min
     Load average       : 2.04, 1.69, 1.60
     Kernel             : 5.15.0-1029-oracle
     Basic Network Info
     Host               : Oracle Cloud Infrastructure (us-sanjose-1)
     ISP: Oracle Cloud
     Nearest          0.36 ms     0.0%    456.55 Mbps    477.82 Mbps    Acreto - San Jose, CA
     Kochi, IN        224.46 ms   0.0%    41.33 Mbps     238.60 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    259.60 ms   0.0%    59.18 Mbps     107.57 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      235.19 ms   N/A     64.31 Mbps     231.26 Mbps    Jio - Chennai
     Mumbai, IN       224.39 ms   0.0%    37.79 Mbps     60.15 Mbps     i3D.net - Mumbai
     Delhi, IN        306.21 ms   0.0%    30.35 Mbps     22.99 Mbps     Tata Play Fiber - New Delhi
     Los Angeles, US  7.52 ms     0.0%    136.13 Mbps    265.84 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       99.43 ms    0.0%    49.20 Mbps     481.19 Mbps    Hivelocity - Dallas, TX
     New York, US     99.26 ms    0.0%    36.86 Mbps     466.37 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      18.31 ms    N/A     101.25 Mbps    246.66 Mbps    Comcast - Seattle, WA
     Miami, US        94.49 ms    0.0%    72.57 Mbps     478.69 Mbps    AT&T - Miami, FL
     Toronto, CA      94.67 ms    0.0%    73.53 Mbps     479.49 Mbps    Rogers - Toronto, ON
     Paris, FR        197.89 ms   0.0%    41.66 Mbps     99.63 Mbps     ORANGE FRANCE - Paris
     Amsterdam, NL    156.60 ms   0.0%    75.24 Mbps     422.08 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       196.85 ms   0.0%    53.35 Mbps     372.79 Mbps    UPC Polska - Warszawa
     London, UK       197.72 ms   0.0%    63.41 Mbps     462.25 Mbps    VeloxServ Communications - London
     Frankfurt, DE    197.07 ms   0.0%    76.62 Mbps     423.92 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        FAILED
     Fujairah, AE     299.37 ms   0.0%    92.55 Mbps     121.78 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      213.40 ms   0.0%    326.53 Mbps    243.61 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  199.91 ms   2.6%    28.36 Mbps     3.48 Mbps      China Unicom 5G - ShangHai
     Nanjing, CT-CN   127.56 ms   0.0%    69.11 Mbps     220.68 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   199.57 ms   N/A     81.92 Mbps     430.47 Mbps    STC - Hong Kong
     Singapore, SG    198.50 ms   0.0%    51.80 Mbps     317.72 Mbps    i3D.net - Singapore
     Jakarta, ID      299.12 ms   0.0%    120.80 Mbps    73.33 Mbps     PT Indosat Tbk - Jakarta
     Tokyo, JP        105.76 ms   N/A     84.79 Mbps     287.01 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 93.01 Mbps
     Avg UL Speed       : 281.42 Mbps
     Total DL Data      : 3.18 GB
     Total UL Data      : 10.48 GB
     Total Data         : 13.65 GB
     Duration           : 14 min 38 sec
     System Time        : 27/04/2023 - 14:58:59 UTC
     Total Script Runs  : 1090
     Result             : https://cdn1.frocdn.ch/UGWZsCXaDpjzqzM.txt
    Virmach Tokyo (region: Asia)
     Basic System Info
     CPU Cores          : 2 @ 3693.062 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 48.9 GB (4.8 GB Used)
     Total RAM          : 2.4 GB (171.1 MB Used)
     System uptime      : 7 days, 16 hour 40 min
     Basic Network Info
     ISP                : Owl Limited
     ASN                : AS23959 Owl Limited
     ISP: Owl Limited
     Nearest          0.79 ms     13.5%   867.91 Mbps    387.63 Mbps    GSL Networks - Tokyo
     Mumbai, IN       132.61 ms   0.0%    473.88 Mbps    643.10 Mbps    i3D.net - Mumbai
     Chennai, IN      112.61 ms   N/A     538.28 Mbps    417.73 Mbps    Jio - Chennai
     Bangalore, IN    102.47 ms   0.0%    397.34 Mbps    775.06 Mbps    Bharti Airtel Ltd - Bangalore
     Singapore, SG    66.43 ms    0.0%    494.11 Mbps    792.86 Mbps    i3D.net - Singapore
     Tokyo, JP        4.80 ms     0.3%    739.43 Mbps    714.53 Mbps    Enzu.com - Tokyo
     China Unicom     FAILED
     China Telecom    FAILED
     Hong Kong, CN    101.43 ms   0.0%    388.22 Mbps    735.85 Mbps    i3D.net - Hong Kong
     Karachi, PK      147.00 ms   N/A     727.52 Mbps    330.34 Mbps    Telenor Pakistan - Karachi
     Islamabad, PK    169.67 ms   0.0%    661.12 Mbps    201.16 Mbps    JAZZ - Islamabad
     Kathmandu, NP    178.16 ms   N/A     734.03 Mbps    0.91 Mbps      Nepal Telecom - Hetauda
     Colombo, SL      105.31 ms   N/A     570.67 Mbps    0.54 Mbps      Airtel Lanka - Colombo
     Dhaka, BD        117.88 ms   N/A     628.08 Mbps    715.15 Mbps    Grameenphone Ltd - Dhaka
     Bangkok, TH      100.22 ms   0.0%    592.23 Mbps    776.50 Mbps    3BB - Bangkok
     Ho Chi Minh, VN  99.88 ms    0.0%    570.14 Mbps    681.84 Mbps    Viettel Network - Ho Chi Minh
     Hanoi, VN        107.67 ms   0.3%    699.86 Mbps    56.89 Mbps     Vietnamobile - Hanoi
     Tapei, TW        53.78 ms    N/A     939.01 Mbps    843.04 Mbps    Chunghwa Mobile - Taipei
     Jakarta, ID      141.68 ms   0.0%    89.85 Mbps     76.35 Mbps     PT Indosat Tbk - Jakarta
     Bandah Aceh, ID  175.86 ms   0.0%    7.61 Mbps      93.82 Mbps     PT Acehlink Media - Banda Aceh
     Kuala Lum, MY    69.34 ms    0.0%    889.14 Mbps    424.09 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Novosibirsk, RU  251.54 ms   0.0%    572.15 Mbps    208.82 Mbps    Megafon - Novosibirsk
     Istanbul, TR     290.50 ms   0.0%    664.66 Mbps    207.29 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 583.10 Mbps
     Avg UL Speed       : 432.55 Mbps
     Total DL Data      : 16.27 GB
     Total UL Data      : 13.20 GB
     Total Data         : 29.47 GB
     Duration           : 10 min 49 sec
     System Time        : 27/04/2023 - 14:51:31 UTC
     Total Script Runs  : 1087
     Result             : https://cdn1.frocdn.ch/rgetRaNCvSAEERm.txt
    Hosthatch Stockholm (region: India) [terminated script since result didn't get uploaded to frocdn for some reason]
     Basic System Info
     CPU Cores          : 1 @ 1999.999 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 451.1 GB (300.1 GB Used)
     Total RAM          : 466.2 MB (134.1 MB Used)
     System uptime      : 7 days, 17 hour 33 min
     Load average       : 0.29, 0.06, 0.02
     Basic Network Info
     ISP                : HostHatch
     Speedtest.net (Region: INDIA भरत)
     ISP: HostHatch
     Nearest          0.85 ms     N/A     3908.26 Mbps   5607.97 Mbps   Netprotect - Stockholm
     Mumbai           212.44 ms   0.0%    1695.16 Mbps   405.71 Mbps    Tata Teleservices Ltd - Mumbai
     Mumbai           199.47 ms   N/A     1776.93 Mbps   471.55 Mbps    Jio - Navi Mumbai
     Hyderabad        275.49 ms   0.0%    951.09 Mbps    330.81 Mbps    Vi India - Hyderabad
     Bangalore        154.12 ms   0.0%    1493.48 Mbps   546.12 Mbps    Bharti Airtel Ltd - Bangalore
     Pune             140.65 ms   0.0%    1270.08 Mbps   529.22 Mbps    Tata Play Fiber - Pune
     Chennai          203.71 ms   N/A     1947.92 Mbps   402.55 Mbps    Jio - Chennai
     Coimbatore       170.01 ms   0.0%    942.04 Mbps    239.81 Mbps    ACT FIBERNET - Coimbatore
     Kochi            159.63 ms   N/A     2040.17 Mbps   551.83 Mbps    Jio - Kochi
     Kochi            241.39 ms   0.0%    1053.16 Mbps   363.34 Mbps    Asianet Broadband - Cochin
     Trivandrum       174.26 ms   0.0%    1490.56 Mbps   492.99 Mbps    Keralavision Broadband - Trivandrum
     Kolkata          257.83 ms   0.0%    924.88 Mbps    285.73 Mbps    Alliance Broadband Services Pvt. Ltd. - Kolkata
