anyone got Plex remote access working on Oracle Cloud?
free tier.
am new to public and internal IP. normally my Plex servers are connected directly via public IP.
in this case there's a public and private IP assigned to the VM and it shows me below, I don't understand. under the VCN security settings I opened TCP 32400 for ingress.
not sure whats missing here.
  • The iptables may need to be modified.
    Thanked by (1)cybertech
  • May be you need to add 32400 to egress as well
    You need to edit iptables to allow 32400 ingress.
    I use the template in this video
    thanks for all the tips. tried everything and it now works, now gotta figure out which was the key.
    Try reversing the each action and see which one breaks it
    Sometimes Plex lies about whether it can be accessed from the Internet. I get that message appear occasionally even though my Plex is completely accessible...
    Thanked by (1)BarryHercules
  • edited July 2021
    There must be sonething wrong with your plex server then or may be network it is on. I have few servers in EU that are accessible whenever I try.
    The issue in OP's case was due to iptables. I dont use oracle cloud myself for plex but I do know that firewall configuration alone isnt enough to access services on oracle cloud. I found about the iptables issue from the oracle cloud thread at OGF. Once I reset the IPtables, it was just like any other VPS and I was able to use v2ray
    Nothing wrong with my Plex server, running solid for years now. It is probably as you suggested a networking setup thing. I have my Plex on a NAT network, no public IP, but it's port forwarded for direct access with iptables rules and I also use haproxy and cloudflare for the frontend on a subdomain. Runs flawlessly.
    seems like it's gotta take a while for ARM cloud resources to free up before I can make a new VM and try it again :p
  • d0gd0g
    edited March 17
    I've got the same problem @cybertech ... did you find a way to make it work?
    I've tried firewalld, iptables, ingress/egress rules, disabling ufw ... nothing works!
    Also not sure if related but server shows port 0 on public side:
  • Using this usually works for me after adjusting the VCN security list: https://stackoverflow.com/questions/54794217/opening-port-80-on-oracle-cloud-infrastructure-compute-node
    Happened to my setup a number of times of the years, even reporting the problem whilst people are streaming content over the internet. Whatever they’re doing to validate connectivity clearly isn’t exactly what’s need to connect to PMS over the internet.
    i stopped using oracle free ... but i think i did manage to get it work for a short while as per @CamoYoshi 's method - VCN
  • To open a port on Oracle Cloud, you need:
    • VCN ingress rule
    • iptables ACCEPT rule
    Internet Gateway provides symmetric NAT, and there's no need for port forwarding rule.
    Reference: How to Host a Website in Oracle Cloud Free Tier
    NVMe2G for life!
    You can also consider Webhosting24 or LevelOne or Spartan. (paid links)
