Known Issues - LES v2 - progress tracker
edited July 29 in General
  1. Drafts - broken; keeps putting your draft/auto save back in the input box.
  2. Flashing - (On by default) - You can turn this off with the slider on the nav bar, top right (it has 4 stages)
  3. Contrast on unread threads and bring back yellow 'new post pill box'
  4. Themes icons on Nav bar - make a single icon or move back to 'edit profile'
  5. Overlap on mobile nav bar issues (Probably self resolving by item 4 but will check)
  6. Remove up/down votes on comments in profiles.
  7. Attempt more style consistency.
  8. Limit who can use the image upload feature to avoid abuse ( CP etc )
  9. Fix the permissions preventing anyone using the image upload features.
  10. Check header items on smaler resolutions between desktop 1080 and mobile, maybe bring the burger in sooner.
  11. Sign out button not working.
  12. Check to see how hard vote amplification is based on time.
  13. POST issue on changing notification preferences, error but changes anyway.
  14. Karma flair name being included in quotes e.g. @john is @johnWinning
  15. Add better contrast on flair-based titles, hard to read.
  16. Generally tone down maximum karma flair.
  17. Add S3 and Free Hosting to list of Services Offered for providers page https://lowendspirit.com/registered-providers
  18. PM system is broken. fixed
  19. Registration approval broken (Being replaced with Cloudflare Turnstile anyway)
  20. Badges from store alignment to be worked on, sitting too high.
  21. Karma Store Badges require a page refresh on post for the OP to see it.
  22. Transparency not respected on karma badges.
  23. PM to different member groups may have some issues.
I am collecting issues reported here: https://lowendspirit.com/discussion/11094/welcome-to-les-v2-updated-please-read-op-again
There were always going to be issues; it was a MASSIVE update. I am going to let the reports build up over the weekend, filter out the duplicates and start work on fixing everything I list above on Monday.
I am keeping this closed to avoid duplication and cross-talk; this is just so you know what I know :)
    Flashing / karma flair off by default now - changes live.
    Yellow pills are back for unread posts
    Drafts are now working properly, you will still have any existing drafts in any existing threads; however, once you post again in that thread, the old draft will be deleted and won't keep coming back.
    PM system fixed
    Overlap was caused by having too many icons, theme selector was moved to a single dropdown selector; 2 stones were solved with 1 bird.
    up/down votes from user profile > comments removed.
    updates to the up/down votes styling and generally toned down max flair to be just a glow now.
    Image upload for end user now available once a user has 10 or more karma points
    Sign out function fixed.
    Karma flair generated on Usernames have better contrast
    Header bar updated. Instead of deleting the links as requested I moved them to the user icon functions (your avatar on the top right) some people might find them useful, unsure about just removing all together.
    Header bar more compact, should stop split line words on lower resolutions now, it still happens at the very threshold between low resolution and mobile burger menu, maybe around 20px in it, for now I hope thats enough.
    Better contrast on the green for the dark theme done.
    Notification preferences fixed, (yet another php 7 > 8.4 issue)
    Notifications on save match the dark theme now.
    Flair tag no longer appended to username when quoting.
    badge alignment fixed, +1px gap between karma store items as standard.
    karma badges display without refresh in the thread after post (except for the first application, when they are fetched and fed to the cache)
    Drafts moved to user menu LowEndSpirit - VPS Hosting and tech forum
    hosting providers "edit profile", notification edit signature links etc restored.
    S3 and FREE Hosting added and provider profile options.
    All the major bugs have been taken care of now, so removing this from announcements.
