CloudJiffy (PaaS)- Free 14 Days Trial and get $10 bonus on setting up a demo call!
leapswitchleapswitch Hosting Provider
Dear LES members,
I hope this message finds you well. My name is Ishan, representing Leapswitch Networks, a provider of Cloud and Hosting services since 2006! If you're in search of a robust, reliable, and simple hosting solution, your search ends here. Allow me to introduce CloudJiffy - a user-friendly, container-based automated platform that can significantly reduce your DevOps time and efforts, while also cutting down your hosting costs by up to 75%.
Now, you might wonder, how do we achieve such remarkable savings? The answer lies in two key features: autoscaling and the Pay-As-You-Consume pricing model.
Let's consider how traditional VPS works: When you purchase a VPS, you receive a fixed amount of RAM, CPU, and Storage. Upgrading these resources often requires downtime. Here's the dilemma: Your application may only require 2 GB RAM when it's idle, but during peak traffic times, you may need up to 4 GB RAM. To ensure your application can handle future traffic spikes, you end up purchasing 8 GB RAM, even though you only need 4 GB RAM for a fraction of the day. This means you pay for unused resources throughout the entire month.
CloudJiffy resolves this problem through its container-based platform, built on the Microservice architecture. With CloudJiffy, you can create multiple containers for each of your services and allocate minimum and maximum resources for each service according to your requirements.
Your minimum resources are allocated 24x7, unless you choose to stop them, and you are charged accordingly. Following the previous example, you can set your idle resources at the minimum, such as 2 GB RAM. Additionally, you can set the maximum resources based on your anticipated peak requirement. If your application needs more resources than the minimum allocated, CloudJiffy dynamically allocates additional resources (cloudlets) in real-time, without any downtime.
In other words, you are only charged for the resources you are actively consuming. This approach helps reduce your overall costs by up to 75% and saves you valuable time.
If you're seeking a hosting solution that combines efficiency, scalability, and cost-effectiveness, CloudJiffy is the ideal choice. Feel free to reach out to us with any questions or to explore how CloudJiffy can benefit your specific hosting needs.
Want a trial? Click here for 14 day free trial.
Watch a 2-minute video
Need a demo of the platform or Need more information? Schedule a call with us and get a $10 bonus to try us out.
Best regards,
Ishan
Leapswitch Networks
Thanked by (2)FrankZ Asim
