1168169171173174277
    @fluttershy said:
    @VirMach said:
    @fluttershy and your request would have been around $30 on the old new formula and $69.75 on the old formula. More doable biennial at $65.15 on newest formula.
    If you can do biennial at $60 you got yourself a deal :wink:
    Yeahhhhhhhhh about that. I don't think I have it in me to try to keep Jab at $40/yr and yours at $60/2yr. It's on a very fine line of basically being impossible.
    @FAT32 said:
    @FAT32 said:
    32GB DDR4 RAM
    32GB NVMe SSD
    8 vCore EPYC CPU
    96GB @ 1Gbps
    0x IPv4 & 1x /64 IPv6
    $32/YR
    I call it the SSD32G mini
    @VirMach
    This would be $365.05 a year. Can you tell my new formula is RAM-heavy?
    Thanked by (1)FAT32
  • 15GB NVMe SSD
    8 vCore
    100GB @ 1Gbps
    1x IPv4 & 1x /64 IPv6
    $20/YR
  • @VirMach said:
    Give me some wild ones so I can see if it breaks. Like one resource maxed out and not others. Any weird use cases? Where you'd need a lot of BW and nothing else, a lot of RAM and nothing else, a lot of disk and nothing else, and so on? Trying to figure out the boundaries it works within.
    Some of my old virbotted VMs might qualify:
    3 vCPU
    12GB RAM
    25GB NVMe
    1x IPv4
    24TB @1gbps
    $50/year
    3 vCPU
    11GB RAM
    25GB NVMe
    1x IPv4
    21TB @1gbps
    $41/year
    If you want a challenge, try
    1 vCPU
    2GB RAM
    15GB NVMe
    1x IPv4
    40TB @1gbps
  • Whoops, glad that's not a real user.
    $65 it is then :wink: I need that NVMe for fast backups lol
    Redoing all these with a more balanced memory formula but it gets wonky. Similar total cost components.
    @fluttershy $29 requested versus $50.02 (annual)
    @yoursunny with IPv4 1G/2G/4G $16.61, $20.24, $34.48 (annual)
    Then two years:
    @yoursunny GreenCloud and 8.8.8 are $69.75 and $18.88 requested but $117.99 and $45.74
    @kuroneko23 requested $58 versus $53.40
    @netrix requested $25 and $20 versus $31.65 and $28.05
    @storm requested $80 versus $$125.99
    @Flying_Chinaman first request $126.67 without HDD (but 4x IPv4)
    @Flying_Chinaman second stayed at around $83.26
    @Jab $59.30 or $37.06 annual with 1.46TB BW.
    Then two years:
    Have you tested border conditions and verified input?
    Last time during Ryzen migration, many MJJs successfully smuggled to Tokyo with F12 browser console.
    smartass shitposting satirist
    @ben47955 said:
    15GB NVMe SSD
    8 vCore
    100GB @ 1Gbps
    $20/YR
    Okay so we'll call it V3 and V4. And your RAM is fully missing right? So I'm putting in zero for that.
    V3: $38.21/YR
    V4: $59.67/YR
    @fluttershy said:
    3 vCPU
    12GB RAM
    25GB NVMe
    1x IPv4
    24TB @1gbps
    $50/year
    V3: $118/YR
    V4: $98.33/YR
    3 vCPU
    11GB RAM
    25GB NVMe
    1x IPv4
    21TB @1gbps
    $41/year
    V3: $107.89/YR
    V4: $90.35/YR
    1 vCPU
    2GB RAM
    15GB NVMe
    1x IPv4
    40TB @1gbps
    V3: $103.03/YR
    V4: $101.46/YR
    Okay time to try V5 instead of realizing this is an impossible task. But to be fair all yours are BW heavy where we're giving a lot more than we anticipate being utilized on average. It works out well on average, but then we add in Tokyo and so on and it's harder to make the formula favorable.
    V4 definitely looks more balanced, I just have to... I don't know.
    @Flying_Chinaman said: Last time during Ryzen migration, many MJJs successfully smuggled to Tokyo with F12 browser console.
    Trying to avoid this even being a possibility which will unfortunately make things more rigid and not how we want.
