1105106108110111277
  • @JDMcPea said:
    @VirMach said:
    I had a TLDR written for this but lost it. Basically I have an idea to let existing customers burn in new nodes we deploy so we find any issues we missed that may appear from "natural" usage. It's essentially a 14 day trial service of NVMe1G and it may otherwise go down or have issues, no support, guaranteed data loss. You can abuse it all you want though as long as you're not committing a crime (as in, high CPU or I/O is fine. But we can still suspend it if we want to, not that it matters.)
    https://billing.virmach.com/cart.php?a=add&pid=217
    Coupon code IUNDERSTANDWHATIMORDERING
    I got "You must have an active product/service to use this code" error when I applied the Promo code so it did not remove the setup fee. Was logged in to my account and I do have an active service
    Me too!
    Does this mean the node assignments were filled or just some issue with the site?
  • @AlwaysSkint said:
    ^Yup, I concur. I couldn't get netboot.xyz to play nicely, so booted Alama and flags are set.
    Just FYI, you can use netboot.xyz from grub pretty easily. Just follow these steps:
    apt update && apt install grub-imageboot
    mkdir /boot/images
    cd /boot/images
    wget https://boot.netboot.xyz/ipxe/netboot.xyz.iso
    update-grub2
    (if you're not quick, edit GRUB_TIMEOUT in /etc/default/grub to 30 or higher, run update-grub2 after editing)
    Then just reboot and select netboot from the boot menu (you'll need VNC access for this bit)
    edited October 2022
    @Daevien said: I check a couple things there but avoid most threads, just irritates me for no good reason.
    Precise. Absolut. :)
    @fluttershy said: Fun YABS from my Los Angeles VM:
    Now you do know that you don't really need that and I'll take it off your hands; find it a new home on the East Coast (or NL) where it won't get abused. ;)
  • @jtk said:
    I assume LET admins will remove the "Top Host" designations from all providers who have held it as long or longer as VirMach.
    Like ones with pending court cases about previous related companies that scammed their own userbase? Nah
    I'll never give up my $25/year idler :angry: :lol:
    Thanked by (1)podman
  • FrankZFrankZ ModeratorOG
    edited October 2022
    jbiloh said:
    Virmach received "Top Host" designation after the community voted them as such many years ago.
    LET Provider Poll 2021 - Results
    Best Providers
    Rank Provider Votes
    1 RackNerd - 132
    2 BuyVM / BuyShared - 63
    3 VirMach - 57
    So many years ago, way back in 2021
  • I have apple pie at home. I want it in the office.
  • There is strawberry jelly too.
    You put strawberry jelly on apple pie?
  • @imok Can you PLEASE keep this inane stuff to Cest Pit and/or OGF? PLEASE!
  • @Virmach Perhaps you can ask the mods to create a forum post specifically for reporting issues with the NVMe alpha/beta test. Not much point in adding to your Ticket count, eh?
    @atomi said:
    @VirMach said:
    @atomi said:
    @AlwaysSkint said:
    Gateway is pingable but Solus HTML5 VNC doesn't attach to node and VMS doesn't boot up (to netboot.xyz ISO).
    Same problem, I also noticed that client panel says AMSD030X but its RYZE.AMS-D001.VMS in Solus. I'm not sure if numbers should match but they usually do
    It just means I can't type. (edit) or think.
    I think it must the first one since that package has only 1GB of bandwidth. You cannot think anyone could proceed a normal testing with such a abnormal amount of data transfer :wink:
    This is a glitch that ModulesGarden was asked to fix for probably years and kept saying it's fixed and didn't fix it. Maybe they did fix it by now but I'm pretty sure we're on the latest version already. I'll fix it now, order another one in a few minutes.
    Thanked by (3)AlwaysSkint FrankZ skorous
  • I feel bad for grabbing one of the free instances, I'll probably just run archiveteam on it + yabs on cron or something.
    @jtk said:
    Ordered with Debian 11. The order process was fine. Was provisioned an 1CPU, 1GB RAM, 25GB disk, 1GB traffic on a AMS node. Was marked as offline. Went into the control panel and tried to boot it. Nothing. Re-installed with Debian 11. Still not coming up. Tried Debian 10. Not still offline. Tried VNC, unreachable. Tried remote echo request (PING) to make sure it wasn't being misreported by control panel, no response. Tried CentOS 8, still not up. Tried a couple power offs, boots, and what not.
