Python: append between pattern
So, I continue my learning with python by rewriting 2k+ lines of bash beauty. And now struggling with real bad ass problem: pythons inability to manipulate text in files. Just astonishing how complicated it is.
Have bash function:
ip_access() {
    local user=$1
    local htaccess="/home/${user}/site/.htaccess"
    local ips="$2"
    # manipulate records in .htaccess
    [ ! -f "${htaccess}" ] && touch "${htaccess}"
    # if no IPs provided, assume reset
    if [ -z "${ips}" ]; then
        sed -i '/##ip_access1/,/##ip_access2/{d}' "${htaccess}"
        chown "${user}":"${user}" "${htaccess}"
        echo "IP access successfully reset!"
        exit 0
    fi
   # format IPs into .htaccess acceptable format
    arrip=()
    for ip in ${ips//,/ }; do
        arrip+=("Require ip $ip\n")
    done
    # remove everything
    # inject fresh batch
    { echo -e "##ip_access1";\
     echo -e "${arrip:?}" | head -c -1;\
     echo -e "Require all denied";\
     echo -e "##ip_access2"; } >> "${htaccess}"
    echo "IP access successfully set!"
This function appends text into .htaccess file in this format:
##ip_access1
Require ip 127.0.0.1
Require ip 127.0.0.2
Require all denied
##ip_access2
If no IPs provided function just removes everything between ##ip_access1 and ##ip_access2 including the pattern.
How to achieve this with Python? Any clues?
It's a tad late (6:00 AM lol), so I'll leave a naive solution below. You (obviously) don't want to be reading a massive
.htaccessfile into memory (we should be manipulating it as a stream as opposed to loading the file into memory). (I didn't implement all the functionality listed, but they should be pretty simple to do.)Holy F, this line is pure magic:
return "\n".join(lines[0:pos1]) + start + to_replace + end + "\n".join(lines[pos2 + 1:len(lines)])Glad I could help! :-)
