Air Fryers are amazing, I cook almost everything in mine now.
I can’t argue with that, just keep it away from the wall if you have plastic splash backs…. Ask me how I know
Oh yeah, those things kick out some serious heat. I roasted a joint of meat in mine the other day and the tiles were absolutely drenched in condensation.
@Fritz said:
Is it normal that a simple command will takes forever to finish? @natvps_uk
like apt install curl.
I don't know why but installing curl also took too long for me then closed the ssh window and after i logged back in curl was installed, however rest everything is blazing fast for the price
It shouldn’t be that slow although these are hdd backed so some contention is likely.
I just did a test and it wasn't awful although we are spoilt by SSDs these days:
`time apt -y install curl
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
curl
0 upgraded, 1 newly installed, 0 to remove and 92 not upgraded.
Need to get 265 kB of archives.
After this operation, 411 kB of additional disk space will be used.
Get:1 http://security.debian.org buster/updates/main amd64 curl amd64 7.64.0-4+deb10u3 [265 kB]
Fetched 265 kB in 0s (12.3 MB/s)
Selecting previously unselected package curl.
(Reading database ... 30131 files and directories currently installed.)
Preparing to unpack .../curl_7.64.0-4+deb10u3_amd64.deb ...
Unpacking curl (7.64.0-4+deb10u3) ...
Setting up curl (7.64.0-4+deb10u3) ...
Processing triggers for man-db (2.8.5-2) ...
@mmo25821 said:
out of stock can u stock it again i need some of this🤓
More stock will likely be released in the coming weeks.
so u can’t add today some from it because me and my friends need to buy it
Unfortunately not, this was a sale to use up free resources. The budget nodes are now full however we are evaluating the possibility of being able to offer these packages on a more permanent basis.
Hopefully we will have some news over the coming weeks.
Don’t do it. Keep’em sparse. Drip-feed a handful every few weeks to artificially drive up demand, then sell a few to a fake account you manage then ‘transfer’ them on LET for 10x the price.
@natvps_uk said:
More stock added!
FYI Anyone using false details during signup will not have their orders accepted - NO EXCEPTIONS.
hello my order num 409 is Fraud and my information is correct !?
Hello,
It looks like you signed up twice, the first signup was using false details hence why the order failed, once an order has been marked as fraud it does require manual review. I have replied to both of the tickets that you raised with the steps to activate your account.
https://microlxc.net/
Probably because it's HDD and there are many people using it at the same time so the read and write speeds are slow. Happened to me before.
curl
real 0m2.784s
user 0m0.814s
sys 0m0.274s`
I think you should to examine your usage of the word ‘need’.
If you genuinely ‘need’ this £2 a year VPS I fear to think about the path you and your comrades have taken in life, it sounds incredibly distressing.
You know it makes sense.
More stock added!
I just ordered my first vps.
Thanks for the offer.
What on earth is your username? Did you just slam you head against the keyboard a few times? Or did you transpose your intended username and password?
both.
Hello,
Here is a YABS - geekbench seems to fail
it is the hash of the e-mail username used for registration. I like it.
ITS WEDNESDAY MY DUDES
I cannot confirm or deny anything
Ticket #SWW-708608
my order was marked as fraud
interested but out of stock
Can you add alpine template?
I really want one UK NAT VPS 128 or 256
Will such a server be added in the future?
Ha ha ha, got one. I feel so special now.
u always have been special to use Jane.
Open a ticket and I’ll take a look 🙂
Right now, better be quick 😉
Can't wait, every day I have to check the website to see if it's in stock
Any chance for some more soon?
