Looking for: Low-end Dedi or KVM VPS oriented towards storage & VPN
Hey all,
I've got a slightly strange set of requirements for this one:
  • Either a low-end Dedi or KVM VPS would be fine
  • Must be a non North/South America location (Europe, Asia)
  • Either unmetered 50Mbps-100Mbps, or 10TB @ 250Mbps or greater
  • At least 1TB of Storage (underlying storage type, redundancy, etc. doesn't matter)
  • Allows for personal VPN use (I plan to mostly use this as offsite data storage & as a VPN endpoint)
  • CPU/RAM doesn't matter too much. As long as it can handle using IPSEC VPNs.
  • Max budget is $15/mo, but I am flexible if there's a better value by spending a little more ($20 for 3TB, etc.)
  • Bonus points if it has IP/KVM upon request, but not a requirement.
I am looking for the best bang for the buck deal so to speak so I would rather be closer to or slightly over my budget if it means better value for the money, over a cheaper but less attractive deal.
If you feel my requirements are unreasonable or my budget is too low I'm open to feedback.
