TierHive Free Credit vouchers x 100
https://tierhive.com
Do not reshare unless strictly with your own friend group in small online niche communities i.e. no Telegram groups or similar (apply common sense)
1 use per account, and 1 account per person; existing users can also use if they need it or if it helps.
Value 0.1 tokens per use.
You must be signed in to view this section.
TierHive is now in 16 locations
  • Thank you very kindly
  • I can't see it, but I hope TierHive continues to progress in the future by offering affordable services.
    waifuwall.com | Anime Girl Wallpapers - Uptime Status
  • Great thank you, that's +21 days for a 128MB/1GB AlpineLinux VPS!
    New rule wanted: "each post in this forum needs to be polite, constructive, and joyful"!
    how about now :)
  • i didn't know we have karma :'( At least i have 4 and not 0 somehow haha.
  • Thank you once again for your generousity, for keeping my service idling :)
    now you have 5
    You are most welcome! we love the idlers
  • Many Thanks <3
  • Many thanks for the sweet tokens
  • damn i shouldnt have given @WSS all my dicks karma
  • @AnthonySmith TierHive seems to have more than 2,000 customers/users! Is that accurate?..
    chama +3
    Well over that now; why do you ask?
    We get around 50 new users per day at the moment; live VPS status goes up and down wildly all day, many people use them for a few hours and then destroy them to save money. We have around 2000 VPS shut down and only billing for storage alone.
  • Thank you gentlesir.
    now you have 5
    Thank you! Received<3
  • JabJab TOP Member 2027
    I think one day I should create account and just start farming those free credit for future use :D
    And I, for one, welcome our new insect overlords.
  • @AnthonySmith said: Well over that now; why do you ask?
    Congratulations for your success!
    One feedback: I did have the "Low Performance" for the Disk/IOPS on my VPS and it was terrible: 7 min to boot on Alpine OS because of that.. :s I think the highest level is a must!
    Hmm that doesn't sound right I will test that now
    From deploy to prompt was just under 3 minutes 128mb ram, 1GB disk, low everything.
    Reboot to prompt was 28 seconds.
    My best guess and it's just a guess, you have the 'button' module missing or unlinked so acpi is not responding, libvirt default is a 300 second timeout before it destroys, and if you have anything else installed on a micro that's gonna add to the time.
    Just on my phone and totally guessing though happy to investigate in the morning if you want though.
  • Any plans to add HK as your #17 location? =)
    I have 3… I read more than write, so it’s unlikely I will get enough karma to reveal the code before it runs out of uses. :(
  • edited October 23
    @AnthonySmith said: My best guess and it's just a guess, you have the 'button' module missing or unlinked so acpi is not responding, libvirt default is a 300 second timeout before it destroys, and if you have anything else installed on a micro that's gonna add to the time.
    Thanks for taking the time to try! It was at the UK location. It was linked to the disk/IOPS because the booting delay dropped after the increase of performance level. I actually kept the screenshots, see below! Nothing changed in the config between the two steps except the disk performance level setting. Also my Alpine version is: 3.22.2 (yours was 3.24.1 - I don't know if I should upgrade?).
    BEFORE (@ lowest disk performance level):
    image-2026-10-23-055859566
    AFTER (@ highest disk performance level):
    image-2026-10-23-060018533
    Finally, my AI told me to give you this, and said "an ACPI issue would delay the shutdown time not the boot time":
    test:~# lsmod | grep button
    button                 24576  0
    test:~# cat /proc/bus/input/devices | grep -i -A4 power
    N: Name="Power Button"
    P: Phys=LNXPWRBN/button/input0
    S: Sysfs=/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
    U: Uniq=
    H: Handlers=kbd event1
    test:~# ls -la /dev/input/
    total 0
    drwxr-xr-x    2 root     root           180 Oct 21 03:38 .
    drwxr-xr-x   13 root     root          2500 Oct 21 03:38 ..