     Nagpur           144.65 ms   0.0%    1503.24 Mbps   565.45 Mbps    RailTel Corporation of India, Ltd - Nagpur
     Delhi            164.95 ms   0.0%    1920.01 Mbps   241.06 Mbps    Extreme IX - New Delhi
     Gurgaon          166.39 ms   0.0%    1463.18 Mbps   522.17 Mbps    Bharti Airtel Ltd - Gurgaon
     Patna            314.75 ms   N/A     532.46 Mbps    198.05 Mbps    Vi India - Patna
     Avg DL Speed       : 1557.04 Mbps
     Avg UL Speed       : 734.65 Mbps
     Total DL Data      : 33.47 GB
     Total UL Data      : 15.45 GB
     Total Data         : 48.92 GB
     Duration           : 14 min 16 sec
     System Time        : 27/04/2023 - 15:48:24 UTC
    Terrahost Norway (region: China)
     Basic System Info
     CPU Model          : AMD Ryzen 5 3600 6-Core Processor
     CPU Cores          : 1 @ 3858.894 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 29.4 GB (26.3 GB Used)
     Total RAM          : 1.0 GB (128.5 MB Used)
     Total Swap         : 2.0 GB (92.7 MB Used)
     System uptime      : 160 days, 14 hour 54 min
     Load average       : 0.06, 0.03, 0.00
     Kernel             : 5.4.203-1-pve
     Basic Network Info
     ISP                : TerraHost AS
     ASN                : AS56655 TerraHost AS
     Host               : Terrahost V6net
     ISP: TerraHost
     Nearest          0.06 ms     0.0%    2519.33 Mbps   215.33 Mbps    Terrahost AS - Sandefjord
     CU - Shanghai    290.74 ms   0.0%    1539.23 Mbps   123.91 Mbps    China Unicom 5G - ShangHai
     CT - Shanghai    275.64 ms   N/A     1749.44 Mbps   4.52 Mbps      China Telecom - Shanghai
     CM - Beijing     163.43 ms   N/A     1790.80 Mbps   130.93 Mbps    China Mobile Group Beijing Co.Ltd - Beijing
     CT - Nanjing     262.23 ms   0.0%    2017.47 Mbps   194.51 Mbps    China Telecom JiangSu 5G - Nanjing
     CU - Shenyang    278.95 ms   0.3%    776.09 Mbps    41.54 Mbps     Unicom - Shenyang
     CT - Suzhou      251.69 ms   N/A     1715.08 Mbps   178.76 Mbps    China Telecom JiangSu 5G - Suzhou
     CT - Yangzhou    278.71 ms   4.7%    1689.51 Mbps   3.08 Mbps      江苏电信5G - Yangzhou
     CM - Hangzhou    296.45 ms   0.0%    1741.21 Mbps   123.75 Mbps    China Mobile Zhejiang 5G - Hangzhou
     CU - Zhengzhou   268.87 ms   N/A     1574.05 Mbps   206.19 Mbps    China Unicom HeNan 5G - Zhengzhou
     CT - Changsha    281.31 ms   18.3%   809.91 Mbps    1.44 Mbps      湖南电信5G - Changsha
     CU - Changsha    264.98 ms   N/A     152.14 Mbps    126.35 Mbps    湖南联通5G - Changsha
     CM - Chengdu     198.35 ms   0.3%    1302.61 Mbps   47.27 Mbps     China Mobile Group Sichuan - Chengdu
     CM - Kwai Chung  274.03 ms   0.0%    1474.66 Mbps   117.66 Mbps    China Mobile Hong Kong - Kwai Chung
     CM - Hong Kong   271.67 ms   0.0%    1442.54 Mbps   121.59 Mbps    China Mobile Hong Kong Boardband - Hong Kong
     Hong Kong        226.81 ms   0.0%    893.55 Mbps    215.35 Mbps    HKIX - Hong Kong
     Hong Kong        232.17 ms   N/A     1809.11 Mbps   84.62 Mbps     fdcservers.net - Hong Kong
     Avg DL Speed       : 1470.39 Mbps
     Avg UL Speed       : 113.93 Mbps
     Total DL Data      : 30.60 GB
     Total UL Data      : 2.82 GB
     Total Data         : 33.42 GB
     Duration           : 9 min 54 sec
     System Time        : 27/04/2023 - 15:52:37 UTC
     Total Script Runs  : 1114
     Result             : https://cdn1.frocdn.ch/OHQwE6JnWbe7FAT.txt
    Hosthatch New York (region: Iran)
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
     CPU Cores          : 1 @ 2999.998 MHz
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (170.4 MB Used)
     System uptime      : 4 days, 20 hour 25 min
     Basic Network Info
     ISP                : Siberfy Lahore
     Host               : Prinode AB
     ISP: HostHatch
     Nearest          0.75 ms     0.0%    4468.84 Mbps   2417.33 Mbps   GSL Networks - New York, NY
     Tehran           150.16 ms   2.7%    189.42 Mbps    32.74 Mbps     MCI
     Tehran           164.77 ms   0.0%    1354.07 Mbps   439.88 Mbps    Irancell - Tehran
     Tehran           154.59 ms   0.0%    1015.09 Mbps   12.69 Mbps     HostIran.net - Tehran
     Shiraz           181.04 ms   0.0%    3377.70 Mbps   326.53 Mbps    Irancell - Shiraz
     Isfahan          166.64 ms   0.0%    1552.79 Mbps   499.99 Mbps    MCI
     Tabriz           173.35 ms   0.0%    206.72 Mbps    199.19 Mbps    Maxnet - Tabriz
     Avg DL Speed       : 1737.80 Mbps
     Avg UL Speed       : 561.19 Mbps
     Total DL Data      : 18.95 GB
     Total UL Data      : 6.03 GB
     Total Data         : 24.97 GB
     Duration           : 3 min 46 sec
     System Time        : 27/04/2023 - 15:53:47 UTC
     Total Script Runs  : 1115
     Result             : https://cdn1.frocdn.ch/PBPeeK8N7yXEzPz.txt
  • edited April 2023
    >  Basic System Info
    >  AES-NI             : ✔ Enabled
    >  Basic Network Info
    >  Location           : Los Angeles, California-CA, United States
    >  Avg UL Speed       :  Mbps
    >  Total DL Data      :  GB
    >  Total UL Data      :  GB
    >  Total Data         :  GB
    Wow, I am seeing this for the first time!
    Thank you for reporting, I'll take a look!!
    Edit
    @chimichurri thank you for the tests in all regions, I'll pin it OP when I'm on PC.
    Thanked by (2)carlin0 Not_Oles
  • Looks there is some issue with frocdn, links are not opening.
  • BochiBochi OG
    edited April 2023
    Minor side note, as you are listing the options to pipe the output from curl or wget.
    Let's say my environment doesn't have wget installed, so I take curl to get the script, then execution will fail due to the wget dependency.
    At the same time a report is generated anyway, which doesn't seem to make much sense. :)
    # curl -sL network-speed.xyz | bash
    Error: wget command not found.
     Result             : https://cdn1.frocdn.ch/0s4F1VXvCJz6YMf.txt
    # curl -sL network-speed.xyz | grep wget
        local net_type="$(wget -qO- http://ip6.me/api/ | cut -d, -f1)"
        local net_ip="$(wget -qO- http://ip6.me/api/ | cut -d, -f2)"
        local response=$(wget -qO- http://ip-api.com/json/$net_ip)
        local response_ipv4=$(wget -qO- ipinfo.io)
            wget --no-check-certificate -q -T10 -O speedtest.tgz ${url1}
                wget --no-check-certificate -q -T10 -O speedtest.tgz ${url2}
        echo " Global Speedtest   : $(_red "wget -qO- network-speed.xyz | bash")"
        echo " Region Speedtest   : $(_red "wget -qO- network-speed.xyz | bash -s -- -r <region>")"
        local counter=$(wget -qO- https://counter.network-speed.xyz/)
        ! _exists "wget" && _red "Error: wget command not found.\n" && exit 1
    And is there a switch to disable uploading of the results to your CDN?
    /EDIT/
    As I looked into it now, answering my own question: no, there is no switch to disable the upload.
    And while I was there I was wondering what "counter()" is supposed to do, so I checked the endpoint. So sorry for messing your statistics up, as I called it quite a few times... :/
    However, why does it always increase by 2 (with the occasional 1 or 3 increment)? It certainly is not really counting the runs that way.
  • edited April 2023
    Nice catch! I'll be working on fixes during the weekend. But usually wget is installed by default on Linux?
    No, as of now all results are uploaded to FroCDN (by Advin). But I'll consider adding a switch if it's really needed.
  • Well done @sh97 👍
  • No separate thread was opened so sharing bench here.