    Sounds like you should also order another one.
    @lemoncube said:
    I have a tiny VPS on PHXZ004 idling all the time just triggered an email imforming me it was suspended due to bandwidth overuse. It was a BF flash deal plan and the bandwidth actually is as low as 125GB if I remember correctly so it could have fallen victim to some sort of attack and got it all burnt up ( or maybe the configuration messed up during migration or IP switching and I didn't pay attention ).
    I don't think I'm gonna appeal for it. It's just kinda infuriating not be able to inspect how or when it ran out of bandwidth as either whcms or solusvm won't allow me to see stats and graph at all when service isn't active.
    Yeah I agree with you there. We really need to consider using something else soon as our next big project but I'd rather just leave everything alone at this point. I feel like us and the customers alike have had a decade's worth of frustration from everything flying around this year.
    But pretty much every case is what you described, it might have gotten hacked. The only way to be nearly 100% secure is to use SSH key and disable VNC most the time but I understand that's not convenient for most people.
  • @VirMach said: I'll fix it now, order another one in a few minutes.
    Did you name this VM especially for me? :open_mouth:
    EnviousElderly-VM
    FYI: Still the discrepancy AMSD030X => RYZE.AMS-D001.VMS
    Bandwidth 1000 GB
    That's fixed! :) :+1:
    @willie said:
    14 day burn-in
    I think the big providers qualify new hardware configs for months before opening them up to non-beta users. 14 day burn in is for new installs of hw configs that have already been qualified. It sounds like the hw issues in this thread came from configs that were flaky to begin with, so 14 days wouldn't be nearly enough of a burn-in.
    I certainly hope that all these emergencies resolve and things get near normal again. At that point it's worth doing some reflection to figure out what went wrong and how it can be prevented going forward. Postmortems are a usual procedure after any significant outage.
    SJCZ005 is coming back, it was about to come back this morning and then I got dragged into something else for several hours.
    We've definitely had way longer than months of testing for the configurations, but definitely not every single unit. They're all brand new parts and some just end up malfunctioning after people actually go on them. Based on our experience so far I think 2 weeks is pretty good. Most nodes didn't crash or have problems until we finally filled them, and the ones that did showed their problems relatively quickly. We do actually test everything though beforehand, it's just not the same. Like a node can do a stress test for several days and then once it gets the right combination of people actually using it or after a rough shipment it can still pass everything with flying colors and then go haywire once it has to actually boot up a bunch of VMs doing random things at random times.
    I don't know, I'll stop rambling I guess.
    Thanked by (1)cornercase
    Oh god my brain is actually melting, I could have sworn I fixed it but it's entirely possible I can no longer type 001 correctly.
    Thanked by (1)AlwaysSkint
    If it makes you feel any better this node has just been sitting there idle for ~3 months now.
    Thanked by (1)fluttershy
    Me too!
    Some old WHMCS bug IIRC.
    edited October 2022
    @VirMach said: .. this node has just been sitting there idle for ~3 months now.
    Now just add a 2TB HDD or therabouts and we've got the making of a sweet 15GB NVme/150GB HDD hybrid. ;) Then unleash on the Tokyo suckers punters! :cold_sweat:
    oh yeah just gonna triple YABS it
    edited October 2022
    I'll have more of this, thanks..
    Mon 3 Oct 19:23:28 EDT 2022
    Uptime : 0 days, 0 hours, 7 minutes
    Processor : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores : 1 @ 3693.062 MHz
    AES-NI : ✔ Enabled
    RAM : 804.7 MiB
    Swap : 256.0 MiB
    Disk : 24.3 GiB
    Distro : AlmaLinux 8.6 (Sky Tiger)
    Kernel : 4.18.0-372.26.1.el8_6.x86_64
    Read 351.17 MB/s (87.7k) 785.15 MB/s (12.2k)
    Write 352.09 MB/s (88.0k) 789.28 MB/s (12.3k)
    Total 703.26 MB/s (175.8k) 1.57 GB/s (24.6k)
    Read 1.02 GB/s (1.9k) 2.12 GB/s (2.0k)
    Write 1.07 GB/s (2.1k) 2.26 GB/s (2.2k)
    Total 2.09 GB/s (4.0k) 4.38 GB/s (4.2k)
    Clouvider | London, UK (10G) | 939 Mbits/sec | 940 Mbits/sec
    Online.net | Paris, FR (10G) | 936 Mbits/sec | 936 Mbits/sec
    Hybula | The Netherlands (40G) | 941 Mbits/sec | 941 Mbits/sec
    Uztelecom | Tashkent, UZ (10G) | 861 Mbits/sec | 459 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 876 Mbits/sec | 350 Mbits/sec
    Clouvider | Dallas, TX, US (10G) | 716 Mbits/sec | 178 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 795 Mbits/sec | 241 Mbits/sec
    Edit: Sorry, @yoursunny I haven't swotted up on IPv6, to enable a route but the vNIC appears to have one.
