I would say that they are available, but we're not announcing it as some paperwork and such should be made
So yeah, if you wish to get a quote or such, fill free to DM me.
P.S We will make sure, to make a proper announcement once everything will be ready, but the system and nodes are tested, and they perform well, as also some guys are already using it
Thanks. I didn't know it could be reduced. But it still failed halfway and got null-routed.
Seems the Chicago location is prohibited from network tests.
@skorupion said:
BUYVM LUX 512 MB RAM with Premier account still waiting for 10 gbps upgrade
Hybula | The Netherlands (40G) | 7.10 Gbits/sec | busy
Why are you still waiting?
Cuz from what I know its not out yet, and most of them should be 5-8 gbps not 1.2 gbps tho 1.2 is very good still
Should be 5-8Gbps to different continent with 100ms+ ping? Lol good luck
Look upload speeds (even to UK)
Most of the send speeds are over 1Gbps, so you clearly have been upgraded to 10Gbs or you'd be capped at 1Gbps. Perhaps the network was congested to where you were and the iperf servers when you tested.
But bear in mind, if you read the announcement post you'll see that the nodes are limited to 30Gbps shared across everyone. If everyone is hammering it doing yabs, it's likely that you'll not see 10Gbps per VPS.
Advin Servers - Astro Birthday Special at $11.99 per month
Thanks @Astro & @Advin
Greencloud BudgetKVMHK-3 $45/y
The only VPS that I have. Even forgotten that I have it, lol.
NL/EU, 5€ recurring
Which provider?
LiteServer.
@contactwajeeh liteserver.nl
It's bought on black friday 2020.
Contact me at: +1 (509) 606-3569 or [email protected]
Ethernet Servers 70 GB SSD / 4 TB BW / 2.5 GB RAM / 2 IPs / 1 CPU $25/y
If you plan to cancel that one let me know Thank you
@LetMeBeSad seedboxes when?
Team push-ups!
Hell nah, also non transfarable
RackNerd LA
2.5 GB KVM VPS Special March Madness Specials ($21.50/yr)
@Advin's birthday special for @Astro:
GreenCloud RyzenIL-1
2GB 2 CPUs 25GB NVMe 6TB bandwidth at 10 Gbps port
The iperf test is disabled because my VPS will be null-routed and yabs will fail halfway.
App DevTools | AppPDF | Convert.in.th | ConvertOnline | Imagez | ImgTools
you could do a reduced iPerf
Yeah will retry soon enough
LigaHosting.ro 6.79€/y Boomer replacement, lets hope it will last that long
NATVPS.uk £3 Annually
Liga Hosting KVM SSD 2 €1,99/mo
zd.do $2.5/m Intel Compute Stick
Forgot about this storage box I have from Hosthatch; not sure if I will be keeping this.
Still has 14 months Left, expires on 30-12-2023 renews at 90$ for two years. Any takers?
10TB transfer/month