    HH SG,
     Basic System Info
     CPU Cores          : 2 @ 2999.996 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 36.6 GB (16.6 GB Used)
     Total RAM          : 7.8 GB (2.4 GB Used)
     System uptime      : 16 days, 9 hour 35 min
     Load average       : 0.55, 0.72, 0.77
     Basic Network Info
     ISP                : HostHatch
     Host               : HostHatch, LLC
     ISP: HostHatch
     Nearest          0.30 ms     0.0%    5860.16 Mbps   4883.15 Mbps   PT FirstMedia - Singapore
     Mumbai, IN       54.91 ms    0.0%    3482.33 Mbps   1324.60 Mbps   i3D.net - Mumbai
     Chennai, IN      34.17 ms    N/A     4623.09 Mbps   2434.97 Mbps   Jio - Chennai
     Bangalore, IN    156.59 ms   0.0%    4878.96 Mbps   501.30 Mbps    Bharti Airtel Ltd - Bangalore
     Singapore, SG    1.37 ms     0.0%    6966.38 Mbps   6754.14 Mbps   i3D.net - Singapore
     Tokyo, JP        76.42 ms    0.3%    4314.27 Mbps   1020.95 Mbps   Enzu.com - Tokyo
     China Unicom     221.75 ms   24.7%   1469.35 Mbps   1.57 Mbps      China Unicom 5G - ShangHai
     Hong Kong, CN    36.72 ms    0.0%    4569.08 Mbps   2083.90 Mbps   i3D.net - Hong Kong
     Karachi, PK      87.16 ms    N/A     4475.59 Mbps   550.27 Mbps    Telenor Pakistan - Karachi
     Islamabad, PK    94.75 ms    0.0%    916.06 Mbps    788.75 Mbps    JAZZ - Islamabad
     Kathmandu, NP    267.69 ms   0.0%    929.72 Mbps    291.33 Mbps    Nepal Telecom - Hetauda
     Colombo, SL      35.13 ms    N/A     5948.67 Mbps   1364.83 Mbps   Airtel Lanka - Colombo
     Dhaka, BD        46.59 ms    N/A     5466.59 Mbps   1804.19 Mbps   Grameenphone Ltd - Dhaka
     Bangkok, TH      23.61 ms    0.0%    3184.18 Mbps   2712.58 Mbps   3BB - Bangkok
     Ho Chi Minh, VN  31.57 ms    0.0%    6038.54 Mbps   2979.91 Mbps   Viettel Network - Ho Chi Minh
     Hanoi, VN        57.04 ms    2.7%    889.90 Mbps    364.05 Mbps    Vietnamobile - Hanoi
     Tapei, TW        141.68 ms   N/A     2548.42 Mbps   413.86 Mbps    Chunghwa Mobile - Taipei
     Jakarta, ID      12.64 ms    0.0%    5864.73 Mbps   3543.11 Mbps   PT Indosat Tbk - Jakarta
     Bandah Aceh, ID  47.99 ms    0.0%    773.25 Mbps    639.59 Mbps    PT Acehlink Media - Banda Aceh
     Kuala Lum, MY    14.34 ms    0.0%    3649.64 Mbps   5471.65 Mbps   Telekom Malaysia Berhad - Kuala Lumpur
     Novosibirsk, RU  227.85 ms   0.0%    3498.76 Mbps   350.75 Mbps    Megafon - Novosibirsk
     Istanbul, TR     208.00 ms   0.0%    3066.25 Mbps   397.89 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 3791.55 Mbps
     Avg UL Speed       : 1848.98 Mbps
     Total DL Data      : 105.59 GB
     Total UL Data      : 49.96 GB
     Total Data         : 155.55 GB
     Duration           : 10 min 24 sec
     System Time        : 27/04/2023 - 19:32:47 IST
     Total Script Runs  : 1082
    Thanked by (1)sh97
  • @dosai do you know if HH uses Leaseweb as upstream? I noticed they have some routing issues to Asia/India/Middle East (as above I see high ping to Airtel BLR) with my Greencloud VPS. Host Universal seems to have a better routing it seems.
  • Advin (Host Universal?) SG
     Basic System Info
     CPU Model          : AMD EPYC Processor
     CPU Cores          : 4 @ 3792.874 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 116.2 GB (5.0 GB Used)
     Total RAM          : 15.6 GB (305.2 MB Used)
     System uptime      : 7 days, 2 hour 44 min
     Load average       : 0.22, 0.22, 0.31
     Basic Network Info
     ISP                : Advin Services LLC
     ASN                : AS206216 Advin Services LLC
     Host               : Pal Tech Software LLC
     Location (IPv4)    : Singapore, Singapore, SG
     ISP: Advin Services LLC
     Nearest          0.21 ms     0.0%    936.71 Mbps    930.60 Mbps    PT FirstMedia - Singapore
     Mumbai           55.52 ms    0.0%    945.25 Mbps    937.68 Mbps    Tata Teleservices Ltd - Mumbai
     Mumbai           61.64 ms    N/A     950.20 Mbps    920.79 Mbps    Jio - Navi Mumbai
     Hyderabad        45.20 ms    0.0%    947.38 Mbps    893.24 Mbps    Vi India - Hyderabad
     Bangalore        37.64 ms    0.0%    944.00 Mbps    932.37 Mbps    Bharti Airtel Ltd - Bangalore
     Pune             50.92 ms    0.0%    943.30 Mbps    915.04 Mbps    Tata Play Fiber - Pune
     Chennai          34.43 ms    N/A     943.57 Mbps    913.30 Mbps    Jio - Chennai
     Coimbatore       42.47 ms    0.0%    939.57 Mbps    738.04 Mbps    ACT FIBERNET - Coimbatore
     Kochi            46.10 ms    N/A     876.36 Mbps    938.46 Mbps    Jio - Kochi
     Kochi            47.83 ms    0.0%    943.79 Mbps    703.66 Mbps    Asianet Broadband - Cochin
     Trivandrum       66.14 ms    0.0%    937.39 Mbps    233.71 Mbps    Keralavision Broadband - Trivandrum
     Kolkata          78.89 ms    0.0%    942.31 Mbps    902.47 Mbps    Alliance Broadband Services Pvt. Ltd. - Kolkata
     Nagpur           64.06 ms    0.0%    944.12 Mbps    690.78 Mbps    RailTel Corporation of India, Ltd - Nagpur
     Delhi            69.97 ms    0.0%    947.17 Mbps    903.02 Mbps    Extreme IX - New Delhi
     Gurgaon          69.43 ms    0.0%    950.22 Mbps    915.99 Mbps    Bharti Airtel Ltd - Gurgaon
     Patna            104.39 ms   N/A     945.25 Mbps    386.11 Mbps    Vi India - Patna
     Avg DL Speed       : 939.78 Mbps
     Avg UL Speed       : 803.45 Mbps
     Total DL Data      : 19.11 GB
     Total UL Data      : 16.56 GB
     Total Data         : 35.67 GB
     Duration           : 6 min 57 sec
     System Time        : 27/04/2023 - 16:45:16 UTC
     Total Script Runs  : 1124
     Result             : https://cdn1.frocdn.ch/4pFlJSkgCGP3Fe1.txt
    root@sgp2-advin-sgp:~#
     Nearest          0.18 ms     0.0%    942.73 Mbps    939.52 Mbps    PT FirstMedia - Singapore
     Mumbai, IN       53.40 ms    0.0%    950.28 Mbps    831.27 Mbps    i3D.net - Mumbai
     Chennai, IN      33.71 ms    N/A     943.64 Mbps    863.58 Mbps    Jio - Chennai
     Bangalore, IN    37.54 ms    0.0%    688.25 Mbps    936.17 Mbps    Bharti Airtel Ltd - Bangalore
     Singapore, SG    1.36 ms     0.0%    943.54 Mbps    895.91 Mbps    i3D.net - Singapore
     Tokyo, JP        74.76 ms    0.4%    771.83 Mbps    879.59 Mbps    Enzu.com - Tokyo
     China Unicom     204.44 ms   0.0%    795.58 Mbps    357.36 Mbps    China Unicom 5G - ShangHai
     Hong Kong, CN    36.76 ms    0.0%    940.69 Mbps    878.13 Mbps    i3D.net - Hong Kong
     Karachi, PK      87.07 ms    N/A     948.85 Mbps    546.70 Mbps    Telenor Pakistan - Karachi
     Islamabad, PK    94.73 ms    1.3%    895.32 Mbps    4.26 Mbps      JAZZ - Islamabad
     Kathmandu, NP    81.54 ms    N/A     939.70 Mbps    880.61 Mbps    Nepal Telecom - Hetauda
     Colombo, SL      35.08 ms    N/A     941.72 Mbps    151.72 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        45.81 ms    N/A     943.02 Mbps    939.07 Mbps    Grameenphone Ltd - Dhaka
     Bangkok, TH      24.55 ms    0.0%    940.04 Mbps    911.04 Mbps    3BB - Bangkok
     Ho Chi Minh, VN  31.51 ms    0.0%    943.64 Mbps    813.42 Mbps    Viettel Network - Ho Chi Minh
     Hanoi, VN        56.32 ms    0.0%    771.08 Mbps    864.02 Mbps    Vietnamobile - Hanoi
     Tapei, TW        50.87 ms    N/A     689.95 Mbps    945.82 Mbps    Chunghwa Mobile - Taipei
     Jakarta, ID      13.28 ms    0.0%    947.33 Mbps    946.09 Mbps    PT Indosat Tbk - Jakarta
     Bandah Aceh, ID  47.13 ms    0.0%    733.67 Mbps    870.49 Mbps    PT Acehlink Media - Banda Aceh
     Kuala Lum, MY    14.39 ms    0.0%    944.13 Mbps    938.21 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Novosibirsk, RU  241.80 ms   0.0%    910.44 Mbps    190.80 Mbps    Megafon - Novosibirsk
     Istanbul, TR     182.71 ms   0.0%    832.40 Mbps    465.83 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 879.90 Mbps
     Avg UL Speed       : 729.52 Mbps
     Total DL Data      : 25.49 GB
     Total UL Data      : 21.44 GB
     Total Data         : 46.93 GB
     Duration           : 10 min 26 sec
     System Time        : 27/04/2023 - 17:14:20 UTC
     Total Script Runs  : 1126
    No, they use Host Universal. https://bgp.tools/prefix/103.167.150.0/24#connectivity
  • IH FRA,
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz
     CPU Cores          : 2 @ 3407.982 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 39.8 GB (7.5 GB Used)
     Total RAM          : 976.2 MB (493.5 MB Used)
     System uptime      : 153 days, 16 hour 1 min
     Load average       : 0.35, 0.22, 0.10
     Kernel             : 5.10.0-8-amd64
     Basic Network Info
     ISP                : Clouvider Limited
     ASN                : AS62240 Clouvider
     Host               : Clouvider Limited
     ISP: Clouvider Limited
     Nearest          11.89 ms    0.0%    1366.17 Mbps   3529.55 Mbps   Lightning Fibre Ltd - London
