Testing bandwidth between VPSes?
Hi all,
Just reaching out to ask if anyone knew of any fancy automated tool that could be installed on multiple VPSes to test the bandwidth between them on a regular basis? I've got a Los Angeles Hosthatch service that seems to have less-than-expected network performance and I wanted to collect to more data see if it varies over time. Smokeping's showing cyclical latency variation but actual throughput stats would be great.
I was thinking of rolling something myself using iperf and cron, however thought I'd ask to see if there's something out there that I may have missed during my research...
thanks in advance!
  • HostHatch LA is 🥔 24/7. I have one of those 10TB $110 VPS but it feels less special because of the network.
    Thanked by (1)bdl
  • bdlbdl OG
    edited September 2021
    Your experience beats a scheduled iperf any day :) Damn, I have the same 10tb service and was hoping network would be better than my 3tb - it's not :lol: .
    My HH Chicago one is more (network) performant even though it's further away. I may just throw everything up to Chicago instead then sync LA from CHI.
    Thanked by (1)corbpie
    Just setup cron to run iperf3 on an hourly basis for a few days. iperf3 is really easy to use anyhow. On Debian/Ubuntu, you can install it via:
    sudo apt install iperf3
    No further config needed. To bench, just run:
    iperf3 -c <target iperf server>
    # for ex: iperf3 -c lg.vie.alwyzon.net
    # or: iperf3 -c speedtest.iveloz.net.br
    Then filter the output of iperf3 to only get the total in/out (you could just copy function launch_iperf from Mason's YABS and alter the print statement in line 616) and log it line by line to a CSV file. After a few days you download that CSV and create a chart in Excel.
    Just as a warning: iperf3 is quite heavy on the network and uses a lot of bandwidth, maybe don‘t let it run too often/too long. (And, remove the script again once you do not longer need it.)
    — Michael
    Thanked by (1)bdl
    i have HH LAX too, download is okayish at about 1gbps, but upload is.....iffy.
    tried sending between both HH NVMe and Storage VPS in LAX.
    NVMe sends at ~100MB/s to Storage, but the other way around is only ~9MB/s. Noted that IOWait while sending is at 80 ish.
    Thanked by (1)bdl
  • bdlbdl OG
    Thanks, that's what I was intending to do - either have it spit out a CSV or maybe throw it into a rrd... don't worry, with the speeds I'm experiencing on this service, I don't think it will use too much data :lol:
    That's pretty line ball with my findings. Latency also seems to follow my neighbors' backup schedules :) (the dark green is the service)
    root@cybertech:~# wget -4 http://mirror.us.leaseweb.net/speedtest/10000mb.bin
    --2021-09-08 14:56:07--  http://mirror.us.leaseweb.net/speedtest/10000mb.bin
    Resolving mirror.us.leaseweb.net (mirror.us.leaseweb.net)... 207.244.94.80
    Connecting to mirror.us.leaseweb.net (mirror.us.leaseweb.net)|207.244.94.80|:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 10000000000 (9.3G) [application/octet-stream]
    Saving to: ‘10000mb.bin’
    10000mb.bin                20%[======>                               ]   1.89G  37.5MB/s    eta 3m 44s
    root@cybertech:~# wget -4 http://mirrors-lax.webnx.com/test/10gb.bin
    --2021-09-08 15:01:42--  http://mirrors-lax.webnx.com/test/10gb.bin
    Resolving mirrors-lax.webnx.com (mirrors-lax.webnx.com)... 104.237.63.187
    Connecting to mirrors-lax.webnx.com (mirrors-lax.webnx.com)|104.237.63.187|:80... connected.
    HTTP request sent, awaiting response... 301 Moved Permanently
    Location: https://mirrors-lax.webnx.com/test/10gb.bin [following]
    --2021-09-08 15:01:42--  https://mirrors-lax.webnx.com/test/10gb.bin
    Connecting to mirrors-lax.webnx.com (mirrors-lax.webnx.com)|104.237.63.187|:443... connected.
    Length: 10485760000 (9.8G) [application/octet-stream]
    Saving to: ‘10gb.bin’
    10gb.bin                   59%[=====================>                ]   5.78G  94.8MB/s    eta 46s
    downloading speeds are fine-ish, IOWait less than 10.
    Thanked by (1)bdl
  • mtr might be interesting as well
    Thanked by (1)bdl
    HS4LIFE (+ (* 3 4) (* 5 6))
  • I think I build such thing in the past, to benchmark CDN's using LES with 10MB files.
    Lemme search.
    Thanked by (1)bdl
    OP, will you be raising a ticket with HH?
  • bdlbdl OG
    @alwyzon said:
    Just setup cron to run iperf3 on an hourly basis for a few days. iperf3 is really easy to use anyhow. > @cybertech said:
    @cybertech - I lodged one about a month ago, they said there was a known peering dispute between Level3 and NTT and said wait until mid-September for resolution. If you are experiencing similar with your services, may be worthwhile yourself opening a ticket too?
    Thanked by (1)cybertech
  • hosthatchhosthatch Hosting Provider
    This was related to Sydney only, with Level3 sending traffic from Sydney to Tokyo to LA instead of directly. But recently Telstra Global was added there along with Level3 and it is no longer a problem. Can you please re-test and update your ticket if you still see the longer route?
    As for LA - we use Psychz there. Please open a ticket with us including MTRs on both sides and both source/destination IPs (and if you can include another provider in LA who is showing better performance, that will be even better as we have something to compare to) - and we will get it optimized.
    Thanks
    Thanked by (2)chocolateshirt bdl
  • bdlbdl OG
    Thanks
    Thanks @hosthatch, really appreciate it. Unfortunately I don't have the LA letbox service (which had better performance) that I migrated to HH from, however I've asked other users in this thread who are also affected to see if they have alternate services - may be able to sort out some MTRs for us.
    Can also confirm the Sydney Hosthatch to Chicago Hosthatch routing is much improved, dropped 50ms - so good!
    Thanked by (1)hosthatch
    just made a ticket with "localized" tests to and fro HH NVMe VPS because i believe my upload problem is something to do with high IOWait when sending a file.
    Briefly tested with a Virmach LAX 10G VPS as well, Virmach sends in at 80MB/s, but HH Box sends out at 10MB/s, no difference.
    Thanked by (1)bdl
  • corbpiecorbpie OG
    Got this from my HH LAX storage which does seem better than when I got it
    iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.38 Gbits/sec | 1.00 Gbits/sec Online.net | Paris, FR (10G) | busy | 961 Mbits/sec WorldStream | The Netherlands (10G) | 1.15 Gbits/sec | 1.15 Gbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 1.97 Gbits/sec | 1.75 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 2.68 Gbits/sec | 1.88 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 3.37 Gbits/sec | 2.58 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 269 Mbits/sec | 907 Mbits/sec
    Thanked by (1)bdl
    Hello!
    This is a notification to let you know that we detected an issue affecting the node that hosts your Storage VM in Los Angeles and rebooted the node to normalize it. Your server will be back online shortly and we do not expect any further interruptions. We will be keeping an extra eye on the node for a while.
    We sincerely apologize for the inconvenience caused.
    Kindest Regards,
    Your HostHatch team
    Thanked by (1)bdl
    the issue remains.
    Thanked by (1)bdl
  • I didn’t get that email
  • I got the email, service was restarted but too soon to see if it changed anything :)
