which domain registrar offers the most number of tlds?
mikhomikho AdministratorOG Bash Me Gently
Curious if someone knows which registrar offers the most number of tlds?
With a proper search function :)
What I'm after is actually a place where I can input a word, or a phrase, and see what tlds are available.
perhaps someone here has coded a function like this already?
    Namesilo has lot of tlds not sure if they are the very best in number of ltds.
    That is one of the sites I'm using.
  • Netim?
    "The imitator dooms himself to hopeless mediocrity." — Ralph Waldo Emerson
    @thedp said:
    Netim?
    990 + .... me like :+1:
    It is the very best option for me. The unique problem they not sell .es or country ltds etc. But for general use their prices are usually the very best. I need to stop buying idling domains but usually they are too cheap
    @mikho said:
    @thedp said:
    Netim?
    Not the best search function though....
    My exact usage would be ....
    Let's say I want to find all available tlds for my domain mrvm.
    Namesilo has the checkbox to filter out registered (and premium) domains, which eliminates them from the list.
    Netim search is divided into groups :( and no filter for already registered domains.
  • @mikho said:
    @mikho said:
    @thedp said:
    Netim?
    Then maybe try EuroDNS.
  • @mikho said:
    @mikho said:
    @thedp said:
    Netim?
    Try dondominio.com just putting mrvm and appears all the domains . i guess is not 900+ but could make the trick for you. They are expensive and renewal are even more expensive but for search are OK
  • gandi.net
    eurodns.com
  • Porkbun it can search many domain extension
  • beaglebeagle OG
    edited April 2021
    I've got domains split among Namesilo, Porkbun and OVH (for EU domains). If I'm looking a domain across mutiple TLDs I use https://tld-list.com/
  • @mikho I am quite satisfied with Porkbun, "show all extensions" search:
    https://porkbun.com/checkout/search?q=janevski&all=1
  • Not sure about many, but big fan of porkbun because they have specials that cover not just 1st year but all
  • Not_OlesNot_Oles Provider
    edited April 2021
    Hey! If you're not ready to buy the domain immediately, maybe, when you return a few days later, it will be registered by a domain name investor? Maybe not the best idea to inform domain name businesses of your interest and the potential interest of others in the name?
    When I got metalvps.com I also searched baremetalvps.com. The latter was available at the time I searched, but when I returned a few days later it was registered to a speculator and available for $1,000.
  • mhubudmhubud OG
    edited April 2021
    I also use https://tld-list.com/ and have found it to be incredibly useful. Searches across registrars, can specify character count, price, etc. Can sort output on cheapest registrar, renewal price (since that's often a gotcha), etc. Used it recently to find affordable 3-char domains (nicely named).
    Also, while it doesn't cover all tlds, https://micro.domains/ was useful in finding short domains (but pricing info was a bit inaccurate, so just use it as a guide to availability).
    Was it GoDaddy?
    Not GoDaddy. Also not Porkbun, whom I recommend and with whom I have enjoyed only good experiences. 👍
  • Gandi has a lot, OVH has a lot, tld-list.com aggregates a bunch. At one point I scraped a number of those sites (mostly for price comparisons) and I made a csv: https://willie.linuxiso.party/domains.csv
    It is way out of date though.