     London, UK       11.34 ms    4.9%    3443.36 Mbps   3984.08 Mbps   VeloxServ Communications - London
     Edinburgh, UK    27.41 ms    N/A     2749.83 Mbps   2963.87 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       24.41 ms    0.0%    4978.14 Mbps   3240.08 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.17 ms     3.8%    3585.67 Mbps   4486.56 Mbps   GSL Networks - Amsterdam
     Paris, FR        19.99 ms    0.0%    2068.27 Mbps   3718.07 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    15.56 ms    0.0%    5576.81 Mbps   5292.60 Mbps   GSL Networks - Marseille
     Madrid, ES       26.79 ms    0.0%    621.02 Mbps    2967.95 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    21.76 ms    0.9%    1481.30 Mbps   1065.62 Mbps   Adamo - Barcelona
     Lisbon, PT       39.00 ms    N/A     2164.09 Mbps   578.51 Mbps    fdcservers.net - Lisbon
     Rome, IT         23.68 ms    0.0%    2018.11 Mbps   3737.00 Mbps   TIM SpA - Rome
     Zurich, CH       7.83 ms     1.6%    2853.51 Mbps   2568.61 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.70 ms     0.0%    2779.68 Mbps   4371.91 Mbps   23M GmbH - Frankfurt Am Main
     Berlin, DE       8.28 ms     1.0%    1693.45 Mbps   3835.08 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       11.98 ms    0.0%    2572.94 Mbps   6827.66 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     18.35 ms    0.0%    987.84 Mbps    3920.73 Mbps   Yettel Hungary - Budapest
     Gdansk, PL       25.10 ms    1.4%    1633.92 Mbps   3102.18 Mbps   Orange Polska S.A. - Gdansk
     Warsaw, PL       19.56 ms    0.5%    1180.56 Mbps   3542.26 Mbps   UPC Polska - Warszawa
     Lviv, UA         25.03 ms    0.0%    4592.55 Mbps   3267.91 Mbps   Kyivstar - Lviv
     Kyiv, UA         27.45 ms    0.0%    2862.19 Mbps   2814.66 Mbps   o3 - Kyiv
     Minsk, BY        22.42 ms    7.3%    2937.97 Mbps   2741.66 Mbps   A1 - Minsk
     Bucharest, RO    31.79 ms    0.0%    3611.41 Mbps   2870.30 Mbps   Orange Romania Communications - Bucharest
     Helsinki, FI     36.46 ms    0.0%    1750.30 Mbps   2060.45 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.58 ms    0.0%    1100.13 Mbps   2716.78 Mbps   i3D.net - Stockholm
     Oslo, NO         22.56 ms    0.0%    1685.31 Mbps   3552.12 Mbps   Speedtest.net - Oslo
     Moscow, RU       42.90 ms    5.0%    2591.25 Mbps   1924.10 Mbps   MTS - Moscow
     Moscow, RU       39.06 ms    0.7%    1699.14 Mbps   2016.42 Mbps   Rostelecom - Moscow
     Istanbul, TR     45.55 ms    0.4%    1903.55 Mbps   1734.37 Mbps   Turkcell - Istanbul
     Antalya, TR      45.74 ms    0.0%    937.66 Mbps    1562.75 Mbps   Vodafone TR - Antalya
     Avg DL Speed       : 2394.00 Mbps
     Avg UL Speed       : 3137.73 Mbps
     Total DL Data      : 87.38 GB
     Total UL Data      : 112.74 GB
     Total Data         : 200.12 GB
     Duration           : 11 min 50 sec
     System Time        : 28/04/2023 - 16:42:43 IST
     Total Script Runs  : 1690
    Thanked by (1)sh97
  • Vultr Free Frankfurt
    Interesting note - upload bandwidth outside EU throttled to ~350Mbps
    ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Version            : v2023.04.12
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Basic System Info
     CPU Model          : Intel Xeon Processor (Skylake, IBRS)
     CPU Cores          : 1 @ 2593.904 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 9.3 GB (4.7 GB Used)
     Total RAM          : 473.3 MB (77.0 MB Used)
     Total Swap         : 1024.0 MB (20.9 MB Used)
     System uptime      : 33 days, 15 hour 48 min
     Arch               : x86_64 (64 Bit)
     Virtualization     : MICROSOFT
     Basic Network Info
     Primary Network    : IPv6
     ISP                : The Constant Company
     ASN                : AS20473 The Constant Company, LLC
     Host               : Vultr Holdings, LLC
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Choopa, LLC
     Nearest          0.30 ms     N/A     12892.43 Mbps  8328.53 Mbps   Netprotect - Frankfurt
     London, UK       15.06 ms    0.0%    4164.32 Mbps   3686.27 Mbps   VeloxServ Communications - London
     Edinburgh, UK    25.12 ms    N/A     6488.69 Mbps   2579.85 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       21.99 ms    0.0%    7531.65 Mbps   3023.78 Mbps   Three Ireland - Dublin
     Amsterdam, NL    99.16 ms    0.0%    3551.88 Mbps   769.98 Mbps    GSL Networks - Amsterdam
     Paris, FR        10.99 ms    0.0%    7146.16 Mbps   5688.89 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    15.84 ms    0.0%    5301.13 Mbps   5061.16 Mbps   GSL Networks - Marseille
     Madrid, ES       26.62 ms    0.0%    6783.41 Mbps   3558.80 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    22.21 ms    0.0%    8822.15 Mbps   2952.35 Mbps   Adamo - Barcelona
     Lisbon, PT       43.00 ms    N/A     7113.47 Mbps   1468.82 Mbps   fdcservers.net - Lisbon
     Rome, IT         17.48 ms    0.0%    6186.99 Mbps   3802.18 Mbps   TIM SpA - Rome
     Zurich, CH       8.03 ms     0.0%    10211.94 Mbps  6707.08 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.73 ms     0.0%    8951.02 Mbps   6750.37 Mbps   23M GmbH - Frankfurt Am Main
     Berlin, DE       8.15 ms             7251.85 Mbps   FAILED         Misaka Network, Inc. - Berlin
     Vienna, AT       11.90 ms    0.0%    8256.68 Mbps   5267.58 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     18.48 ms    0.0%    8283.04 Mbps   3981.39 Mbps   Yettel Hungary - Budapest
     Gdansk, PL       24.54 ms    0.0%    8025.93 Mbps   2758.56 Mbps   Orange Polska S.A. - Gdansk
     Warsaw, PL       19.20 ms    0.0%    8061.77 Mbps   3529.99 Mbps   UPC Polska - Warszawa
     Lviv, UA         22.64 ms    0.0%    7392.70 Mbps   3000.25 Mbps   Kyivstar - Lviv
     Kyiv, UA         26.86 ms    0.0%    8671.27 Mbps   1310.86 Mbps   o3 - Kyiv
     Minsk, BY        27.40 ms    0.0%    4714.39 Mbps   2439.65 Mbps   A1 - Minsk
     Bucharest, RO    27.59 ms    0.0%    7665.02 Mbps   3056.90 Mbps   Orange Romania Communications - Bucharest
     Helsinki, FI     41.63 ms    0.0%    11094.17 Mbps  1563.79 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.48 ms    0.0%    10171.34 Mbps  2127.96 Mbps   i3D.net - Stockholm
     Oslo, NO         22.75 ms    0.0%    5648.61 Mbps   2949.78 Mbps   Speedtest.net - Oslo
     Moscow, RU       43.15 ms    0.0%    5239.50 Mbps   2292.88 Mbps   MTS - Moscow
     Moscow, RU       41.56 ms    0.0%    4068.12 Mbps   2546.82 Mbps   Rostelecom - Moscow
     Istanbul, TR     43.72 ms    0.0%    6205.74 Mbps   2000.88 Mbps   Turkcell - Istanbul
     Antalya, TR      46.59 ms    0.0%    940.87 Mbps    1241.43 Mbps   Vodafone TR - Antalya
     Avg DL Speed       : 7132.31 Mbps
     Avg UL Speed       : 3256.80 Mbps
     Total DL Data      : 280.80 GB
     Total UL Data      : 124.20 GB
     Total Data         : 405.00 GB
     Duration           : 12 min 19 sec
     System Time        : 12/04/2023 - 15:09:35 IST
     Total Script Runs  : 884
  • BuyVM 1 Core AMD 2GB RAM - 7 USD (2023)
     Basic System Info
     CPU Model          : AMD Ryzen 9 3900X 12-Core Processor
     CPU Cores          : 1 @ 3792.874 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 39.3 GB (1.7 GB Used)
     Total RAM          : 1.9 GB (71.0 MB Used)
     System uptime      : 0 days, 0 hour 33 min
     Load average       : 0.00, 0.06, 0.07
     Kernel             : 5.4.0-148-generic
     Virtualization     : KVM
     Basic Network Info
     ISP                : FranTech Solutions
     ASN                : AS53667 FranTech Solutions
     Host               : FranTech Solutions
     Location (IPv4)    : Bissen, Mersch, LU
     ISP: FranTech Solutions
     Nearest          1.14 ms     0.0%    936.22 Mbps    938.92 Mbps    Broadcasting Center Europe SA - Luxembourg
     London, UK       13.22 ms    0.0%    958.78 Mbps    1027.05 Mbps   VeloxServ Communications - London
     Edinburgh, UK    28.67 ms    N/A     676.04 Mbps    1030.22 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       20.75 ms    0.0%    977.23 Mbps    1029.64 Mbps   Three Ireland - Dublin
     Amsterdam, NL    11.40 ms    0.0%    961.54 Mbps    1023.42 Mbps   GSL Networks - Amsterdam
     Paris, FR        12.21 ms    0.0%    692.49 Mbps    1028.83 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    19.50 ms    0.0%    980.11 Mbps    1028.65 Mbps   GSL Networks - Marseille
     Madrid, ES       28.87 ms    0.0%    537.53 Mbps    1037.25 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    27.40 ms    0.0%    446.99 Mbps    1032.98 Mbps   Adamo - Barcelona
     Lisbon, PT       37.20 ms    N/A     340.94 Mbps    1035.36 Mbps   fdcservers.net - Lisbon
