Netherlands dedicated servers. (Help pls)
AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
edited March 25 in Requests
I have been out of the picture for a while. Who is the go-to for cheap dedis in NL now?
Used to be i3d, who had the €30 E3's, which they still have just at €170 now (lol) and Wordstream, who still have a few but with very fixed options in less than ideal configs.
Anything considered, cheaper the better, must provide IPv6 /64 minimum /48 preferred.
Cheers.
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA, USA.
FREE tokens on sign up, try before you buy. | Join us on Reddit
Thanked by (2)Not_Oles jureve
    Scaleway/Offline.net used to have 20€ NL dedis.
    Worldstream used to sell 10€ NL dedis, but no more
    OneProvider just ends up selling mostly trash
    LeaseWeb was mentioned for like 30€ dedis on OGF
    Thanked by (1)AnthonySmith
  • Oneprovider collects them into one page. Amsterdam is in netherlands, right?
    https://oneprovider.com/en/dedicated-servers/amsterdam-netherlands
  • AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
    I just never trusted that site, no specific reason
    At OVH, even for a 10€ server, they replace the disk without asking.
    At OneProvider, they argue, until you loose it.
    Leaseweb and Hostkey
    edited March 26
    I should have said I am Excluding spinning rust and will consider SSD at a push depending on the deal, what i found so far.
    Scaleway's cheapest (viable) option on NVMe is actually pretty good: AMD Ryzen™ 5 PRO 3600, 6C / 12T - 3.6 GHz, 32 GB, 2 × 1 TB NVMe €39.99
    HostKey's cheapest option seems to be €174 /month, not ideal, maybe thats not normal for them idk.
    LeaseWeb seems to be €84 /month for an E3-1230v1 with 16GB Ram
    Worldstream most suitable offer is €66 with SSD's
    Seems there are still pretty cheap dedis in NL generally but many of them use sata or tiny SSD, is what it is.
    If any hosts read this and have deals, please post them :)
    CPU: Not the highest priority
    RAM: 32GB Minimum
    Disk: NVMe preferred, ssd considered if multiple, no HDD.
    Well, i had 4 servers with them... for 1 month each, which is a total of 3 months since i got 2 servers with them at one time. So not saying much... :lol:
    Did not know that. I avoided OVH for some reason. Cant recall why...
    @somik said: Did not know that. I avoided OVH for some reason. Cant recall why...
    in fairness, there are lots of reasons to avoid them, you need to know what you are getting into to make it work haha.
    It looks like I avoided them as they have a limited selection of OS for your server and their network speed for cheaper servers are bellow 1gpbs.
    just a mega reseller of all hosting in the word, not a real hosting provider.
