Custom Hosting Control Panels — Built to Your Spec on a Proven Core
girginos
Provider
We build white‑label hosting control panels tailored to your business.
Not another one‑size‑fits‑all panel — you tell us the stack, the services and the OS you run, and we ship a panel that works exactly the way you want, under your brand.
We don't start from zero: the panel is built on GirginOS core — a mature, security‑first, already‑optimized control‑panel engine (per‑tenant isolation, hardened defaults, automated SSL, backups, email, DNS, WordPress tooling, reseller/white‑label, REST API). We adapt, extend and re‑brand it to your requirements, then hand you a panel you own.
Build to order — you choose the stack
Tell us what you run; the panel is assembled around it.
🗄️ Database / SQL
- [ ] MariaDB / MySQL (per‑tenant databases, isolated users, quotas)
- [ ] PostgreSQL (custom/enterprise)
- [ ] Per‑account DB isolation (separate users, no cross‑tenant access)
- [ ] Remote / dedicated DB server
- [ ] Clustered / HA SQL — Galera / replication (enterprise, see below)
🌐 Web server
- [ ] NGINX
- [ ] Apache
- [ ] NGINX + Apache (reverse‑proxy)
- [ ] Per‑site PHP‑FPM pools (tenant isolation)
- [ ] Multiple PHP versions (7.4 → 8.x), ionCube/loader, per‑site selection
- [ ] OpenLiteSpeed / LiteSpeed (on request)
📧 Mail server
- [ ] Postfix + Dovecot (IMAP/POP3/SMTP)
- [ ] DKIM / SPF / DMARC automation
- [ ] Per‑domain / per‑mailbox quotas
- [ ] Webmail
- [ ] Outbound SMTP policy / rate limiting / anti‑abuse
🧭 DNS server
- [ ] Authoritative DNS (BIND / PowerDNS)
- [ ] DNSSEC
- [ ] Central DNS templates (A/MX/SPF/DMARC/DKIM applied to new domains)
- [ ] External DNS provider integration (API)
💻 Operating system support
- [ ] AlmaLinux
- [ ] Rocky Linux
- [ ] RHEL
- [ ] Debian / Ubuntu (on request)
- [ ] Windows Server (IIS / MSSQL) (where applicable)
Don't see your exact stack? Ask. The core is modular — we add what you need and leave out what you don't.
Included out of the box
Every panel ships with the capabilities the core already does well:
- Tenant isolation — CageFS‑style filesystem isolation + per‑account PHP‑FPM; one site can't reach another.
- Security first — malware scanning (ClamAV + custom rule engine), fail2ban + nftables firewall, WAF (ModSecurity + OWASP CRS), live kernel patching, CVE awareness.
- Automated SSL — Let's Encrypt issuance & renewal, per‑domain.
- Backups — scheduled, per‑site, with off‑site targets (object storage / remote) and restore testing.
- WordPress tooling — install, hardening, integrity checks.
- Reseller / white‑label — your brand, your logo, reseller plans and quotas.
- Billing integration — WHMCS module.
- Automation — documented REST API + webhooks for provisioning and integration.
- Resource limits — CPU / RAM / I/O (cgroups), disk & inode quotas.
Enterprise add‑ons
For larger or mission‑critical deployments, we design and build on top:
- HA cluster — multi‑node high availability, failover, shared/replicated state.
- Central management — one control plane for many nodes/hosts.
- Multiple / clustered SQL — dedicated or HA database tier.
- Custom modules — bespoke features, integrations (CRM, billing, identity/SSO, payment), workflows unique to your business.
- Scale & performance tuning — for high‑density or high‑traffic fleets.
These are scoped per project — we return a clear architecture, timeline and fixed price.
How it works
- Scope — you send your requirements (stack, OS, services, branding, scale). We return a clear plan + fixed price.
- Build — we adapt/extend the core and brand it to you.
- Deliver — a panel you own, on your servers, under your name.
- Support — maintenance, security updates and new features as needed.
Why build on our core instead of from scratch
- Proven & optimized — security hardening, tenant isolation and performance are already solved; you're not paying to re‑invent them.
- Faster & cheaper — custom where it matters, standard where it doesn't.
- Independent & white‑label — your brand, no third‑party licensing lock‑in on the panel itself.
- Security‑first by design — isolation and hardening are the foundation, not an afterthought.
Interested? Tell us your stack (SQL / web / mail / DNS), your OS, your scale, and whether you need any enterprise features (HA, central management, custom modules). We'll come back with a scoped proposal.
Pricing: Custom quote based on project scope, required features, and integrations. Contact us to discuss your requirements.
📩 Contact:
Telegram: girginos
Whatsapp: https://wa.me/girgin
🔗 More:
https://girginos.io/en/custom-solutions
(White‑label custom development — your brand, your infrastructure. Reply here or DM.)
AI written?
Fair question. We use modern tooling, AI-assisted development included, the same way most teams do today. But nothing ships on trust. Every change goes through the same verification pipeline whoever (or whatever) wrote the first draft:
Automated test gate: the full Go suite (3,300+ tests across 100+ packages) plus a separate API contract suite has to pass before anything is merged.
Mutation testing on critical paths: we inject faults on purpose to prove the tests actually catch them, not just that they pass.
Static analysis and security scanning with Aikido and Corgea, plus secret scanning (gitleaks) on every commit.
Real-server rehearsals: each release candidate is installed and exercised on disposable VPS instances (SELinux enforcing) before it’s published, and rollback paths are tested too, not just unit tests.
Independent review passes, each focused on a different area (security, regressions, migrations), before release.
The panel also makes zero third-party requests (fonts and assets are self-hosted, strict CSP), and that’s audited across every page.
If you spot anything that looks off, we’d genuinely like to hear about it. Bug reports are welcome.
Here we go again.
ExtraVM - KVM NVMe VPS in USA, EU, APAC -|- RackColo - Find Colo -|- SRVCheck
Wow!
100+ packages for a hosting panel? when next supply chain attack?
Has it been audited by a third party?
Yes, we receive support from third-party security companies.
https://www.aikido.dev/
http://www.corgea.com
