Free Shared Hosting - Powered by Directadmin panel
Hi Lesbians!
We have few servers which have no use for us. So we have decided to provides free shared hosting services for people who need or want to start their first website or blog.
Forever Free
Basic Hosting to start
1 GB SSD Storage
Up to 3 Domains
Up to 2 Sub Domains
Up to 5 MariaDB Databases
5 Email Accounts
1 FTP Accounts
1 TB Bandwidth Monthly
Free SSL Certificates
Location: Germany (Hetzner), more location will add soon
Basic Support
Order now
You can find all details about resources limits form the page
No Credit card or anything needed.
Just don't use vpn or proxy to order and everything will fine.
It's our request please do not abuse the service, order only if you really need it.
**Data Protection or GDPR!??**
We are not an European company so we may retain some of the data for accounting purposes only.
But as this is a free plan, so no invoice generate. So we don't need to retain any of your data.
Once you cancel the service, Open a ticket and ask us to remove your profile and we will remove it complete.
We do not store or share any data of our client exept for those requires for accounting and tax filing.
For mods, Please remove the post if it's violated any rules here.
  • edited April 2023
    Also added: If you think your order marked as fraud by mistake, you can open a ticket and we will manually review the order and activate the account.
    You can also put your order number here
    We will try our best so do not open multiple tickets for same reason or we will consider it as an abuse
  • 548297 Application to remove fraud status. The information I fill in is true, and I promise not to misuse it!
    Thanked by (1)ViridWeb
  • edited April 2023
    Thank you for your reply.
    However we can't approve the order
    Reason:
    1. You put "well lam" as your name, and I'm sure it's not true
    2. instead of domain you put "welllam"
    With "welllam" instead domain how exactly we can create a shared hosting account?
    This is a shared web hosting and not a vps, so you need a domain for that to run a website using our service.
    So unfortunately we can't activate your account.
    Note: your account will be removed from our website within next 24hrs as we do not store client data which doesn't have financial data in it.
    For now we are stopping to accept order from few countries including China
    It's not because of racism but maybe for language barrier and we think it's not worth it to spends so much time to explain everything about the service to each and every customer
    Clients from other countries are welcome as usual.
    For other products they can order as usual but for this free hosting we are pausing for now
    Thank you for understanding
    Best Regards,
    Reason:
    Best Regards,
    i know that.thanks
  • Is't so difficult to understand basics?
    Why most people using vpn/proxy/datacentre IP to order when we Cleary mentioned we will not accept any order using those services!?
    Also we will neither accept any order blocked by FraudLabs nor FraudRecord.
    So please do not order if you have previous record on those sites as well
    Anyways, orders are still open for legit cleints
  • order number 1753656666 :)
    Hello!
    Can't find the order
    can you please reorder again and provide me the number again?
    I will activate the order manually
  • Is there anyone who got a successful manual activation?
    For those who failed to get one, I recommend WebHorizon and Gullo for their stability and affordability.
  • edited April 2023
    Hello!
    Kindly order and provide me your order number.
    Make sure to use a proper domain name on hostname section as it's shared hosting so a FQDN required.
    We have rejected most of orders because most of them are not using FQDN and their real names are good man, bad man, etc.
    And yes you can order from other provider using your real name like good man, bad man
    Thanked by (2)bliss yoursunny
  • FatGrizzlyFatGrizzly Hosting Provider
    Hello!
    I can't order with my domain, tried ov.mydomain.net and mydomain.net. No success.
    Can I DM you for help?
  • @FatGrizzly said:
    Hello!
    Can you please check again? we made some changes and it should work now.
    If not then please DM us your account details and the domain you want to use. I will add the service for you
  • Thank you very much for providing Free Shared. Can i still ask if you provide jail shell "ssh access" ?
    Hey Ehab!
    By default the SSH is disable for Free service.
    Check your PM
    For others who failed to get the service please follow the below listed rules and I'm sure you will have any issue
    1. Use real information to register (No John doe, or good man like name please)
    2. Do not use VPN/Proxy or any datacenter IP to register or order
    3. Use proper domains or subdomains. Ex: mydomain.com or sub.mydomain.net. (Do not put any other thing exept an FQDN. It's not a vps so do not use hostname like myserver
    4. If it's still failed and mark as fraud, please provide your order number here. we will review and activate it if everything looks good.
    Thank You!
    Thanked by (1)ehab
  • i made order, instant activation and found my way around.
    Thank you ViridWeb
    Thanked by (2)Ympker ViridWeb
  • same here, signed up, was activated immediately and works fine.
    thanks!
  • order number 1954573485
    thank you for your kindness
    Order: 1655772191
    if possible, can you enable jailed ssh for my account?
  • Thanks for your patient explanation.
    :wink:
    @FatGrizzly said:
    Order: 1655772191
    Unfortunately free plan doesn't have SSH access for now
    Sorry!
    thanks!
    Welcome! :smile:
    Are you sure your domain only has 6 digits number and no latter?
    Thank you ViridWeb
    Thank you for choosing us
  • IPv6 is also available. If you account doesn't have IPv6 by default, just open a ticket or post your order number here, we will add the IPv6 as well on your account
    @ViridWeb said: IPv6 is also available. If you account doesn't have IPv6 by default, just open a ticket or post your order number here, we will add the IPv6 as well on your account
    first free webhosting introducing v6 I see. GG
    Thanked by (2)ViridWeb Ympker
    Just trying our best.
    BTW, I have added the IPv6 on your account as well :wink:
    Enjoy :tongue:
    Thanked by (1)FatGrizzly
  • EncodersEncoders Supporter
    lmao nice, keep it up.
    watch this man slaughter 80% abuse attempt with a simple trick
    Thanked by (1)terrorgen
    @Encoders said: watch this man slaughter 80% abuse attempt with a simple trick
    This is on my blocklist:
    CC_DENY = "CN,RU,TD,PK,ID"
    no racism/discrimination intended, this is the countries I get attacked from, so yeah.
    Thanked by (1)Encoders
  • What is CC in CC_DENY means?
  • @ViridWeb said:
    :wink:
    @FatGrizzly said:
    Order: 1655772191
    Sorry!
    thanks!
    Welcome! :smile:
    Thank you ViridWeb
    Yes. I still have no idea how can I transfer my com
    domain to porkbun or dynadot
    Country Code DENY, CSF firewall
  • edited April 2023
    Yes we are using the same but don't think it will help. as majority of them visits/order using vpn from different country/location
    So just blocking a single country will not help
    Anyways, majority of orders from China automatically marked as fraud by fraudlabs and fraudrecord. That makes our job easy.
    But we already accepted few clients from China as well who have no fraudrecord and passed by fraudlabs.
    ID :'( oh Noo!
    ID :'( oh Noo!
    don't feel sad.... is Eid tomorrow for you?
