1568101113
  • AdvinAdvin Hosting Provider
    edited June 2022
    @ehab said:
    @Advin said:
    ee1074d5ff673b3413a9993eaf9553f841b8ccd0
    Interested in playing around with it. I'll most likely be running a couple of very small websites, and maybe also running an uptime monitor along with it :)
    maybe Neoon has something from advinservers and him reading this is like :
    Haha =) To be honest, I'm mostly just curious on how NanoKVM works and what I can do with one of the smaller instances. I requested their lowest plan, the 256MB one, so I'm curious on how it would handle a couple of small websites/uptime monitoring :p If my request does get denied, that's understandable since there's probably someone who needs it more than I do <3
    Thanked by (1)ehab
  • @Neoon how long have you been giving these out for now? Regardless, kudos.
  • NeoonNeoon OG
    edited June 2022
    Deployed, nah its fine.
    Since 2018.
    Thanked by (2)flips ralf
  • Proxmox 6 is going EOL soon, end of next month.
    We still got 2 Nodes running Proxmox 6, FM and NO.
    NL2 already runs with Proxmox 7.
    I have to upgrade these by end of next month.
    I will announce the the Maintenance windows soon.
    Thanked by (3)Ganonk flips adly
  • On Wednesday 6th of July at 11:00 UTC+3 / CEST, Network gear will be upgraded in Fremont.
    The estimated downtime is a maximum of 2 hours, but we expect most servers to be online much faster.
    The Reason for this, the Node is currently limited to 100Mbit, each VM to 50Mbit, after this upgrade, the Node will have full Gigabit connectivity, which means each VM will be upgraded to 150Mbit/sec after the Maintenance shortly.
    Thanked by (2)Ganonk bdl
  • Proxmox 6.4 is going EOL on 31.07.2022.
    We still got 2 Nodes, NO and FM running with Proxmox 6.
    Hence we need to upgrade them to Proxmox 7 until the end of the month.
    I am planning upgrading booth Nodes on Tuesday, 19.07 at around 22:00 CET.
    Estimated downtime 30-60 minutes, usually it goes quicker.
    No plans for DE, despite its still up and running, since I am still unsure about its future.
    Thanked by (4)Brueggus Ganonk Ouji adly
    My server's back up but IPv6 seems to be broken:
    tracepath6 2620:fe::10
     1?: [LOCALHOST]                        0.021ms pmtu 1500
     1:  2604:a100:100:2::1                                    0.206ms
     1:  2604:a100:100:2::1                                    0.200ms
     2:  no reply
     3:  no reply
     4:  no reply
    ^C
    ...or are they still doing maintenance?
  • NeoonNeoon OG
    edited July 2022
     2:  no reply
     3:  no reply
     4:  no reply
    ^C
    The Maintenance only took 5 minutes, but yea from the looks of it IPv6 died.
    I have forwarded the issue, they should take a look shortly.
    Thanked by (1)Brueggus
  • Should be resolved.
  • @Neoon said:
    Should be resolved.
    Looks good. Thanks a bunch!
  • If someone wants the Uplink Speed upgraded to 150Mbit lemme know.
    Sadly Proxmox is not making it easy.
  • DE node status unknown 🥺
    I already said, no guarantees, if you keep your vm on this node.
    Everyone who wanted got a migration.
    Thanked by (2)Ganonk alvin
    You should apply as soon as possible while Neoon can arrange other region for you, otherwise there may be one area left to choose from or even none.
    Kinda but most of the time, when everything is out of stock on the page, the nodes still have enough memory and disk free to relocate a few vms.
    Plus, some rumors say, they might be a new Node soon.
    Thanked by (3)alvin ralf Ganonk
    Maintenance done, took a bit longer due to spinning rust.
    Thanked by (1)Ganonk
  • Token
    73aff7499a532d11ccee5ac64a8663ccb238eb67
    @Neoon could you help me start?
    thank you very very very very very very very very very very very very very very very very very very very much <3
    Yes, you can start by reading the rules
  • @mfvps said:
    Token
    Thanked by (2)ralf adly
  • Fresh from the Mailbox (Fremont):
    Our ISP (Internet Service Provider) is performing a maintenance on its infrastructure in the interval below:
    Window Start Time: Thursday, August 4, 2022 23:00 (UTC-0700)
    Window End Time: Friday, August 5, 2022 02:00 (UTC-0700)
    Expected Impact: < 1 hour
    Reason: Switch software upgrade to enhance security and stability
  • So how can I get free kvm =)
    no
    Congratulations on your first post!
    $7
  • Token: 1d39894740497ed302e4a05f25ec5e6cdc4915ab
    I plan to use my requested NanoKVM instance to test some small Machine Learning Models for a purpose of Academic. These Models have very low bandwidth and system requirements, so I am confident that they should not negatively impact other tenants on my node. Thank you for offering this service!
  • Can none of you guys read instructions?
  • Not connected, error: No such file or directory
    Thanked by (2)Ganonk ehab
