Tailscale SSH
edited June 2022 in General
Some of you are probably using tailscale, and they introduced a new SSH feature that allows you to work with SSH, set up access control lists, and without needing to add stuff in ~/.ssh/config.
https://tailscale.com/blog/tailscale-ssh/
Personally, I've never used Tailscale, I plan to try it some time in the future though.
Thanked by (3)fryz Abdullah chimichurri
