Uhm, I'm trying to reach minivps.vpsadmin.inceptionhosting.com as that was where solusvm was installed (or well, my password manager pointed me there) but it looks like it doesn't work anymore?
I have 2 masters because back around 9 years ago I was getting a ton of issues being caused by latency mainly impacting the VNC connections, as they go via the master, so in India you would be hitting the uk > phoenix > back to the uk > back to India which was making things not work great.
Nevermind me...
Mine is at https://vpsadmin.inceptionhosting.com
https://webhorizon.net
that is for non nat vps
i see my NAT VM's there!
Hmmmmm
it's the same as all the others https://vpsadmin.inceptionhosting.com
2 possibilities.
1) you are using the wrong username.
2) they lapsed and got terminated. (obviously not by your screenshot)
I am 95% sure I know who you are so I will trigger a vps info email so you can get a username reminder.
its common for people that have other services or have had other services to use an old username e.g. ukvps1234 when they should be using minivps1234
Hope that helps.
Ant.
I was using the wrong username!
Thanks
No worries, it is incredibly common.
Wait what. 90 cents annually? Holy...
I'm the 85%. Also Elon likes memes hence he's an idiot.
Also if it helps someone else, the solus domain for IH's Phoenix vps is https://usadmin.inceptionhosting.com
I figured it out just in time before I hit submit on an unnecessary ticket.
I just was not expecting a different solus (master?) within same provider.
It was part of a bundle deal, it is just how whmcs handles it
however for the NAT ones everything is on https://vpsadmin.inceptionhosting.com even if its phoenix, just to confuse things.
I have the links on the main site on the top right though for everything https://inceptionhosting.com