     Rome, IT         26.00 ms    0.0%    949.78 Mbps    1045.48 Mbps   TIM SpA - Rome
     Zurich, CH       10.79 ms    0.0%    836.11 Mbps    1027.66 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    5.34 ms     0.0%    948.72 Mbps    1023.06 Mbps   23M GmbH - Frankfurt Am Main
     Berlin, DE       17.85 ms    0.0%    965.12 Mbps    1024.07 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       16.04 ms    0.0%    886.16 Mbps    1030.59 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     19.80 ms    0.0%    827.52 Mbps    1028.84 Mbps   Yettel Hungary - Budapest
     Gdansk, PL       29.00 ms    0.0%    732.17 Mbps    1023.35 Mbps   Orange Polska S.A. - Gdansk
     Warsaw, PL       25.50 ms    0.0%    730.67 Mbps    1027.95 Mbps   UPC Polska - Warszawa
     Lviv, UA         41.54 ms    0.0%    951.59 Mbps    1034.85 Mbps   Kyivstar - Lviv
     Kyiv, UA         35.02 ms    0.0%    738.04 Mbps    1039.88 Mbps   o3 - Kyiv
     Minsk, BY        56.33 ms    0.0%    982.16 Mbps    1032.54 Mbps   A1 - Minsk
     Bucharest, RO    31.07 ms    0.0%    825.65 Mbps    1034.13 Mbps   Orange Romania Communications - Bucharest
     Helsinki, FI     31.17 ms    0.0%    685.17 Mbps    1032.13 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    27.70 ms    0.0%    644.54 Mbps    1030.65 Mbps   i3D.net - Stockholm
     Oslo, NO         27.61 ms    0.0%    619.09 Mbps    1027.48 Mbps   Speedtest.net - Oslo
     Moscow, RU       46.32 ms    0.0%    974.98 Mbps    1038.08 Mbps   MTS - Moscow
     Moscow, RU       37.52 ms    0.0%    684.97 Mbps    1045.50 Mbps   Rostelecom - Moscow
     Istanbul, TR     48.21 ms    0.0%    930.79 Mbps    1030.75 Mbps   Turkcell - Istanbul
     Antalya, TR      55.65 ms    0.0%    939.48 Mbps    930.41 Mbps    Vodafone TR - Antalya
     Avg DL Speed       : 805.54 Mbps
     Avg UL Speed       : 1024.82 Mbps
     Total DL Data      : 27.88 GB
     Total UL Data      : 43.01 GB
     Total Data         : 70.89 GB
     System Time        : 28/04/2023 - 00:23:14 EDT
     Total Script Runs  : 1668
     Result             : https://cdn1.frocdn.ch/Z4F1MlnFEZedTnT.txt
    Thanked by (1)sh97
  • Oracle ARM,
     Basic System Info
     CPU Cores          : 4
     AES-NI             : ✔ Enabled
     Total Disk         : 96.8 GB (15.3 GB Used)
     Total RAM          : 23.4 GB (3.5 GB Used)
     Total Swap         : 5.9 GB (1.5 GB Used)
     System uptime      : 384 days, 23 hour 30 min
     Load average       : 0.00, 0.02, 0.00
     Kernel             : 5.13.0-1018-oracle
     Basic Network Info
     Host               : Oracle Corporation
     ISP: Oracle Cloud
     Nearest          0.59 ms     0.0%    3775.72 Mbps   3957.46 Mbps   ACT Fibernet - Hyderabad
     Mumbai           12.58 ms    0.0%    3761.10 Mbps   3921.83 Mbps   Tata Teleservices Ltd - Mumbai
     Mumbai           27.01 ms    N/A     3957.91 Mbps   3183.29 Mbps   Jio - Navi Mumbai
     Hyderabad        FAILED
     Bangalore        18.49 ms    0.0%    3915.09 Mbps   2981.14 Mbps   Bharti Airtel Ltd - Bangalore
     Pune             15.69 ms    0.0%    4005.86 Mbps   3674.70 Mbps   Tata Play Fiber - Pune
     Chennai          16.32 ms    N/A     4048.79 Mbps   3393.57 Mbps   Jio - Chennai
     Coimbatore       24.56 ms    0.0%    921.38 Mbps    919.56 Mbps    ACT FIBERNET - Coimbatore
     Kochi            26.10 ms    N/A     3997.36 Mbps   3286.62 Mbps   Jio - Kochi
     Kochi            23.88 ms    0.0%    4009.46 Mbps   3765.37 Mbps   Asianet Broadband - Cochin
     Trivandrum       59.53 ms    0.0%    3481.18 Mbps   1380.28 Mbps   Keralavision Broadband - Trivandrum
     Kolkata          30.55 ms    0.0%    3952.04 Mbps   2689.52 Mbps   Alliance Broadband Services Pvt. Ltd. - Kolkata
     Nagpur           26.34 ms    0.0%    3746.62 Mbps   3065.15 Mbps   RailTel Corporation of India, Ltd - Nagpur
     Delhi            41.81 ms    0.0%    3018.32 Mbps   2031.25 Mbps   Extreme IX - New Delhi
     Gurgaon          65.84 ms    0.0%    3943.40 Mbps   1441.55 Mbps   Bharti Airtel Ltd - Gurgaon
     Patna            85.17 ms    N/A     4014.47 Mbps   834.68 Mbps    Vi India - Patna
     Avg DL Speed       : 3636.59 Mbps
     Avg UL Speed       : 2701.74 Mbps
     Total DL Data      : 79.40 GB
     Total UL Data      : 48.00 GB
     Total Data         : 127.40 GB
     Duration           : 6 min 41 sec
     System Time        : 28/04/2023 - 19:24:32 IST
     Total Script Runs  : 1696
    Thanked by (1)sh97
  • Hostaris 1 Core AMD 2GB RAM - 4 GBP | UK (Kettering) |
     Basic System Info
     CPU Cores          : 1 @ 3693.062 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 19.3 GB (2.8 GB Used)
     Total RAM          : 1.9 GB (210.6 MB Used)
     System uptime      : 0 days, 1 hour 29 min
     Load average       : 0.05, 0.12, 0.27
     Basic Network Info
     Primary Network    : IPv4
     ISP                : Hostaris Limited
     ASN                : AS199765 Hostaris Limited
     Host               : Ipxo
     Speedtest.net (Region: EUROPE)
     ISP: Sprint
     Nearest          4.58 ms     0.0%    786.03 Mbps    931.39 Mbps    Lit Fibre Group Ltd. - Slough
     London, UK       3.63 ms     0.0%    895.98 Mbps    928.16 Mbps    VeloxServ Communications - London
     Edinburgh, UK    18.57 ms    N/A     712.76 Mbps    909.78 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       12.67 ms    0.6%    910.31 Mbps    909.43 Mbps    Three Ireland - Dublin
     Amsterdam, NL    10.86 ms    0.0%    897.96 Mbps    883.10 Mbps    GSL Networks - Amsterdam
     Paris, FR        16.12 ms    0.0%    779.62 Mbps    891.06 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    28.73 ms    0.0%    925.95 Mbps    859.90 Mbps    GSL Networks - Marseille
     Madrid, ES       37.75 ms    0.0%    628.83 Mbps    869.42 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    33.90 ms    0.0%    588.68 Mbps    781.07 Mbps    Adamo - Barcelona
     Lisbon, PT       53.14 ms    N/A     581.28 Mbps    659.41 Mbps    fdcservers.net - Lisbon
     Rome, IT         31.02 ms    0.0%    722.29 Mbps    866.98 Mbps    TIM SpA - Rome
     Zurich, CH       22.40 ms    0.0%    718.71 Mbps    877.96 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    16.45 ms    0.0%    853.94 Mbps    706.41 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       33.23 ms    0.0%    928.75 Mbps    873.54 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       29.21 ms    0.0%    642.34 Mbps    825.54 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     36.13 ms    N/A     718.06 Mbps    803.02 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       35.58 ms    0.0%    719.60 Mbps    777.75 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       34.35 ms    0.0%    638.23 Mbps    768.84 Mbps    UPC Polska - Warszawa
     Lviv, UA         44.29 ms    0.0%    851.69 Mbps    834.66 Mbps    Kyivstar - Lviv
     Kyiv, UA         44.99 ms    0.0%    704.37 Mbps    708.40 Mbps    o3 - Kyiv
     Minsk, BY        38.11 ms    0.0%    930.45 Mbps    724.53 Mbps    A1 - Minsk
     Bucharest, RO    51.18 ms    0.0%    690.36 Mbps    747.76 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     37.30 ms    0.0%    693.54 Mbps    800.44 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    34.76 ms    0.4%    530.44 Mbps    795.55 Mbps    i3D.net - Stockholm
     Oslo, NO         37.47 ms    0.0%    68.54 Mbps     652.56 Mbps    Speedtest.net - Oslo
     Moscow, RU       54.01 ms    0.0%    846.06 Mbps    644.75 Mbps    MTS - Moscow
     Moscow, RU       49.77 ms    0.0%    19.53 Mbps     629.42 Mbps    Rostelecom - Moscow
     Istanbul, TR     54.42 ms    0.0%    201.74 Mbps    655.14 Mbps    Turkcell - Istanbul
     Antalya, TR      60.14 ms    0.0%    101.02 Mbps    515.71 Mbps    Vodafone TR - Antalya
     Avg DL Speed       : 665.07 Mbps
     Avg UL Speed       : 787.29 Mbps
     Total DL Data      : 25.31 GB
     Total UL Data      : 27.24 GB
     Total Data         : 52.55 GB
     Duration           : 11 min 59 sec
     System Time        : 29/04/2023 - 22:21:05 WIB
     Total Script Runs  : 1758
     Result             : https://cdn1.frocdn.ch/b1eNjI8zc6NxSBX.txt
    Thanked by (1)sh97
  • GreenCloud BudgetKVM-3, SG -> India
     Version            : v2023.05.01
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
     CPU Cores          : 4 @ 2199.986 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 55.1 GB (31.5 GB Used)
     Total RAM          : 7.8 GB (554.9 MB Used)
     Total Swap         : 4.0 GB (0 Used)
     System uptime      : 28 days, 8 hour 24 min
     Load average       : 0.29, 0.17, 0.11
     Kernel             : 5.15.0-69-generic
     Basic Network Info
     ISP                : Leaseweb Singapore
     ASN                : AS59253 Leaseweb Asia Pacific pte. ltd.
