Which free webpanel do you use?
edited March 2022 in General
what i need:
lightweight, fast, responsive panel
Support either Alma/Rocky 8 or Debian 11
Nginx
up to date Php 8.1 with Phpredis
up to date Mariadb 10.7
one-click migration (nice to have)
hence aapanel fit the bill.
any others?
edit:
with the community's suggestion, was able to get hestiacp up and running well with the above (sans one-click migration)
with the really minimalist setup, it might just be faster than aapanel!
Thanked by (1)pepa65
  • edited March 2022
    My friend just switched from DirectAdmin to Fastpanel.
    Debian 8, 9, 10, 11 (64-bit)
    Ubuntu 18.04, 20.04 (64-bit)
    CentOS 7 (64-bit)
    AlmaLinux 8 (64-bit)
    Rocky 8 (64-bit)
    Check their wiki for further details.
    Thanked by (2)cybertech pepa65
  • I don't use any. Someone I know has a lot of success with HestiaCP, I tried it myself but panels aren't really my thing so it's hard to judge whether it's good or not.
    Thanked by (1)cybertech
    aaPanel all the way baby
    I use it with centos 7 since it’s what it’s based off of but it works fine on centos 8 too. Have you tried it before or is it just on your list of ones to try?
    Thanked by (3)Erisa cybertech pepa65
    im using aapanel since Centos7, then 8 and now debian 11.
    always open to explore !
  • free as in Beer or Free as in Freedom?
    (someone had to bring it up! )
    Thanked by (2)0xff pepa65
    Squats are the new Push-ups
    🍻 beer
    edited March 2022
    those requirements, aapanel is the only one comes to mind.
    also give hestiacp a try
  • vyasvyas OG
    edited March 2022
    I missed the last part- Support either Alma/Rocky 8 or Debian 11
    @cybertech,
    Cloudron
    cipi
    VPSNoobs ( @AK_KWH )
    Ajenti
    Webmin
    ISPConfig
    longer list on my blog
    Edit: Updated images. My last sync messed up the path
    Thanked by (3)cybertech Abdullah pepa65
  • yokowasisyokowasis Services Provider
    Hestia FTW. They have complete , easy to understand API, perfect for automating things.
    have heard multiple mentions about it, does it have nginx+php8.1+php-redis?
  • vyasvyas OG
    edited March 2022
    Scroll to features and services
    https://github.com/hestiacp/hestiacp
    Installer script is nifty
    https://gabizz.github.io/hestiacp-scriptline-generator/
    Any bench for the server you will install this on?
    noice.
    am testing fastpanel now, hestiacp next.
    benches already been made, will be on one of them greencloudvps :p
  • sweatbarsweatbar Hosting Provider
    Hestiacp
    PeekaBoo at https://handyhost.net
    (Not affiliated with the Russian Handyhost Website in any way.)
  • vyasvyas OG
    edited March 2022
    Webinoly
    Wordops
    Cli. Latter has admin gui iirc
    Since your Saturday is already occupied, thought Sunday should not feel left out
  • edited March 2022
    I still use virtualmin, I absolutely hate the UI but it's very open to lots of technologies and since it's just for me, I haven't pushed for anything else. From a consumer perspective, I have subscribed in to this thread to see what might be out there
    Just realized it mine doesn't have php8, sorry if the post seemed spammy.
    RCLOUDSYSTEMS - EmailBackup and EmailSync are powerful email management and migration utilities for an unbeatable price!
  • It does not fit your requirements as it only supports centos 7 for now but centminmod is a great nginx stack, the dev tuned it to utilize the best of nginx & made it to one of the best out of the box stack. It is a cli based panel though so its attack surface is just your public facing application if you turn off its ftp feature.
  • edited March 2022
    Take a look at TinyCP; not sure it'll meet all your criteria though. I'd think 1-click migration is a non-starter, for example.
    Thanked by (3)cybertech pepa65 kdh
  • I switched to https://hestiacp.com great free webpanel. It doesn't have redis out of the box but you can manually install it.
    Thanked by (3)cybertech Falzo pepa65
  • webmin always
  • aapanel
  • Ispconfig3. You can strip it down to mere barebones via config upon installation. It has clustering as bonus.
    Hestiacp is also nice panel. There is a ton of options for personal use. Depends on os and UI preference.
    edited March 2022
    have been trying out hestiacp, and its really nice, but ran into an issue i wonder if anyone here has had experience with.
    my staging was able to work, loads fine but when i try to update it this happens:
    - mariadb 10.6
    - redis
    - Php8.1 + php-redis
    - session handler = redis
    - session.save_path = "tcp://127.0.0.1:6379"
    fault when updating my site causing PHP error:
    session_start(): Failed to read session data: redis (path: /home/admin/tmp)
    just hoping to get pointed in the right direction for me to investigate if its not too complicated :P
  • edited March 2022
    > - mariadb 10.6
    > - redis
    most likely a permission issue. afaik that specific tmp folder is not world readable, so redis might really and simply not be able to access it, if it does not run under the right owner. but I am a bit out of loop for the development so I can't say since when or why it is this way. maybe search or write something in the forum over there, right now I sadly have not much time to dive deeper into it...
    on a seperate note, it's not advisable to host anything under that admin account itself anymore, but instead create a seperate one with no sudo rights. could well be, that there are also implications here to restrict the admin account in a way to make the whole thing more secure ;-)
    edited March 2022
    > > - mariadb 10.6
    > > - redis
    thanks for the tip, yeah I've been searching around for permission issues, probably just havent nailed it yet.
    and yes im trying out using admin account, probably good to follow the proper procedures to this as well.
    Thanked by (1)Falzo
  • aapanel
  • @cybertech checkout cloudpanel v2
  • @Falzo are you HestiaCP's forum moderator, right bro :3
    Thanked by (1)Falzo
  • edited June 2022
    @risharde said: I still use virtualmin, I absolutely hate the UI but it's very open to lots of technologies and since it's just for me, I haven't pushed for anything else. From a consumer perspective, I have subscribed in to this thread to see what might be out there
    That's because they don't build PHP for you, you're relying on the system's repository which by default is the one provided by the OS - as an example RHEL 9 provides 8.0 currently. If you want 8.1 you need to add a 3rd-party repo or build it yourself. For RHEL/CentOS/Rocky/Alma/Fedora you can use Remi's one, and for Ubuntu/Debian you can use Ondřej Surý's ones - ppa:ondrej/php for Ubuntu, packages.sury.org/php for Debian.
  • Free: Keyhelp
    Paid: Plesk
    does it have php8.0-redis, opcache etc?
