AMD RYZEN 5950x (preferred), RYZEN 9 3900X or RYZEN Threadripper 3960X in Frankfurt / Germany
i am looking for a vps with the following specifications:
1-2 CPU, 1-4 GB RAM, 20-60 GB NVMe, 1 IPv4, 1 or 10 Gbps, Bandwidth 5-15 TB or unmetered (fair use), DC Location: Frankfurt am Main / Germany
Budget: 20,00 €/year up to 40,00 €/year (perhaps I would concede a little more here, lets see)
the specifications are a mixture of different (special-) offers from let providers (buyvm, hostslick, greencloud, liteserver). i am aware that i am very much around the lower end when it comes to the price. it is very important to me that the server is located in frankfurt am main. for all other specifications, i am also willing to make sacrifices.
  • @mxmla @Advin do you have something like above ?
    Thanked by (1)lapua
  • mxmlamxmla Hosting Provider
    Not in Frankfurt am Main, Germany sorry :/
    We could do the following if you're interested:
    2.5GB RAM
    50GB NVMe
    2 vCore Ryzen CPU
    6TB @ 1Gbps Bandwidth
    I was going to say $47.28 but to stay within your budget and add a little bit of buffer for conversion rate, we could do $35/YR.
    Frankfurt is 5900X for where you'd land. And just another note, we're swapping out IPv4 addresses on the server I could put you on (this week on Thursday) so if you do go ahead, the secondary IP will be the one it gets switched to then.
    https://ffm.lg.virmach.com
  • AdvinAdvin Hosting Provider
    edited September 2022
    Thanks for the mention, I don't think we can do Ryzen servers under 8GB of memory unfortunately :'(
    We used to have 1-4GB Micro KVM servers in Germany with 5950X but we stopped selling them a while ago
  • Just to be clear, are you looking for dedicated CPU, or fair share?
  • afnafn
    netcup maybe? 2.99/m -> 36 per year
    2.5GB RAM
    50GB NVMe
    2 vCore Ryzen CPU
    When will you have more ISOs available for your Ryzen services?
  • dfroedfroe Services Provider
    @afn said: netcup maybe?
    There's no netcup in Frankfurt.
    vCPU (fair share)
  • afnafn
    @dfroe said: There's no netcup in Frankfurt.
    oops, my bad... I confused their locations with someone else (ionos)...
    **Check this: **Frankfurt am Main -> https://cloud.ionos.com/data-centers ( I have no idea about their prices tho)
    Curious question tho, for people (like you) pin-pointing a specific city (not just the country), does it really matter that much in terms of latency for your use-case?
