@ofit said:
Hello @ralf, can you please test wireguard and openvpn performance (speed) on pfsense and openwrt in promox on your new box n5105 please. Thanks
I do have a wireguard proxy set up to another VM at OVH which seems to be working well, but not much use for a test as OVH is capped at 100Mbps.
So, initial tests using that (as it was already set up) seem pretty good for up to 100Mbps.
My direct setup is:
(unecrypted) laptop -> wifi -> 192.168.1.1 (pfsense) -> WAN -> internet -> gra.proof.ovh.net
I guess -R is slower because the ports on KS-LE-1 are 100 up, 1000 down.
CPU on proxmox hit about 6.5% on the first test and about 7.5% on the second, so not much impact. From the graph that shows all cores, running top -t 0.25 shows CPU getting up to about 30% (max 400%)
OneProvider.com
Product/Service: Dedicated Server +
Server location: Paris - FR
HARDWARE SPECIFICATIONS:
CPU: Intel Xeon E3-1220 v2 or better - 3.1 GHz - 4 core(s)
RAM: 32GB - DDR3
Hard Drive(s): 2x 1TB (SSD SATA)
Bandwidth: Unmetered @ 1Gbps (1 Gbps Guaranteed)
Price: €24.99 / 1 month
I got 2x SA530 3D NAND SATA SSD drives from Western Digital with Power On Hours: 120 , Intel Xeon E3-1230 V2 CPU and Dell Multi-bit ECC 4x 8GiB bus 1600 MT/s RAM.
Apologies for not adding more info. I did a similar proxy to a US VPS with Racknerd in LA and run iperf directly on that machine. I was getting about 300Mbps direct but for some reason the forwarding to a VM that did wireguard and forwarded on to the RN machine seemed to top out at about 130Mbps. Not sure why yet why it was much lower throughput than unwrapped, as CPU usage seemed pretty low everywhere.
Holy shit that CPU steal is high af
My direct setup is:
My test set up using the tunnel is:
Doing a direct test first shows the wifi doesn't really limit bandwidth:
And multiple runs via the tunnel pretty much hit my usual speeds with OVH:
For comparison, iperf direct from the KS-LE-1:
Just fresh Delivered
10€/y Miami W24
Steam Deck 256GB NVMe (not plugged in)
Steam Deck 256GB NVMe (plugged in)
Aliababa Cloud Offer 2GB KVM for 2.50$ 6Mbit Cap, 1.5TB Hong Kong
15$/y AMS GreenCloud from 4th April Sale, still in Stock.
OneProvider.com
RAM: 32GB - DDR3
Yabs is here:
https://dttech.net - Personal Site.
Hetzner CPX21
Thu Jul 14 05:31:20 AM UTC 2022
Uptime : 0 days, 0 hours, 3 minutes
Processor : AMD EPYC Processor
CPU cores : 3 @ 2445.406 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 3.7 GiB
Swap : 0.0 KiB
Disk : 75.1 GiB
Distro : Ubuntu 22.04 LTS
Kernel : 5.15.0-40-generic
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 909
Multi Core | 2580
Full Test | https://browser.geekbench.com/v5/cpu/16001884
Oracle Cloud Ashburn, Virginia
FiberVM - Linux Cloud VPS S - Singapore
Virmach $6/yr plan from 2017 that was migrated (Dallas):
Virmach $6/yr plan from 2017 that was migrated (New York):
New / sub brand of Cloud V?
Squats are the new Push-ups
Was able to access my Hostcram VPS after a long time (long story, too). So, posting a YABS - 6 months later.
Hi @vyas ,
Do you know why the Network speed is limited to less than 90 Mbits/sec?
virmach after fixing their network in tokyo
iHostART VPS FluxNode
NexusBytes $16/y vps
virtono KVM1G - 2.5 e
VirMach BF plan after ryzen migration to frankfurt
server-factory epyc XS
racknerd NY flash sale $6.79/y
IDK, the control panel is indeed Cloud V though
Also note that the VPS doesn't allow TIOCSTI.
GreenCloud LET 5555 RO
Brazil, G-Core
Hosthatch - Singapore - 32gb VPS
How much do you pay for this?
Short answer : A LOT
More than LES limits allow.
Edit: regular price isn’t too bad considering the specs and location
https://hosthatch.com/ssd-vps