     Host               : Leaseweb Asia Pacific pte. ltd
     ISP: Leaseweb Asia
     Nearest          0.75 ms     0.0%    6775.96 Mbps   8516.61 Mbps   MyRepublic Singapore - Singapore
     Mumbai, MH       63.20 ms    0.0%    3259.50 Mbps   758.80 Mbps    Tata Teleservices Ltd - Mumbai
     Mumbai. MH       60.96 ms    N/A     2995.42 Mbps   928.88 Mbps    Jio - Mumbai
     Pune, MH         50.62 ms    0.0%    1821.86 Mbps   1474.35 Mbps   Tata Play Fiber - Pune
     Hyderabad, AP-TL 178.58 ms   N/A     87.63 Mbps     450.18 Mbps    Airtel Broadband - Hyderabad
     Bangalore, KA    189.61 ms   0.0%    109.44 Mbps    524.17 Mbps    Bharti Airtel Ltd - Bangalore
     Bangalore, KA    41.68 ms    0.0%    2171.25 Mbps   2077.81 Mbps   ACT FIBERNET - Bangalore
     Mangalore, KA    46.47 ms    0.0%    3525.94 Mbps   1446.05 Mbps   BBNL - Mangalore
     Chennai, TN      33.76 ms    N/A     2535.61 Mbps   1925.40 Mbps   Jio - Chennai
     Chennai, TN      35.00 ms    0.0%    1701.23 Mbps   960.21 Mbps    Extreme IX - Chennai
     Coimbatore, TN   176.54 ms   0.0%    32.81 Mbps     417.11 Mbps    Airtel Broadband - Coimbatore
     Madurai, TN      160.90 ms   0.0%    716.40 Mbps    385.53 Mbps    Vi India - Madurai
     Kochi, KL        46.48 ms    N/A     983.64 Mbps    1182.03 Mbps   Jio - Kochi
     Kochi, KL        50.31 ms    0.0%    3014.19 Mbps   1749.98 Mbps   Asianet Broadband - Cochin
     Trivandrum, KL   78.46 ms    0.0%    1093.56 Mbps   1106.21 Mbps   Keralavision Broadband - Trivandrum
     Kolkata, WB      92.57 ms    0.0%    2024.57 Mbps   696.44 Mbps    Alliance Broadband Services Pvt. Ltd. - Kolkata
     Delhi, DL        72.12 ms    0.0%    696.32 Mbps    299.90 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      72.75 ms    0.0%    1212.13 Mbps   1073.19 Mbps   Powernet - Gurgaon
     Patna, BH        141.90 ms   N/A     1572.12 Mbps   33.77 Mbps     Vi India - Patna
     Avg DL Speed       : 1912.07 Mbps
     Avg UL Speed       : 1368.76 Mbps
     Total DL Data      : 49.90 GB
     Total UL Data      : 29.74 GB
     Total Data         : 79.64 GB
     Duration           : 9 min 36 sec
     System Time        : 01/05/2023 - 02:33:23 IST
     Total Script Runs  : 1803
     Result             : https://cdn1.frocdn.ch/hjpGFEELKQtIR4l.txt
  • AdvinAdvin Hosting Provider
    wget and curl sometimes aren't installed by default on some minimal installations of various operating systems and have to be installed manually
    Thanked by (1)sh97
  • edited May 2023
    Updated to v2023.05.01
    * Added new region: Africa
    * Updated regions - India, EU to use speed test servers >1Gbps, update locations
    NatVPS UK -> Africa
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz
     CPU Cores          : 1 @ 1350.000 MHz
     CPU Cache          : 6144 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 4.9 GB (2.0 GB Used)
     Total RAM          : 128.0 MB (79.0 MB Used)
     System uptime      : 157 days, 21 hour 46 min
     Load average       : 0.22, 0.12, 0.16
     OS                 : Ubuntu 20.04.5 LTS
     Kernel             : 5.4.0
     Virtualization     : OPENVZ
     Basic Network Info
     ISP                : OVH SAS
     ASN                : AS16276 OVH SAS
     Host               : OVH Ltd
     Speedtest.net (Region: AFRICA)
     ISP: OVH SAS
     Nearest          0.67 ms     0.0%    738.37 Mbps    216.88 Mbps    Community Fibre Limited - London
     Cape Town, SA    148.71 ms   0.0%    879.90 Mbps    157.65 Mbps    MTN SA - Cape Town
     Cape Town, SA    140.71 ms   0.0%    828.11 Mbps    199.93 Mbps    Vodacom - Cape Town
     Johannesburg, SA 164.99 ms   0.0%    818.35 Mbps    169.66 Mbps    i3D.net - Johannesburg
     Harare, ZW       192.61 ms   N/A     482.87 Mbps    2.55 Mbps      Econet Wireless Zimbabwe - Harare
     Maputo, MZ       164.85 ms   0.0%    374.43 Mbps    58.64 Mbps     TMCEL - Moçambique Telecom - Maputo
     Antananarivo, MG 192.76 ms   0.0%    824.75 Mbps    138.76 Mbps    Orange Madagascar - Antananarivo
     Darusalaam, TZ   142.16 ms   0.0%    789.21 Mbps    65.07 Mbps     Vodacom Tanzania Ltd - Dar es Salaam
     Nairobi, KE      149.51 ms   0.0%    780.62 Mbps    79.89 Mbps     Airtel Kenya - Nairobi
     Addis Ababa, ET  91.60 ms    0.0%    824.16 Mbps    189.75 Mbps    Ethio Telecom - Addis Ababa
     Cairo,EG         58.22 ms    0.0%    917.42 Mbps    216.30 Mbps    Vodafone Egypt - Cairo
     Alexandria, EG   52.04 ms    N/A     859.27 Mbps    217.08 Mbps    Etisalat Misr - Alexandria
     Rabat, MA        43.66 ms    0.0%    908.21 Mbps    167.81 Mbps    Maroc Telecom - Rabat
     Algiers, DZ      36.94 ms    0.0%    849.64 Mbps    151.37 Mbps    Ooredoo Algeria - Algiers
     Lagos, NG        115.09 ms   0.0%    18.07 Mbps     116.61 Mbps    MTN NIGERIA COMMUNICATIONS LTD - Lagos
     Avg DL Speed       : 726.23 Mbps
     Avg UL Speed       : 143.20 Mbps
     Total DL Data      : 14.35 GB
     Total UL Data      : 3.44 GB
     Total Data         : 17.79 GB
     Duration           : 7 min 58 sec
     System Time        : 01/05/2023 - 11:23:17 UTC
     Total Script Runs  : 1835
     Result             : https://cdn1.frocdn.ch/BnjpdCv1a7m3rTb.txt
    root@uk2-natvps-london:~#
    Thanked by (2)febryanvaldo carlin0
  • VPS CrownCloud 2 Cores Intel 2GB RAM - 15 USD
     Basic System Info
     CPU Model          : 12th Gen Intel(R) Core(TM) i9-12900K
     CPU Cores          : 2 @ 3187.200 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 58.5 GB (3.6 GB Used)
     Total RAM          : 1.9 GB (148.2 MB Used)
     Total Swap         : 512.0 MB (524.0 KB Used)
     System uptime      : 0 days, 0 hour 43 min
     Load average       : 0.33, 0.12, 0.19
     Kernel             : 5.4.0-135-generic
     Basic Network Info
     ISP                : Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG
     ASN                : AS48314 Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG
     Host               : IP- Accelerated IT Services GmbH
     ISP: IP-Projects GmbH & Co. KG
     Nearest          1.18 ms     0.0%    425.16 Mbps    477.40 Mbps    Prepaid-Host - Uslar
     London, UK       11.97 ms    0.0%    925.03 Mbps    582.70 Mbps    VeloxServ Communications - London
     Edinburgh, UK    25.04 ms    N/A     927.93 Mbps    908.37 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       24.14 ms    0.0%    944.82 Mbps    910.54 Mbps    Three Ireland - Dublin
     Amsterdam, NL    6.55 ms     0.0%    924.85 Mbps    920.42 Mbps    GSL Networks - Amsterdam
     Paris, FR        11.47 ms    0.0%    908.83 Mbps    916.24 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    16.30 ms    0.0%    939.23 Mbps    914.75 Mbps    GSL Networks - Marseille
     Madrid, ES       30.90 ms    0.0%    900.48 Mbps    897.21 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    36.45 ms    0.0%    911.09 Mbps    895.23 Mbps    Adamo - Barcelona
     Lisbon, PT       39.85 ms    N/A     922.95 Mbps    897.97 Mbps    fdcservers.net - Lisbon
     Rome, IT         25.42 ms    0.0%    910.69 Mbps    919.55 Mbps    TIM SpA - Rome
