Looking for Sydney VPS
Morning All,
I am looking for a budget VPS (or dedi) in Sydney,
I am currently using a Kimsufi: KS-7
Intel i3 2130 - 8Go DDR3 1333 MHZ - 2To
So VPS specs should be (roughly) 2/4 Cores, 8Gb RAM, 50Gb Disk (don't need all that space).
Also open to 2 Cores, 4Gb RAM, 50Gb Disk if the above is way outside the budget.
Currently paying $11USD/month but know thats a dream in Sydney,
Willing to pay qtr/semi/yearly if that helps with prices.
I posted this elsewhere, but all the providers I know seem to have moved off that forum over the last 1-2 years
@MikeA @xTom @Brendan
not sure if any others here have Aussie VMs
@QuantumCore
Yeah, probably so. Nevertheless, here are some providers that have things in AU, and Sydney specifically I believe, that you might check out:
Dataplane.org's current server hosting provider list
Thanks @corbpie and @jtk
Might have to sit and wait in the shadows until a good deal comes up
I see there have been a few in the past.
I had a 4gb $25/qtr with FlowVPS, kicking myself for cancelling it when i was cleaning up idles.
FlowVPS is Melbourne, HostHatch has done good deals in the past but likely won't be doing them again. Also check shockhosting https://shockhosting.net/vps you can get 3c 6g 50GB SSD for $14.99
@corbpie I want Sydney, but Melbourne is still 100x better than France for latency to Australia
I'll check out HostHatch and Shockhosting, thanks
Webhosting24 Sydney NVMe 👈
Notice: paid link, non-aff
I am thinking of dropping a HostHatch 16GB / 80GB NVMe / 3x Xeon E5-2690 @ 3.0 (1 dedicated) in Sydney, might be a bit below your CPU specs.
@tetech I would be interested in this if you want to let it go, PM you.
I recomand:
Virtono