  • FAT32FAT32 OGSenpai
    I am going to try obtaining multiple of them and create a Proxmox HA cluster, let's see how well it does
    This is acceptable use case for IO/CPU "abuse" right?
    Obligatory YABS
    Mon 03 Oct 2022 07:43:40 PM EDT
    Uptime     : 0 days, 0 hours, 3 minutes
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 976.4 MiB
    Swap       : 256.0 MiB
    Disk       : 24.6 GiB
    Kernel     : 5.10.0-8-amd64
    Read       | 118.66 MB/s  (29.6k) | 16.06 MB/s     (251)
    Write      | 118.98 MB/s  (29.7k) | 16.62 MB/s     (259)
    Total      | 237.65 MB/s  (59.4k) | 32.69 MB/s     (510)
    Read       | 127.02 MB/s    (248) | 669.60 MB/s    (653)
    Write      | 133.77 MB/s    (261) | 714.19 MB/s    (697)
    Total      | 260.79 MB/s    (509) | 1.38 GB/s     (1.3k)
    Geekbench 5 Benchmark Test:
    Single Core     | 1063
    Multi Core      | 1063
    Full Test       | https://browser.geekbench.com/v5/cpu/17722131
    AES-NI     : ❌ Disabled
    RAM        : 976.4 MiB
    Swap       : 256.0 MiB
    Disk       : 24.6 GiB
    Read       | 120.15 MB/s  (30.0k) | 23.25 MB/s     (363)
    Write      | 120.47 MB/s  (30.1k) | 23.81 MB/s     (372)
    Total      | 240.62 MB/s  (60.1k) | 47.06 MB/s     (735)
    Read       | 115.83 MB/s    (226) | 1.27 GB/s     (1.2k)
    Write      | 121.99 MB/s    (238) | 1.35 GB/s     (1.3k)
    Total      | 237.82 MB/s    (464) | 2.63 GB/s     (2.5k)
    Single Core     | 1048
    Multi Core      | 1053
    Full Test       | https://browser.geekbench.com/v5/cpu/17722134
    Mon 03 Oct 2022 07:43:41 PM EDT
    AES-NI     : ❌ Disabled
    RAM        : 976.4 MiB
    Swap       : 256.0 MiB
    Disk       : 24.6 GiB
    Read       | 77.24 MB/s   (19.3k) | 20.02 MB/s     (312)
    Write      | 77.44 MB/s   (19.3k) | 20.60 MB/s     (321)
    Total      | 154.68 MB/s  (38.6k) | 40.63 MB/s     (633)
    Read       | 735.64 MB/s   (1.4k) | 541.07 MB/s    (528)
    Write      | 774.72 MB/s   (1.5k) | 577.10 MB/s    (563)
    Total      | 1.51 GB/s     (2.9k) | 1.11 GB/s     (1.0k)
    Single Core     | 1059
    Multi Core      | 1077
    Full Test       | https://browser.geekbench.com/v5/cpu/17722130
    Mon 03 Oct 2022 07:43:42 PM EDT
    AES-NI     : ❌ Disabled
    RAM        : 976.4 MiB
    Swap       : 256.0 MiB
    Disk       : 24.6 GiB
    Read       | 119.58 MB/s  (29.8k) | 21.96 MB/s     (343)
    Write      | 119.89 MB/s  (29.9k) | 22.53 MB/s     (352)
    Total      | 239.48 MB/s  (59.8k) | 44.50 MB/s     (695)
    Read       | 182.18 MB/s    (355) | 937.87 MB/s    (915)
    Write      | 191.86 MB/s    (374) | 1.00 GB/s      (976)
    Total      | 374.05 MB/s    (729) | 1.93 GB/s     (1.8k)
    Single Core     | 1054
    Multi Core      | 1060
    Full Test       | https://browser.geekbench.com/v5/cpu/17722133
    Mon 03 Oct 2022 07:43:43 PM EDT
    AES-NI     : ❌ Disabled
    RAM        : 976.4 MiB
    Swap       : 256.0 MiB
    Disk       : 24.6 GiB
    Read       | 80.23 MB/s   (20.0k) | 26.40 MB/s     (412)
    Write      | 80.44 MB/s   (20.1k) | 26.84 MB/s     (419)
