Ran Yabs on my late 2012 Macbook Pro -
Clean install of Manjaro on OEM 128 GB disk. While I wait for the adapter to arrive that will help me upgrade to a 512 GB SSD.
Question: Why the Zeros for disk speed?
I used the command
curl -sL yabs.sh | bash -s -- -r9
bench.monster gave the following:
Disk Speed:
1st run : 2.9 GB/s
2nd run : 2.7 GB/s
3rd run : 2.9 GB/s
Thu Jul 29 17:26:55 IST 2021
Usage: ./yabs.sh [-fdighr49]
curl -sL yabs.sh | bash -s -- -{fdighr49}
Flags:
-f/d : skips the fio disk benchmark test
-i : skips the iperf network test
-g : skips the geekbench performance test
-h : prints this lovely message, shows any flags you passed,
shows if fio/iperf3 local packages have been detected,
then exits
-r : reduce number of iperf3 network locations (to only three)
to lessen bandwidth usage
-4 : use geekbench 4 instead of geekbench 5
-9 : use both geekbench 4 AND geekbench 5
Detected Arch: x64
Detected Flags:
-i, skipping iperf network test
-g, skipping geekbench test
running geekbench 5
Local Binary Check:
fio not detected, will download precompiled binary
iperf3 not detected, will download precompiled binary
Detected Connectivity:
IPv4 connected
IPv6 not connected
Exiting...
Yikes... yeah don't think it's gonna fare well on something that old. Lots of bash-related syntax errors there. Maybe I could enforce some sort of minimum bash version or something rather than spewing out junk output.
@vyas not too sure about that one. I'd do what @LetMeBeSad suggested and install fio natively to see if it runs that way (the script will detect the locally installed version and use that instead). If that fails too, then I'd know it's not an issue with the binary that I compiled
Tom. 穆坦然. Not Oles. Happy 233 哈哈哈 New York City guy visiting Mexico! How is your 文言文?
The MetalVPS.com website ran very speedily on MicroLXC.net! Thanks to @Neoon!
@Not_Oles said: When running qemu on Hetzner AX101, how much difference does -cpu host and -enable-kvm make?
Nice trial and results! Very interesting
This is why I always request for CPU passthrough on any newly purchased VMs if it's not enabled by default... Those AES-NI instructions are really essential for some operations. Plus... the less time a client's VM spends processing instructions, the less impact to the load on a host node, so it's a win-win.
would be interesting to also see some middle ground, aka qemu-kvm or similar but with AES-NI enabled (which should be possible with additional settings)... as you said I guess that option alone will make a very huge difference.
@Not_Oles any chance you can add this too, pretty please ;-)
@Falzo said: would be interesting to also see some middle ground, aka qemu-kvm or similar but with AES-NI enabled (which should be possible with additional settings)... as you said I guess that option alone will make a very huge difference.
Here are results with qemu's default processor (as in the first test, above) but now flying the -enable-kvm flag. As might be expected, this third test gives an intermediate result, 1308:
KVM Status
AES Status
GB 5 Single Core Score
Off
Off
110
On
Off
1308
On
On
1524
For anybody trying to understand how KVM could be "off" in test 1, given that the processor model name -- "Common KVM processor" -- literally includes "KVM," please consider that possessing a capability is not the same as actually using the capability. It seems that calling qemu as qemu-kvm-x86_64 requires that root explicitly enable KVM with -enable-kvm in order for KVM to be used. However, when qemu is called simply as kvm then KVM is used automagically if the caller is root but not used if the caller is unprivileged.
Note that there are additional changes beyond just AES status when switching from the default "Common KVM processor" to -cpu host which is AMD Ryzen 9 5950X 16-Core Processor.
[email protected] ~ # qemu-system-x86_64 -enable-kvm -m 8192m -nographic debian-sid-nocloud-amd64-daily.qcow2
[email protected]:~# curl -sL yabs.sh | bash
# Yet-Another-Bench-Script #
# v2021-06-05 #
Sat Jul 31 21:39:44 UTC 2021
qemu-system-x86_64: Slirp: external icmpv6 not supported yet
Processor : Common KVM processor
CPU cores : 1 @ 3393.622 MHz
AES-NI : ❌ Disabled
VM-x/AMD-V : ❌ Disabled
RAM : 7.8 GiB
Swap : 0.0 KiB
Disk : 1.9 GiB
Less than 2GB of space available. Skipping disk test...
