TierHive tokens - Trial, topup, test, whatever
AnthonySmith
AdministratorProviderOG
A day late again; busy week.
Free for anyone to use or share this time.
You must be signed in to view this section.
Limited to 1 use per account
Value: 0.023456
Max uses total: 30
yum yum
Thanks! 🤩
Redeemed and Thank you!
I was hoping that there would be a way for users to generate (multiple) vouchers by now. Just the $0.02c that I took, here's mine back.
And I, for one, welcome our new insect overlords.
It's on the list, it's a long list and shit keeps going south so has to take priority.
Days without incident: 0
Other than attracting a certain sort of client (cheap, bitchy, using), what issues are you running into?
Not that sort of issue, it's more things like discovering we never considered people might try to make their own automation and add ports to a VPS less than 1 seconds after it has been created so the logic of 'does the VPS already have assigned ports' if yes treat it as a reinstall, which then assumes the NAT is already in place when it's not so ports are only ever assigned in the database and nothing works.
Takes the better part of a day to triage from Nd out what exactly they did and what to update to fix it.
Something like this happens near enough every day, so that's why we are not racing to get out of Alpha
Thanks for the token!
Pulsed Media: The Eternal Väinämöinen Sale: Seedboxes and storage boxes from €1.99/mo, priced for life. (ref/aff link)
Thanks for another free day of the vm's running.
Thank you for the little bit of token bonus.
So sad, always late to claim voucher
Most people treat AI like gospel. Those people fail.
Treat AI like a drunk intern with occasional good idea, And you will succeeds.
Thank you!