     Zurich, CH       6.91 ms     0.0%    935.79 Mbps    924.09 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    0.98 ms     0.0%    922.42 Mbps    926.48 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       10.17 ms    0.0%    925.70 Mbps    914.27 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       12.37 ms    0.0%    887.42 Mbps    922.05 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     18.30 ms    0.0%    926.35 Mbps    908.64 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       24.58 ms    0.0%    917.21 Mbps    905.37 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       20.52 ms    0.0%    912.36 Mbps    917.21 Mbps    UPC Polska - Warszawa
     Lviv, UA         23.53 ms    0.0%    916.78 Mbps    906.65 Mbps    Kyivstar - Lviv
     Kyiv, UA         27.56 ms    0.0%    923.91 Mbps    912.34 Mbps    o3 - Kyiv
     Minsk, BY        27.61 ms    0.0%    929.34 Mbps    904.51 Mbps    A1 - Minsk
     Bucharest, RO    27.12 ms    0.0%    924.95 Mbps    924.41 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     28.87 ms    0.0%    910.40 Mbps    899.76 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    29.50 ms    0.0%    921.69 Mbps    903.57 Mbps    i3D.net - Stockholm
     Oslo, NO         25.60 ms    0.0%    916.95 Mbps    905.76 Mbps    Speedtest.net - Oslo
     Moscow, RU       43.43 ms    0.0%    933.23 Mbps    877.56 Mbps    MTS - Moscow
     Moscow, RU       37.22 ms    0.0%    732.44 Mbps    893.90 Mbps    Rostelecom - Moscow
     Istanbul, TR     48.31 ms    0.0%    927.29 Mbps    872.78 Mbps    Turkcell - Istanbul
     Istanbul, TR     38.15 ms    0.0%    920.43 Mbps    895.79 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 897.43 Mbps
     Avg UL Speed       : 881.23 Mbps
     Total DL Data      : 31.30 GB
     Total UL Data      : 27.86 GB
     Total Data         : 59.16 GB
     Duration           : 10 min 42 sec
     System Time        : 01/05/2023 - 15:27:05 UTC
     Total Script Runs  : 1845
     Result             : https://cdn1.frocdn.ch/dL2csNtJ7P2lEEM.txt
    Thanked by (1)sh97
  • VPS Tube-Hosting 2 Cores AMD 2GB RAM - 5 EURO
     Basic System Info
     CPU Model          : AMD EPYC 7542 32-Core Processor
     CPU Cores          : 2 @ 2899.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 24.5 GB (4.8 GB Used)
     Total RAM          : 1.9 GB (122.3 MB Used)
     Total Swap         : 2.0 GB (0 Used)
     System uptime      : 0 days, 0 hour 14 min
     Load average       : 0.21, 0.16, 0.09
     OS                 : Ubuntu 18.04.6 LTS
     Kernel             : 4.15.0-140-generic
     Basic Network Info
     ISP                : Pascal LAURENT
     ASN                : AS49581 Ferdinand Zink trading as Tube-Hosting
     Host               : Mo's Operations GmbH
     Location (IPv4)    : Bad Königshofen im Grabfeld, Bavaria, DE
     ISP: Tube-Hosting
     Nearest          17.21 ms    0.0%    958.56 Mbps    625.65 Mbps    BOUYGUES TELECOM CUBIC - Vélizy
     London, UK       14.89 ms    0.0%    951.59 Mbps    885.25 Mbps    VeloxServ Communications - London
     Edinburgh, UK    25.34 ms    N/A     949.07 Mbps    455.83 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       21.72 ms    0.0%    950.85 Mbps    715.73 Mbps    Three Ireland - Dublin
     Amsterdam, NL    8.81 ms     0.0%    927.34 Mbps    982.66 Mbps    GSL Networks - Amsterdam
     Paris, FR        17.49 ms    0.0%    951.43 Mbps    591.49 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    23.62 ms    0.0%    951.24 Mbps    609.22 Mbps    GSL Networks - Marseille
     Madrid, ES       37.10 ms    0.0%    951.38 Mbps    417.65 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    40.57 ms    0.0%    943.22 Mbps    443.72 Mbps    Adamo - Barcelona
     Lisbon, PT       44.50 ms    N/A     952.92 Mbps    467.30 Mbps    fdcservers.net - Lisbon
     Rome, IT         30.85 ms    0.0%    957.60 Mbps    372.56 Mbps    TIM SpA - Rome
     Zurich, CH       20.05 ms    0.0%    952.56 Mbps    676.65 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    12.23 ms    0.0%    951.68 Mbps    902.94 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       14.45 ms    0.0%    947.93 Mbps    850.27 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       23.75 ms    0.0%    959.74 Mbps    478.12 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     28.83 ms    N/A     939.74 Mbps    496.06 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       33.90 ms    0.0%    948.79 Mbps    452.16 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       26.34 ms    0.0%    948.22 Mbps    507.07 Mbps    UPC Polska - Warszawa
     Lviv, UA         48.42 ms    0.0%    950.30 Mbps    362.56 Mbps    Kyivstar - Lviv
     Kyiv, UA         35.01 ms    0.0%    954.00 Mbps    393.22 Mbps    o3 - Kyiv
     Minsk, BY        64.69 ms    0.0%    961.62 Mbps    314.27 Mbps    A1 - Minsk
     Bucharest, RO    46.26 ms    0.0%    953.02 Mbps    339.24 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     33.99 ms    0.0%    955.53 Mbps    340.47 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    28.63 ms    0.0%    946.14 Mbps    449.85 Mbps    i3D.net - Stockholm
     Oslo, NO         35.13 ms    0.0%    944.34 Mbps    472.04 Mbps    Speedtest.net - Oslo
     Moscow, RU       47.13 ms    0.0%    945.21 Mbps    258.45 Mbps    MTS - Moscow
     Moscow, RU       45.48 ms    0.0%    956.79 Mbps    333.75 Mbps    Rostelecom - Moscow
     Istanbul, TR     45.33 ms    0.0%    953.97 Mbps    358.57 Mbps    Turkcell - Istanbul
     Istanbul, TR     43.65 ms    0.0%    953.35 Mbps    356.56 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 950.62 Mbps
     Avg UL Speed       : 514.12 Mbps
     Total DL Data      : 34.89 GB
     Total UL Data      : 18.88 GB
     Total Data         : 53.77 GB
     Duration           : 11 min 52 sec
     System Time        : 02/05/2023 - 14:25:38 CEST
     Total Script Runs  : 1892
     Result             : https://cdn1.frocdn.ch/mXzJwExpDyyNOp6.txt
    Thanked by (1)sh97
  • @Calin iHostART NAT, $5.69/yr
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU           X5660  @ 2.80GHz
     CPU Cores          : 1 @ 2800.098 MHz
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 49.1 GB (645.3 MB Used)
     Total RAM          : 512.0 MB (42.9 MB Used)
     System uptime      : 0 days, 4 hour 52 min
     Load average       : 0.19, 0.19, 0.12
     OS                 : Ubuntu 22.04.2 LTS
     Kernel             : 5.2.0
     Basic Network Info
     ISP                : Legaco Networks B.V
     ASN                : AS9050 ORANGE ROMANIA COMMUNICATION S.A
     Host               : Legaco Networks B.V
     Location (IPv4)    : Eindhoven, North Brabant, NL
     ISP: Orange Romania Communications
     Nearest          110.05 ms   0.0%    159.07 Mbps    121.52 Mbps    Frontier - Ashburn, VA
     London, UK       50.20 ms    0.0%    457.83 Mbps    227.98 Mbps    VeloxServ Communications - London
     Edinburgh, UK    50.35 ms    N/A     553.61 Mbps    352.70 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       65.71 ms    0.0%    481.01 Mbps    256.08 Mbps    Three Ireland - Dublin
     Amsterdam, NL    41.53 ms    0.0%    466.79 Mbps    259.68 Mbps    GSL Networks - Amsterdam
     Paris, FR        36.87 ms    0.0%    571.00 Mbps    262.51 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    49.08 ms    0.0%    458.84 Mbps    258.99 Mbps    GSL Networks - Marseille