    crw-rw----    1 root     input      13,  64 Oct 21 03:38 event0
    crw-rw----    1 root     input      13,  65 Oct 21 03:38 event1
    crw-rw----    1 root     input      13,  66 Oct 21 03:38 event2
    crw-rw----    1 root     input      13,  67 Oct 21 03:38 event3
    crw-rw----    1 root     input      13,  63 Oct 21 03:38 mice
    crw-rw----    1 root     input      13,  32 Oct 21 03:38 mouse0
    crw-rw----    1 root     input      13,  33 Oct 21 03:38 mouse1
    test:~# ps aux | grep acpid
     1581 root      0:00 /sbin/acpid -f
     2544 root      0:00 grep acpid
    test:~# ls -la /etc/acpi/ 2>/dev/null
    total 5
    drwxr-xr-x    3 root     root          1024 Oct  8  2025 .
    drwxr-xr-x   40 root     root          3072 Oct 22 17:22 ..
    drwxr-xr-x    2 root     root          1024 May  1 20:00 PWRF
    total 5
    test:~# ls -la /etc/acpi/PWRF/
    total 3
    drwxr-xr-x    2 root     root          1024 May  1 20:00 .
    drwxr-xr-x    3 root     root          1024 Oct  8  2025 ..
    -rwxr-xr-x    1 root     root            19 Nov 21  2025 00000080
    test:~# ls -la /etc/acpi/events/ 2>/dev/null
    test:~# cat /etc/acpi/handler.sh 2>/dev/null
    test:~#
    Aaah ok @jcn50 ok so it's the older template I understand why now, that's the reason I recently 'rerolled' the new one, the official ones from alpine are super inefficiently made so they work on everything which means a lot of bloat and they have an odd acpi issue.
    I left 3.22.2 alone so as not to mess with recipes that people might have pinned to the old version, maybe I should optimise that too.
    The fun of alpha :) Ideally redeploy with the new template if that's not too much trouble or we have a blog entry on optimisation for alpine if you want to apply that yourself.
  • @AnthonySmith said: The fun of alpha Ideally redeploy with the new template if that's not too much trouble or we have a blog entry on optimisation for alpine if you want to apply that yourself.
    OK thank you! I guess there are no ways to upgrade without a redeployment because the kernel of the container won't change?..
    Yeah, cherry picking the alpine blog post from the TierHive blog will get you 90% of the way though.
    how about now :)
  • @AnthonySmith
    1) how to change the hostname?
    2) how to change the subnet?
    of an existing VPS
    @jcn50 said:
    @AnthonySmith
    of an existing VPS
    Hostname changes in the panel are coming; you can't yet, because it's tied to the cloud-init config and has wider implications. You can't change your subnet; I can't see any common justification for anyone to ever need to?
  • edited October 23
    @AnthonySmith said: I can't see any common justification for anyone to ever need to?
    Because you don't think about the (proper) hostname when you deploy ; and I have made a mistake for the subnet of a deployed VPS (my mind skipped the "Private IP" dropdown).
    Could you add a "Copy" function along with the "Migrate" one?.. That would really save me a lot of time!
    Are the backups of 1x VPS location available to another VPS in the same location?..
    @jcn50 said: Because you don't think about the (proper) hostname when you deploy
    You can change it in the VPS directly in the mean time and this only impacts reinstalls.
    @jcn50 said: and I have made a mistake for the subnet of a deployed VPS (my mind skipped the "Private IP" dropdown).
    So do you mean change the IP not the "entire subnet" ? if so that is coming, also multiple IP's is coming, but we wont be doing full subnet changes I dont think.
    @jcn50 said: Could you add a "Copy" function along with the "Migrate" one?..
    Already in our sandpit version but probably wont be released until beta due to the amount of changes we need to consider for cloud-init a copied VPS right now would have no functional networking as it would hav ethe old VPS's IP and MAC. this has a log of subtle complexities for us on many levels, but its very much in progress.
