MrVM Zerotier not working. (Solved)
edited May 2020 in Help
Does anyone know why the zerotier does not working in MrVM NAT VPS?
My TUN/TAP is enabled in control panel. Wireguard is working.
Edit:
Add this picture
Resolution:
https://github.com/zerotier/ZeroTierOne/issues/699#issuecomment-456768506
Thanked by (2)mikho bdl
MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
  • What port is it trying to use?
    The default one should be localhost:9993. I thought localhost does not need the public ip port?
  • @go626201 said: zerotier
    Interesting. What is the use case for this?
    edited May 2020
    Its like zinc but with a fancy webui, basically zinc for lazy people.
    You can setup a giant peer to peer LAN.
    Thanked by (1)NanoG6
    It can use for grouping a numbers of network device into a private virtual network without a public ip.
    Within the network every device can communicate as similar to all located at local network.
  • mikhomikho OG Supporter
    Kudos for posting this!!
    Not everyday I see someone posting the solution to their problem when they find it themself.
    Thank you!
    Thanked by (1)skorous
  • Lol, I actually had the same issue, and I thought it was an OVZ thing.
    Thanks for the post!
    Thanked by (1)mikho
    Thank you!
    Actually i almost give out already,because i have search for resolution for about 8hours.And i thought it was the kernel problem,because last year i was using i-83,i didn't met this problems.
    I think it is kernel problem,newer version should had fix for it.
    Thanked by (1)sanvit
    I have never used an i-83 product, I might be out on the deep end.... I have a hard time to think that i-83 would have OVZ7 last year.
    And the kernel is newer on OVZ7 then OVZ6.
  • edited May 2020
    Their technical support really not "quick" response...(they never send replies back)
    There was a few weeks that their SG Node being abuse by someone,and they not trying to fix it...(Maybe i was wrong,might just be a network issue,but i don't think so,since the latency is very ridiculous - 500 to 800ms to 8.8.8.8 or 1.1.1.1)
    And that why i change to use your service,but with bandwidth limit. =)