     Madrid, ES       54.25 ms    0.0%    476.98 Mbps    261.71 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    53.24 ms    0.0%    588.55 Mbps    311.84 Mbps    Adamo - Barcelona
     Lisbon, PT       76.31 ms    N/A     452.23 Mbps    142.06 Mbps    fdcservers.net - Lisbon
     Rome, IT         56.15 ms    0.0%    389.65 Mbps    234.05 Mbps    TIM SpA - Rome
     Zurich, CH       34.03 ms    0.0%    566.21 Mbps    294.48 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    27.48 ms    0.0%    494.63 Mbps    309.44 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       32.71 ms    0.0%    209.86 Mbps    241.32 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       32.51 ms    0.0%    602.98 Mbps    181.99 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     24.27 ms    N/A     364.46 Mbps    231.15 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       49.94 ms    0.0%    496.11 Mbps    249.78 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       47.58 ms    0.0%    465.49 Mbps    197.06 Mbps    UPC Polska - Warszawa
     Lviv, UA         39.79 ms    0.0%    452.81 Mbps    217.00 Mbps    Kyivstar - Lviv
     Kyiv, UA         41.03 ms    0.0%    450.55 Mbps    192.72 Mbps    o3 - Kyiv
     Minsk, BY        65.36 ms    0.0%    396.59 Mbps    203.78 Mbps    A1 - Minsk
     Bucharest, RO    13.22 ms    0.3%    434.00 Mbps    353.91 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     72.56 ms    0.0%    505.37 Mbps    112.30 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    65.82 ms    0.0%    521.13 Mbps    181.53 Mbps    i3D.net - Stockholm
     Oslo, NO         52.33 ms    0.0%    397.92 Mbps    163.41 Mbps    Speedtest.net - Oslo
     Moscow, RU       68.83 ms    0.0%    200.16 Mbps    122.92 Mbps    MTS - Moscow
     Moscow, RU       61.11 ms    0.0%    448.74 Mbps    102.40 Mbps    Rostelecom - Moscow
     Istanbul, TR     64.65 ms    0.0%    554.41 Mbps    62.05 Mbps     Turkcell - Istanbul
     Istanbul, TR     72.32 ms    0.0%    541.14 Mbps    66.85 Mbps     Vodafone TR - Istanbul
     Avg DL Speed       : 453.72 Mbps
     Avg UL Speed       : 212.87 Mbps
     Total DL Data      : 17.77 GB
     Total UL Data      : 8.62 GB
     Total Data         : 26.39 GB
     Duration           : 14 min 0 sec
     System Time        : 03/05/2023 - 13:49:22 UTC
     Total Script Runs  : 1948
     Result             : https://cdn1.frocdn.ch/6ix4wiS1GMirBe7.txt
    root@rom2-ihostart-ministorage:~#
  • @RapToN - KTS24 - Black Friday 2022 special offer - first year 5€, renewal 15€/year
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2630 v2 @ 2.60GHz
     CPU Cores          : 1 @ 2599.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 9,8 GB (2,1 GB Used)
     Total RAM          : 964,6 MB (103,1 MB Used)
     Total Swap         : 256,0 MB (0 Used)
     System uptime      : 3 days, 2 hour 5 min
     Load average       : 0.00, 0.00, 0.00
     Kernel             : 5.10.0-22-amd64
     Basic Network Info
     ISP                : SkyLink Data Center BV
     ASN                : AS44592 SkyLink Data Center BV
     Host               : Sascha Haendler
     ISP: SkyLink Data Center BV
     Nearest          0.20 ms     0.0%    8886.71 Mbps   3239.58 Mbps   FastLayer - Kerkrade
     London, UK       12.49 ms    0.0%    7288.82 Mbps   5934.94 Mbps   VeloxServ Communications - London
     Edinburgh, UK    23.02 ms    N/A     8026.66 Mbps   3497.07 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       23.43 ms    0.0%    7582.64 Mbps   2843.81 Mbps   Three Ireland - Dublin
     Amsterdam, NL    12.24 ms    0.0%    2419.70 Mbps   7442.75 Mbps   GSL Networks - Amsterdam
     Paris, FR        17.18 ms    0.0%    6918.40 Mbps   5317.36 Mbps   ORANGE FRANCE - Paris
    awk: line 1: 88674e+117648 : decimal overflow
    awk: line 1: 2396e+112850 : decimal overflow
     Marseille, FR    27.51 ms    0.0%    5221.75 Mbps   3852.84 Mbps   GSL Networks - Marseille
     Madrid, ES       36.89 ms    0.0%    3859.24 Mbps   2729.08 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    38.40 ms    0.0%    1503.53 Mbps   950.21 Mbps    Adamo - Barcelona
    awk: line 1: 7126e+1107 : decimal overflow
     Lisbon, PT       44.51 ms    N/A     4491.29 Mbps   1387.73 Mbps   fdcservers.net - Lisbon
    awk: line 1: 5712e+1519 : decimal overflow
     Rome, IT         30.36 ms    0.0%    4189.89 Mbps   2498.09 Mbps   TIM SpA - Rome
     Zurich, CH       20.31 ms    0.0%    8020.67 Mbps   2828.80 Mbps   Sunrise Communication AG - Zurich
    awk: line 1: 22139e+114544 : decimal overflow
    awk: line 1: 85228e+101408 : decimal overflow
     Frankfurt, DE    12.30 ms    0.0%    4444.84 Mbps   2439.67 Mbps   23M GmbH - Frankfurt Am Main
     Berlin, DE       17.94 ms    0.0%    6293.19 Mbps   3645.21 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       23.91 ms    0.0%    5783.50 Mbps   3728.59 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     26.46 ms    0.0%    5500.48 Mbps   1738.79 Mbps   Yettel Hungary - Budapest
     Gdansk, PL       29.57 ms    0.0%    7735.09 Mbps   2917.98 Mbps   Orange Polska S.A. - Gdansk
     Warsaw, PL       26.42 ms    0.0%    6349.86 Mbps   3407.01 Mbps   UPC Polska - Warszawa
    awk: line 1: 44464e+115505 : decimal overflow
    awk: line 1: 43937e+111797 : decimal overflow
     Lviv, UA         41.67 ms    0.0%    3909.92 Mbps   2010.79 Mbps   Kyivstar - Lviv
     Kyiv, UA         36.16 ms    0.0%    6152.00 Mbps   792.86 Mbps    o3 - Kyiv
     Minsk, BY        35.83 ms    0.0%    5309.54 Mbps   2505.44 Mbps   A1 - Minsk
     Bucharest, RO    40.63 ms    0.0%    6593.29 Mbps   1671.44 Mbps   Orange Romania Communications - Bucharest
     Helsinki, FI     32.11 ms    0.0%    7932.14 Mbps   2791.26 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.03 ms    0.0%    6998.22 Mbps   3100.99 Mbps   i3D.net - Stockholm
    awk: line 1: 01087e+101715 : decimal overflow
     Oslo, NO         35.04 ms    0.0%    3339.54 Mbps   1282.99 Mbps   Speedtest.net - Oslo
    awk: line 1: 90912e+127961 : decimal overflow
     Moscow, RU       47.46 ms    0.0%    5149.94 Mbps   2285.34 Mbps   MTS - Moscow
     Moscow, RU       45.95 ms    0.0%    5446.16 Mbps   2090.26 Mbps   Rostelecom - Moscow
     Istanbul, TR     65.34 ms    0.0%    5993.41 Mbps   997.39 Mbps    Turkcell - Istanbul
     Istanbul, TR     45.85 ms    0.0%    6020.43 Mbps   1843.39 Mbps   Vodafone TR - Istanbul
    awk: line 1: 28224e+111023 : decimal overflow
     Avg UL Speed       :  Mbps
     Total DL Data      :  GB
     Total UL Data      :  GB
     Total Data         :  GB
     Duration           : 13 min 23 sec
     System Time        : 03/05/2023 - 16:25:38 CEST
     Total Script Runs  : 1952
     Result             : https://cdn1.frocdn.ch/kjABgxF0aez6mBv.txt
    Thanked by (1)sh97
     Basic System Info
     AES-NI             : ✔ Enabled
     OS                 : Debian GNU/Linux 11
     Basic Network Info
     Avg UL Speed       :  Mbps
     Total DL Data      :  GB
     Total UL Data      :  GB
     Total Data         :  GB
    That error is really strange, seems to happen only on debian, and not always. I will take a closer look sometime soon.
    Thanked by (1)carlin0
  • edited May 2023
    Debian installs fewer packages by default than Ubuntu , maybe something is missing...
    EDIT:
    or maybe it’s because Debian has older software
    Thanked by (1)sh97
