ServaRica Local AI VPS: dedicated Tesla P40 / V100 excellent tok/s for Strata (Qwen3.8-Flash-Next 12
servarica_haniservarica_hani ProviderOG
Hi LES!
Today we're introducing our fine-tuned GPU VPS service.
These are large VPS instances with one or more full GPUs passed through to each VPS. The GPU is fully dedicated to your VPS and isn't visible to the host or to any other VPS.
Platform
  • AMD EPYC 7552 hosts
  • Linux or Windows templates with GPU drivers preinstalled
The specs aren't random. We ran Strata on both cards and built each plan around the RAM and SSD needed to run Qwen3.8-Flash-Next (125B) on a single card at full speed. We also use some of these VPS internally for very large log analysis and chat analysis tasks.
Benchmarks (on our own VMs)
Strata – Qwen3.8-Flash-Next 125B, 128K context
GPU Generation (write) Prompt processing (read)
1× P40 39–41 tok/s ~450 tok/s
1× V100 72–79 tok/s ~1,160–1,450 tok/s
llama.cpp – smaller models run even faster
  • Qwen3.6-35B-A3B: up to 73 tok/s on a P40
  • Qwen3.8-35B-A3B Distill: up to 154 tok/s on a V100
Full benchmark tables, a step-by-step Strata setup guide, and an honest list of what these cards can't do are on each plan page.
Plans (USD/month)
Tesla P40 (24 GB VRAM per card)
Plan Cores RAM NVMe VRAM Price
P40 ×1 10 dedicated 40 GB 500 GB 24 GB $139 Order
P40 ×2 20 dedicated 80 GB 1 TB 48 GB $278 Order
P40 ×3 30 dedicated 120 GB 1.5 TB 72 GB $417 Order
Tesla V100 (32 GB HBM2 per card)
V100 ×1 8 dedicated 35 GB 400 GB 32 GB HBM2 $179 Order
V100 ×2 16 dedicated 70 GB 800 GB 64 GB HBM2 $358 Order
V100 ×3 24 dedicated 105 GB 1.2 TB 96 GB HBM2 $537 Order
Bandwidth – every plan lets you choose:
  • 100 TB/month on a 10 Gbps port, or
  • Unlimited transfer on a 250 Mbps port that grows by 1 Mbps per day up to 1 Gbps
Why run this instead of using an API?
  • Privacy: It's your server. Nobody sees your prompts or trains on your documents.
  • Flexibility: Switch models whenever you like.
About servaRICA
servaRICA is a VPS and dedicated server provider based in Montreal, Canada.
We own and operate our own network and infrastructure, delivering reliable service since 2010.
FAQ
  • Terms of Service (TOS) and Acceptable Use Policy (AUP): View Here
  • Accepted Payment Methods: PayPal, Alipay, credit cards, cryptocurrencies (BTC, ETH, etc.)
Thanks
  • You could try STATA with the lowest tier you offer can post the numbers here? :D
  • @servarica_hani said:
    Plans (USD/month)
    The pricing is reasonable, given the specs and electricity costs. You can do a lot with a single gpu
    I've used variants (lower ram) of both tesla cards locally in the past. They're both quite usable. You can buy used cards to run locally. Just keep in mind the heat generated (you need good airflow), maybe not a bad thing given its getting cold in the northern hemisphere. If you go v100, I've had luck with the server version with an adapter board.
    damn, that's an interesting offer!
    the numbers here and here are actual numbers on these VPS
    https://servarica.com/plan/683/
    https://servarica.com/plan/688/
    actually the V100 was tested with slightly less ram so we will do the test again with exact ram and update the numbers which i assume will be better
    Strata with Qwen Moe model really gave life to lower GPU tiers
    These numbers are from actual long tasks we currently run the cards on
    and this model Qwen3.8 FN is much better than I initially expected
  • Did you test with all under load? Memory bandwidth still shared on the Host though.
    My assumption is, that if each card is under load with STRATA, the numbers will be lower.
    good question
    no I didnt
    I assume the difference will not be big but it make sense to test it
    will do it and report back
    good question
    no I didnt
    Got the numbers
    We ran all the gpu simultaneously on very long task and we measured it for prefill
    then we did it on decode tasks
    the performance didn't affect that much , its about 2-3% on average:
    prefill : 0.5 to 2.5% , decode: 1.5 to 4%
    the output is about 75.5 tok/s ..
    which is within the range above
    Got the numbers
    Very nice! Are you putting them on bf sale this year? :)
    Got the numbers
    Thanks
    Not on GPUs , we are working on some other offers but for these we have few servers and I think any excess will be used by us internally ,
    If we continue like that we will have more use cases than what our GPU fleet can handle
    Yeah, the GPUs deals are very good, especially if you're into Strata
  • Nice, but I'm not sure if an AI VPS can really be considered "local" given that it is in the cloud.
  • Landing page is definitely vibe coded.
    I like how the per-month all in pricing is more predictable than spot GPU pricing. Only question is: any chance on adding per-week billing?
  • servarica_haniservarica_hani ProviderOG
    Yeah , I mean this is not a model through API so we dont see what you use the gpu for
    maybe the correct name should be private AI not local AI
    similar to VPS (Virtual Private Server)
    Actually many parts of it that was done by AI was done using the local models on our VPS :)
    but it depend on your definition of vibe coding these pages although AI were using in writing them took weeks of working on requirements, specs , code quality and so on
    I am a dev myself and I just treat AI as a faster intermediate developer so I work alot on the features ,specs and let the AI do the final dev work just like any employee
    It's a nice product. Might consider a v100 next month if you have any left.