    Total      | 160.67 MB/s  (40.1k) | 53.24 MB/s     (831)
    Read       | 604.22 MB/s   (1.1k) | 894.08 MB/s    (873)
    Write      | 636.32 MB/s   (1.2k) | 953.62 MB/s    (931)
    Total      | 1.24 GB/s     (2.4k) | 1.84 GB/s     (1.8k)
    Single Core     | 1064
    Multi Core      | 1063
    Full Test       | https://browser.geekbench.com/v5/cpu/17722136
    I have never done this before but my plan is setup VPN in one node, so others can connect to it and use that as the "external" IP address with the HA cluster setup
    edited October 2022
    @FAT32 Please install Alma8 Linux template first to get AES-NI, VM-x/AMD-V enabled. Then install Proxmox . :)
    Thanked by (1)FAT32
    Me too!
    I've tried switching browsers, adding "&promocode=IUNDERSTANDWHATIMORDERING" to the URL but still no joy.
    So is everyone else just paying the setup fee?
    Just realise all of them are in the same host node, probably defeat the purpose of HA :joy:
    edited October 2022
    Well you could pretend you have HA. :grimace:
    (Always good to see you around.)
    YABS with IPv6 for @yoursunny
    # Yet-Another-Bench-Script #
    # v2022-08-20 #
    Mon Oct 3 19:32:56 CDT 2022
    Uptime : 0 days, 0 hours, 5 minutes
    AES-NI : ✔ Enabled
    RAM : 964.7 MiB
    Swap : 4564.0 MiB
    Disk : 24.3 GiB
    Read | 377.29 MB/s (94.3k) | 353.85 MB/s (5.5k)
    Write | 378.29 MB/s (94.5k) | 355.71 MB/s (5.5k)
    Total | 755.59 MB/s (188.8k) | 709.57 MB/s (11.0k)
    Read | 791.81 MB/s (1.5k) | 2.13 GB/s (2.0k)
    Write | 833.88 MB/s (1.6k) | 2.28 GB/s (2.2k)
    Total | 1.62 GB/s (3.1k) | 4.41 GB/s (4.3k)
    Clouvider | London, UK (10G) | 940 Mbits/sec | 940 Mbits/sec
    Online.net | Paris, FR (10G) | 937 Mbits/sec | 929 Mbits/sec
    Uztelecom | Tashkent, UZ (10G) | 822 Mbits/sec | 417 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 876 Mbits/sec | 378 Mbits/sec
    Clouvider | Dallas, TX, US (10G) | 813 Mbits/sec | 190 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 767 Mbits/sec | 219 Mbits/sec
    Clouvider | London, UK (10G) | 743 Mbits/sec | 306 Mbits/sec
    Online.net | Paris, FR (10G) | busy | 518 Mbits/sec
    Hybula | The Netherlands (40G) | 831 Mbits/sec | 833 Mbits/sec
    Uztelecom | Tashkent, UZ (10G) | 752 Mbits/sec | 77.1 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 574 Mbits/sec | 87.9 Mbits/sec
    Clouvider | Dallas, TX, US (10G) | 311 Mbits/sec | 113 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 593 Mbits/sec | 85.1 Mbits/sec
    Test | Value
    Single Core | 1385
    Multi Core | 1334
    To simulate real world client usage I have installed a VPN, a miner, H@H, and a small website. It is good that VirMach let us have so much swap RAM, I mean disk space.
    Thanked by (2)FAT32 AlwaysSkint
    That's so nice of you, good to see you around too :) I have been focusing on work, relationship and family lately, dont really spend time on social much.
    With the recession coming, I am also trying to plan my investment as all of them has been performing really badly, might want to start cutting my expenses too
