[DEDI] $69/m Xeon E5 1650 V4 + 128G + 1TB SSD | 1G UNMETERED | MORE DEALS INSIDE
ReliableSite_RadicReliableSite_Radic Hosting Provider
**** CLICK HERE FOR A FULL LIST OF SERVERS + FILTERS + ORDER LINKS ****
100% Dedicated/Unshared Ports
1 Gbps Unmetered - FREE
2 Gbps Unmetered - $99/m
3 Gbps Unmetered - $190/m
5 Gbps Unmetered - $350/m
10 Gbps Unmetered - $599/m
DDoS Protection - Included
Deals are first come first serve, if you no longer see it on the web site, then it's sold out.
Data Centers:
New York City Metro
Miami, Florida
Los Angeles, California
Add a nVidia Quadro RTX 4000 GPU to the following servers for an additional $99/mo:
-Intel Core i7 9700K
-Intel Core i9 9900K
-Intel Core i9 10900K
-AMD Ryzen 3700X/3900X/3950X
-AMD Ryzen 5600X/5800X/5900X/5950X
We also have more modern servers in stock, but not listed below as they are priced above $120/mo.
Take **ADDITIONAL ** discounts off the Rapid Deploy servers below throughout the rest of 2022 with the following coupons:
$10 off: July10OFFTHRU2022
$20 off $50+: JULY20OFF50THRU2022
$40 off $100+: JULY40OFF100THRU2022
$70 off $150+: JULY70OFF150THRU2022
$100 off $200+: JULY100OFF200THRU2022
Offers $70 ( and Under (full list here):
Instant Setup - (4 Cores)   Intel Core i7 4770 (Rapid Deploy 32GB)  32GB DDR3 /     2x1TB HD    $54.00/mo
Instant Setup - (4 Cores)   Intel Core i7 4790 (Rapid Deploy 32GB)  32GB DDR3 /     256GB SSD   $54.00/mo
Instant Setup - (4 Cores)   Intel Special (RD 32GB) 32GB DDR3 /     1TB SSD $55.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1230 V3 (Rapid Deploy 8GB)    8GB DDR3 /  64GB SSD    $39.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1230 V3 (Rapid Deploy 32GB)   32GB DDR3 /     256GB SSD   $49.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1240 V5 (Rapid Deploy 16GB)   16GB DDR4 /     256GB SSD+2TB HD    $59.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1240 V6 (RD 16GB SSD) 16GB DDR4 /     256GB SSD   $55.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1240 V6 (RD 16GB HDD) 16GB DDR4 /     2TB HD  $55.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1245 V2 (RD 32GB SSD) 32GB DDR3 /     256GB SSD   $47.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1245 V2 (RD 32GB HDD) 32GB DDR3 /     2TB HD  $47.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1270 V3 (Rapid Deploy 8GB)    8GB DDR3 /  128GB SSD   $45.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1270 V3 (Rapid Deploy 16GB)   16GB DDR3 /     64GB SSD+1TB HD $48.00/mo
Instant Setup - (4 Cores)   Intel Xeon E3 1270 V3 (Rapid Deploy 32GB)   32GB DDR3 /     512GB SSD   $55.00/mo
  • ReliableSite_RadicReliableSite_Radic Hosting Provider
    Just a note, you cannot use addons to bump into a different discount category. The category is based off the base server price.
    Some epic post discount deals:
    Intel Xeon E5 1650 V4 | 128GB RAM | 1TB SSD + 4 TB HDD | $69/mo (with coupon JULY40OFF100THRU2022)
    AMD Ryzen 3700X | 64GB RAM | 2 x 512GB NVMe | $69/mo (with coupon JULY40OFF100THRU2022)
    Some more:
    Intel Xeon E3 1270 V3 | 32GB RAM | 512GB SSD | $35/mo (with coupon JULY20OFF50THRU2022)
  • Question: Are these discounts reccuring?
    Or only first month?
    Good day and Goodbye
    From OP:
    Thanked by (1)miu
  • UPDATE: at checkout and after applying of code i see " Recurring Discount"
    So answer is probably YES
    From OP:
    Ok then this should means that discounts are working only till end of this year
    Can u confirm or better explain it @ReliableSite_Radic ?
  • visualwebtechnovisualwebtechno Hosting ProviderOG
    edited July 2022
    Amd server available
  • MasonMason AdministratorOG
    From OP:
    Coupon says recurring when you add it, so safe to assume it's recurring for as long as you keep the service. The "rest of 2022" bit just means the coupon codes are valid until the end of the year.
    Thanked by (1)miu
  • miumiu
    edited July 2022
    From OP:
    It is confusing whole.
    I worry that he sooner meant that recurring discount will be remove from 1.1.2023 (discounted price is valid only till end of the year 2022)
    @ReliableSite_Radic can you finally explain how it is and confirm?
    Thanks
    The coupon is valid until July 31st, 2022. The discount is active throughout 2022.
    Yes, we have Ryzen 3000 and Ryzen 5000 based configurations in stock.
    https://www.reliablesite.net/dedicated-servers/
    More:
    Intel Core i7 4790 | 32GB RAM | 256 GB SSD | $34/mo (with coupon JULY20OFF50THRU2022)
    And more:
    Intel Core i9 9900K | 64GB RAM | 1TB NVMe | $75/mo (with coupon JULY40OFF100THRU2022)
  • AdvinAdvin Hosting Provider
    From OP:
    From OP:
    Thanks
    You can only use the coupon in July and any services bought with the coupon will lose the discount at the end of 2022. So, if you bought a 5900X 128GB config for $129/month with the coupon code in this thread, it'll go back up to $200/month in January.
    I bought a server without realizing this :anguished:
    From OP:
    From OP:
    Thanks
    Buy it, cancel it Dec 31st.
    or.....take advantage of an epic deal and build up your business :-)