    @jcn50 said: Are the backups of 1x VPS location available to another VPS in the same location?..
    You can attach a VPS's backup to any other VPS anywhere, you will see the backup volume as /dev/vdb in the OS, currently a full restore only works for the original VPS it was made against, again because of the networking considerations mentioned above.
  • edited October 23
    @AnthonySmith said: So do you mean change the IP not the "entire subnet" ? if so that is coming, also multiple IP's is coming, but we wont be doing full subnet changes I dont think.
    Yes yes, the Private IP of the VPS~ not my own entire subnet.
    @AnthonySmith said: Already in our sandpit version but probably wont be released until beta due to the amount of changes we need to consider for cloud-init a copied VPS right now would have no functional networking as it would hav ethe old VPS's IP and MAC. this has a log of subtle complexities for us on many levels, but its very much in progress.
    I can imagine the mess of a "Copy" function but it should be less complicated than a "Migrate"~ and also you could just do:
    1) take a backup
    2) create new VPS
    3) restore backup on the new one
    which is what I am going to try manually now.
    edited October 23
    @jcn50 said: I can imagine the mess of a "Copy" function but it should be less complicated than a "Migrate"~ and also you could just do:
    1) take a backup
    2) create new VPS
    So what do you do about the fact that it has the same IP and mac address as the other server you made a copy of? I know its simple on a single VPS manual scale, but its much less so when you have a mesh system that bridges your servers between all locations so they operate as 1 big lan, checking for network isolation between subnets and origina, HAProxy validation and L2 protection to consider and cloud-init data.
    edited October 23
    Anyway, as a tip if you want to do it quick, just spin up a new VPS, put them both in rescue and dd it over ssh, you have a copy, you can then manually update what needs to be updated.
  • Thanks @AnthonySmith ! Another suggestion (to add to the huge list): the ability to add a comment with the forwarded port field. ;)
    yep, thats trivial, I will add that to the list
  • A question for @AnthonySmith I deployed two backends with HAProxy. Is there a way to make HAproxy trust caddy's self-signed TLS cert on both backends? I am trying to set up zero trust where the traffic will flow to haproxy, it will then be re-encrypted and send to backends.
    No, for that you need TCP mode, we are deploying it eventually, we have it working in the internal version.
    For now, it's not possible using NAT IPv4 unless you use non-standard ports for SSL.
  • @ponpon said: Any plans to add HK as your #17 location?
    @AnthonySmith : yeah, what will be your next location? ;)
  • @AnthonySmith said: unless you use non-standard ports for SSL.
    This is absolutely fine until you release TCP mode. Do I need to open a ticket to do non-standard SSL ports?
    Either Los Angeles or Miami most likely, but not ruling out India.
    We took a bit of a break from expansion and focused on availability/capacity instead, as some locations were constantly out of stock or overloaded, that is mostly solved now so we might look to start adding locations again within the next month.
    I have not been well, so we are a few weeks behind where we planned.
    Nope, just allocate a port from the VPS management page:
    If you want a custom internal port (I suggest 443 for compatibility) then enter it there and then the panel will issue e.g. 6789 > 443 so https://domain-pointed-to-external-ip.com:6789 will reach your VPS on e.g. 10.100.101.102:443
    I hope that makes sense.
  • @AnthonySmith said: I hope that makes sense.
    It does, thank you. However, the issue is I am trying to to use HAproxy to have 2-3 backends and port forwarding does not help with it. Is there absolutely no way to force HAproxy to send HTTPS traffic to backends? I guess I would have to wait for TCP mode then.
  • edited October 23
    How do I get more karma to see these posts? Is it like the thanks on LET?
    edited October 23
    Yep, just being active in general I guess.
    Contribute a post every now and then I. Something you like, do, find interesting, want etc etc.
    You have got more karma than me :lol:
