I am certainly doing something wrong ... how do I access Collabra? I cannot find it anywhere. Please note, I am new to NextCloud so maybe I am not looking in the right place, but I have looked everywhere.
Just create a new document or spreadsheet in a folder, then when you click it it will open.
Uhmm, I wish my life were that simple. I created a new document. It did not open. I reread and saw that you said to create it in a folder so I did that ... same.
Now, a few minutes later ... it works. Sigh
You're not wrong. When I create a new document and click it, nothing happens. I have to go somewhere else, come back to files, then click it and it works.
I think my order failed many times without VPN. Maybe because I am in Spain and billing address is german. Could try ordering via vpn but...
Maybe IP from my shared flat here is blacklisted?
@dosai said:
I tried rclone mount and it works perfectly.
It took me two days to upload all the photos (about 120GB) via davfs2+rsync.
davfs2 isn't working on my home router (GL-AR750) so I have to run it on a BeagleBone Black, then rsync from SAMBA mount to WebDAV mount.
rsync would only transfer 1 file at a time.
All the modify dates are messed up because WebDAV protocol doesn't allow setting modify dates.
I wish I knew rclone ealier.
With rclone sync command:
rclone can run on the home router directly, so the source HDD is local.
rclone can transfer 4 files in parallel.
Modify dates are set correctly.
There are fewer command line flags to remember than rsync.
Currently, I'm using rclone to re-sync the photo directory.
It wants to re-upload about 15% of the files, and takes a lot of CPU and RAM.
Nevertheless, once I put it into nice, everything is progressing smoothly and should complete in less than a day.
I passed with a Serbian address (and all the other data - like phone etc.), in spite of using a "foreign IP address" through a VPN.
Maybe just lucky?
Maybe just lucky ?
Thank you! was wondering where to move my Google Photos! this is exactly what I need
My Personal Blog
It's a bit bugged I guess...
Off topic - has anyone successfully mounted nextcloud using webdav?
https://docs.nextcloud.com/server/20/user_manual/en/files/access_webdav.html#creating-webdav-mounts-on-the-linux-command-line
I did as per above instructions and mount works fine, but when I reboot my box goes into emergency mode.
I set a system-wide mount for WebDAV.
All files would show up as owned by the
ubuntu
user that I use to login to the desktop.ServerFactory aff best VPS; HostBrr aff best storage.
Ordered one
Managed to get one
Good deal
IPv6 is disabled
@martijnk
Yes I'm aware! It's on my list
Thanks my ?? friend.
Greetings from Gummersbach, Germany,
Malte / Xenic
thanks from indonesia
Thanks, I will try this. In the mean time, I tried rclone mount and it works perfectly.
Thank you so much ?
Thanks, I got one.
@martijnk Nice deal you got here, and thanks for the free 200GB. However, is there a way to enable file sharing with non-nextcloud users?
Edit: Found the share option.
Could we have the "App Order" app installed pretty please? Maybe "Notes" and/or "Deck" too?
I could but it seems the nextcloud app store is down right now. I will add them next time.
Ordered one, let's see how long it lasts
Sweet! I can see that you've installed them.
Thanks a ton.
Got one.
In total received 7 emails.
Get some 405 errors randomly.
Rclone command 'list' is disabled for WebDav.
https://microlxc.net/
How to mount it on a vps as an extra disk?
Rclone
Interesting, I forget to disable NordVPN autoconnection but still order successfully.
just got onboard, the new nextcloud UI looks good! seems different than what I got from swizzin
hope this BRICK will never get bricked!
With
rclone sync
command:Currently, I'm using rclone to re-sync the photo directory.
nice
, everything is progressing smoothly and should complete in less than a day.ServerFactory aff best VPS; HostBrr aff best storage.
You can increase transfers from 4 by using
--transfers=69
more here https://rclone.org/docs/I passed with a Serbian address (and all the other data - like phone etc.), in spite of using a "foreign IP address" through a VPN.
Maybe just lucky?
Squats are the new Push-ups
I am in too hopefully works well