    @VirMach said:
    @FAT32 said:
    @FAT32 said:
    32GB DDR4 RAM
    32GB NVMe SSD
    8 vCore EPYC CPU
    96GB @ 1Gbps
    $32/YR
    @VirMach
    On V4 this is $114/yr and I don't know if that's a good thing.
    Thanked by (1)FAT32
  • Is virbot coming back?
    32GB DDR4 RAM
    50GB NVMe SSD
    1 vCore EPYC CPU
    32GB @ 1Gbps
    $32/YR
    How about this specs? (The storage is to store the persistent data)
    edited October 2022
    @FAT32 said:
    32GB DDR4 RAM
    50GB NVMe SSD
    1 vCore EPYC CPU
    32GB @ 1Gbps
    $32/YR
    Okay V4 is gone but this is V3 vs V5-ish
    V3: $142.47/YR
    V5: $103.44/YR
    This just makes it to where it's impossible to do normal plans so we definitely need to put a memory cap.
    V3: $142.47/YR
    V5: $103.44/YR
    That feels like it is still very RAM-heavy
    tragic
    @FAT32 said:
    V3: $142.47/YR
    V5: $103.44/YR
    Well we have to realize 32GB RAM being used on a 128GB max RAM Ryzen node can basically knock out 25% of its usability for just $103.44/YR.
    Thanked by (1)theloafingone
    tragic
    Don't worry V5 fixes it.
  • @VirMach said:
    @FAT32 said:
    V3: $142.47/YR
    V5: $103.44/YR
    get 4 and get the whole node to yourself :sunglasses:
    We can code a penalty of some sorts but then this:
    @Flying_Chinaman said: Have you tested border conditions and verified input?
  • @VirMach said:
    tragic
    hopefully good news for all my backups
  • Is VirBot a symbiot that has taken over VirMach? Or it's the other way around? I am confused.
    Thanked by (1)VirBOT
    VirBot pulls all the strings in the background. VirMach is just the PR guy.
  • @VirMach said:
    @ben47955 said:
    15GB NVMe SSD
    8 vCore
    100GB @ 1Gbps
    $20/YR
    I remember writing 1GB. Not sure were it's gone.
    1GB RAM
    15GB NVMe SSD
    8 vCore
    100GB @ 1Gbps
    $20/YR
    1GB RAM
    15GB NVMe SSD
    8 vCore
    100GB @ 1Gbps
    $20/YR
    V3: $42.27/YR
    V5: $41.66/YR
    edited October 2022
    Okay, here's V5 but we'll most likely need to cap it and have minimums for it to work.
    @fluttershy $29 requested versus $36.10 (annual) and $57.76 biennial
    @yoursunny with IPv4 1G/2G/4G $14.78, $19.42, $32.84 (annual)
    @yoursunny GreenCloud and 8.8.8 are $69.75 and $18.88 requested but $97.06 and $38.91
    @kuroneko23 requested $58 versus $56.16
    @netrix requested $25 and $20 versus $30.67 and $28.79
    @storm requested $80 versus $108.62
    @Flying_Chinaman first request $112.60 without HDD (but 4x IPv4)
    @Flying_Chinaman second stayed at around $74.63
    @Jab $59.11 or $36.94 annual with 1.46TB BW.
    To make it work I had to basically lower the totals so it's not really 1:1 and I need to try to lift some of them somehow without affecting others as much.
    This formula is closest to our Special 512 for $22 though.
  • After going through the last 170 new posts I realized I need my coffee because I have no clue what's going on.
    @FAT32 said:
    V3: $142.47/YR
    V5: $103.44/YR
    V5 Final: $127.87
    Is this something you actually wanted for using/a project?
    Thanked by (1)FAT32
  • @VirMach said:
    V5 Final: $127.87
    Probably one day when I have projects that reach certain scale... I am thinking it could be an interesting Redis/DB Server, but then 32GB is too huge, my existing 8GB plan is already more than sufficient.
  • Anyone tried migration to Frankfurt lately? I tried like 2 weeks ago, it was returning 500.
    I would like to migrate one VPS, but I would need to add money first and there is no reason to add money if transfer not working!
    also there is no reason to add 3$, so I would need to add like 20$... and that would make me vulnerable to BF deals!
    Eh, decisions, decisions, decisions.
