cpanel api to delete addon domains using curl
hi
does anyone know how to use cpanel api to delete addon domains.
preferably using curl or a php script.
i don't mind making several calls just delete the domain
Thanks for any helps
  • I tried the above with several combinations but didn't work either with access denied, function does not exists etc ...what i would like is a complete example if need
    curl authenticate + getsession "if needed"
    curl call the delete api
    but cpanel api's are fragmented between old-new not complete for example the above will not delete the subdomains you'd wish there is a parameter recursive.
    I think a lot of improvements can be made and should discourage old calls.
  • I like doing it manually.
    In particular each and every dns record.
    Very gratifying
    Squats are the new Push-ups
    Very gratifying
    once in a while is fine, but if you have 10's scripting is the only way.
    Very gratifying
    You have low threshold for pain ??
  • @ehab said:
    yes
    Looks like Jay. @seriesn
    Thanked by (1)ehab
  • @vyas said:
    i know your sensitive about hair.
    Thanked by (1)vyas
  • I'm fairly certain that you can only delete domains via the WHM API.
    If you have WHM API access then you could run the following CURL -
    curl -H'Authorization: whm username:MYAPITOKEN' https://hostname.example.com:2087/json-api/delete_domain?api.version=1&domain=example.com
    Thanked by (1)ehab
    https://quantumcore.com.au | Aussie VPS Host
    Pure NVMe Storage | 1GB Link | VPS Start at $5 AUD
  • edited May 2022
    @QuantumCore said:
    I haven't tried if i can access with a whm account, infact not sure if my normal cpanel user account can access that way.
    anyway i found something working for now
    curl --location --request GET 'https://hostname.example.com:2083/json-api/cpanel?cpanel_jsonapi_version=2&domain=example.com&cpanel_jsonapi_module=AddonDomain&cpanel_jsonapi_func=deladdondomain&subdomain=example.com.maindomain.com' \ --header 'Authorization: cpanel YOURCPID:YOURTOKEN'
  • Where'd you find that? I had a look at the cPanel API doco and couldn't find that :persevere:
    yeah, the API and docs need a lot of improvements. I can sometimes say this is shit.
    I am thinking to publish a postman collection for both cpanel and directadmin basic 101 calls... just need to find the time.
  • Yeah, you'd get a bit of traffic for that I'd guess since I searched for API stuff and apart from the cPanel doco, I didn't get a lot of results, even from the cPanel forums.