Clouvider | London, UK (10G) | 931 Mbits/sec | 923 Mbits/sec
Online.net | Paris, FR (10G) | 936 Mbits/sec | 937 Mbits/sec
WorldStream | The Netherlands (10G) | 935 Mbits/sec | 936 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | 761 Mbits/sec | 269 Mbits/sec
Clouvider | NYC, NY, US (10G) | 885 Mbits/sec | 395 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 728 Mbits/sec | 476 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 843 Mbits/sec | 293 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | 767 Mbits/sec | 292 Mbits/sec
Clouvider | London, UK (10G) | 919 Mbits/sec | 910 Mbits/sec
Online.net | Paris, FR (10G) | 924 Mbits/sec | 924 Mbits/sec
WorldStream | The Netherlands (10G) | 921 Mbits/sec | 918 Mbits/sec
Clouvider | NYC, NY, US (10G) | 873 Mbits/sec | 336 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 829 Mbits/sec | 332 Mbits/sec
Running GB5 benchmark test... *cue elevator music*
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1308
Multi Core | 1308
Full Test | https://browser.geekbench.com/v5/cpu/9101589
@Mason said: Nice trial and results! Very interesting
Hey @Mason! Thanks for the kind words! Best wishes from the desert! 👨💻🏜️
@Not_Oles thanks, interesting indeed, esp. because the gap is much smaller with that setting and AES still is disabled. I'd guess KVM+AES then comes really close to full host passthru
Just a mini-update towards the Alwyzon Performance Server line: instead of Xeon® E-2174G (no longer sold), you might now get a Xeon® E-2244G (newer model) delivered instead. But no worries, those are at least as beefy as the E-2174G. 🥳
Tuned a little bit 4k test
10/2 Gbit/s uplink. Network is awesome all around the world.
wow which provider?!
@cybertech OVH.
DO droplet, got it free a little while ago from this thread
juicy network
YABS doesn't run on a Cobalt RaQ4r
I tried using
bash2
and got a bit further. Commented out a section in yabs and got:I think basically it's all just too old lol.
I used the command
Disk Speed:
1st run : 2.9 GB/s
2nd run : 2.7 GB/s
3rd run : 2.9 GB/s
Average : 2901.3 MB/s
Output from the 'h' flag below
Also,
gave
@vyas Install fio manually via brew.
Thanks- forgot to mention I run Manjaro Linux. YABS was on Manjaro
Then it should work, at least as i know Manjaro is based on Arch. Maybe there is some misconfiguration for Arch(Manjaro) tho?
Thanks @LetMeBeSad and @Mason
installing fio worked.
Not bad for a 10 year old OEM disk. (Samsung SSD for MBP12)*
*But allows me to build a case to upgrade the drive. Not just for storage but also speed.
Interesting. So my prebuilt fio has some issues with Manjaro (and possibly Arch?) that I'll have to investigate in the future.
Glad the fio install worked
HostHatch 250GB big plate chicken in Chicago
SSH connection interrupted, after re-login I see
geekbench_claim.url
with link to result:https://browser.geekbench.com/v5/cpu/9086575
3 of 3 my VirMach VPS are online, but you should consider Webhosting24 aff or Nexril aff.
box5 is the culprit - @Fritz ; yoursunny is my dinner for tonight - @FatGrizzly
hosthatch
hongkong 香港
1 vCPU 2690 V2
2GB ram 内存
20GB 硬盘 Hard Disk NVMe RAID-10
1gbps bandwidth
1TB monthly transfer
Above only applies if paid for 2 years (USD $15 / year)
Note -- using -cpu host without -enable-kvm gives an error:
First, without -cpu host and without -enable-kvm
Second, with -cpu host and -enable-kvm
I run yabs inside a screen, so I can leave it anytime without worry..
Huge Poland KVM (WebHorizon)
YABS Archive | Free NAT KVM | Free NAT LXC
That is amazing VPSes you have, guys..
terrahost dedi
Hi @Falzo!
qemu-kvm-x86_64
requires that root explicitly enable KVM with-enable-kvm
in order for KVM to be used. However, when qemu is called simply askvm
then KVM is used automagically if the caller is root but not used if the caller is unprivileged.Note that there are additional changes beyond just AES status when switching from the default "Common KVM processor" to
-cpu host
which is AMD Ryzen 9 5950X 16-Core Processor.Tom. 穆坦然. Not Oles. Happy 233 哈哈哈 New York City guy visiting Mexico! How is your 文言文?
— Michael
Picked up a few UK VMs to benchmark as I'm looking for a new home for a few smaller projects.
VM Specialist
OVHcloud
Nexus Bytes
Nice performance throughout, but will probably hold onto the VM Specialist one - kudos @Mr_Tom
NexusBytes VPS-6G Ryzen
Entrybytes Entry-8G
UK node
NL node
