UK NATVPS from £2 per year!
1246
  • Air Fryers are amazing, I cook almost everything in mine now.
    I can’t argue with that, just keep it away from the wall if you have plastic splash backs…. Ask me how I know
    Thanked by (1)bdl
    Oh yeah, those things kick out some serious heat. I roasted a joint of meat in mine the other day and the tiles were absolutely drenched in condensation.
  • Is it normal that a simple command will takes forever to finish? @natvps_uk
    like apt install curl.
    I don't know why but installing curl also took too long for me then closed the ssh window and after i logged back in curl was installed, however rest everything is blazing fast for the price
  • Probably because it's HDD and there are many people using it at the same time so the read and write speeds are slow. Happened to me before.
  • edited October 2022
    It shouldn’t be that slow although these are hdd backed so some contention is likely.
    I just did a test and it wasn't awful although we are spoilt by SSDs these days:
    `time apt -y install curl
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    The following NEW packages will be installed:
    curl
    0 upgraded, 1 newly installed, 0 to remove and 92 not upgraded.
    Need to get 265 kB of archives.
    After this operation, 411 kB of additional disk space will be used.
    Get:1 http://security.debian.org buster/updates/main amd64 curl amd64 7.64.0-4+deb10u3 [265 kB]
    Fetched 265 kB in 0s (12.3 MB/s)
    Selecting previously unselected package curl.
    (Reading database ... 30131 files and directories currently installed.)
    Preparing to unpack .../curl_7.64.0-4+deb10u3_amd64.deb ...
    Unpacking curl (7.64.0-4+deb10u3) ...
    Setting up curl (7.64.0-4+deb10u3) ...
    Processing triggers for man-db (2.8.5-2) ...
    real 0m2.784s
    user 0m0.814s
    sys 0m0.274s`
  • @natvps_uk said:
    @mmo25821 said:
    out of stock can u stock it again i need some of this🤓
    More stock will likely be released in the coming weeks.
    so u can’t add today some from it because me and my friends need to buy it
    I think you should to examine your usage of the word ‘need’.
    If you genuinely ‘need’ this £2 a year VPS I fear to think about the path you and your comrades have taken in life, it sounds incredibly distressing.
    Thanked by (4)bdl Mumbly fluttershy FrankZ
    Unfortunately not, this was a sale to use up free resources. The budget nodes are now full however we are evaluating the possibility of being able to offer these packages on a more permanent basis.
    Hopefully we will have some news over the coming weeks.
    Don’t do it. Keep’em sparse. Drip-feed a handful every few weeks to artificially drive up demand, then sell a few to a fake account you manage then ‘transfer’ them on LET for 10x the price.
    You know it makes sense.
  • More stock added!
    FYI Anyone using false details during signup will not have their orders accepted - NO EXCEPTIONS.
  • I just ordered my first vps.
    Thanks for the offer.
    Thanked by (1)TrendyJack
    Cloudstorage Filen.io Aff - filelu Aff
    Free Uptime Monitoring HetrixTools Aff
  • NekkiNekki OG
    edited October 2022
    What on earth is your username? Did you just slam you head against the keyboard a few times? Or did you transpose your intended username and password?
    Thanked by (4)bdl ehab localhost pikachu
    both.
    Thanked by (1)localhost
  • @natvps_uk said:
    More stock added!
    hello my order num 409 is Fraud and my information is correct !?
  • @mmo25821 said:
    @natvps_uk said:
    More stock added!
    Hello,
    It looks like you signed up twice, the first signup was using false details hence why the order failed, once an order has been marked as fraud it does require manual review. I have replied to both of the tickets that you raised with the steps to activate your account.
  • Here is a YABS - geekbench seems to fail
    Sun 30 Oct 2022 09:37:55 AM GMT
    Uptime     : 0 days, 12 hours, 0 minutes
    Processor  : Intel(R) Xeon(R) CPU E31240 @ 3.30GHz
    CPU cores  : 1 @ 2207.922 MHz
    RAM        : 256.0 MiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Distro     : Debian GNU/Linux 10 (buster)
    Kernel     : 4.19.0
    Read       | 108.00 KB/s     (27) | 1.99 MB/s       (31)
    Write      | 117.00 KB/s     (29) | 2.16 MB/s       (33)
    Total      | 225.00 KB/s     (56) | 4.16 MB/s       (64)
    Read       | 6.73 MB/s       (13) | 11.83 MB/s      (11)
    Write      | 7.53 MB/s       (14) | 12.90 MB/s      (12)
    Total      | 14.26 MB/s      (27) | 24.73 MB/s      (23)
    Clouvider       | London, UK (10G)          | 869 Mbits/sec   | 877 Mbits/sec
    Online.net      | Paris, FR (10G)           | 873 Mbits/sec   | busy
    Hybula          | The Netherlands (40G)     | 891 Mbits/sec   | 895 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 839 Mbits/sec   | 480 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 867 Mbits/sec   | 542 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 837 Mbits/sec   | 299 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 822 Mbits/sec   | 272 Mbits/sec
    Clouvider       | London, UK (10G)          | 853 Mbits/sec   | 864 Mbits/sec
    Online.net      | Paris, FR (10G)           | 852 Mbits/sec   | 764 Mbits/sec
    Hybula          | The Netherlands (40G)     | 772 Mbits/sec   | 862 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 803 Mbits/sec   | 397 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 796 Mbits/sec   | 294 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 805 Mbits/sec   | 211 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 719 Mbits/sec   | 206 Mbits/sec
    Sun 30 Oct 2022 09:57:13 AM GMT
    Uptime     : 0 days, 12 hours, 19 minutes
    CPU cores  : 1 @ 2774.304 MHz
    RAM        : 256.0 MiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Kernel     : 4.19.0
    Geekbench 4 test failed. Run manually to determine cause.
    :) it is the hash of the e-mail username used for registration. I like it.
  • @Neoon said:
    I cannot confirm or deny anything
  • Ticket #SWW-708608
    my order was marked as fraud
  • interested but out of stock :'(
  • Can you add alpine template?
  • I really want one UK NAT VPS 128 or 256
    Will such a server be added in the future?
  • Ha ha ha, got one. I feel so special now. :relieved:
    Thanked by (2)Micronode localhost
    u always have been special to use Jane.
    Thanked by (1)Janevski
    Open a ticket and I’ll take a look 🙂
    Right now, better be quick 😉
    Thanked by (1)bdl
    Can't wait, every day I have to check the website to see if it's in stock =)
