5.40€/yr NAT64 VPS / 1 GB Ram / 5 GB SSD raid 1 /1 GBps speed/KVM / 1 IPv4 /1x /64 IPv6/DMCA IGNORED
245
  • Bought 1 of this, great fast support from Calin.
    The disk space is actually 10GB as I tested.
  • edited October 2022
    Hello @ccc thanks :) , yes it's true, if we add less than 10 GB it doesn't work to install the operating system, please don't abuse the space
    Regards,
    Calin
  • @Calin said:
    Hello @yoursunny , no IPv4 it s static.
    But IPv6 is dynamic, and everyone is allocated addresses from the same /64 ?
    About Custom ISO i m usage ProxMox , access to the panel can be obtained by requesting a ticket
    Do we have persistent access to the panel (including VNC), or only a limited time after a ticket?
    Are we able to mount the ISO on our own without asking every time?
  • Hello @yoursunny , each customer receives a separate /64
    You get permanent access to the panel, we have a rather strange bug in the panel, so sometimes you can have your own ISO and sometimes you have to make a ticket to add your new ISO
  • @Calin instead of 5GB SSD, can you offer 50 GB HDD for same price and specs ?
    Why?
    NOW THAT IS AN OFFER.
    Offer is that now
    Why?
  • HAHAHAHAH @jmaxwell i was just making a phrase...
    If the base plan is now 10 GB SSD, does this mean 2x price 4x plan would be —
    1 core (25%)
    1 GB RAM
    40 GB SSD
    100 Mbps unmetered
    IPv4 NAT with 5 TCP+UDP ports
    /64 IPv6
    €10.80/year
  • Hello @yoursunny , We still use 5 GB SSD, for example if you buy 4 VPS and combine them you will get 20 GB SSD, but if it is only one VPS we offer you 10 GB SSD, we cannot put less than 10 GB SSD because the system cannot be installed of operation
    Hello @jmaxwell that it s a good idee for future deals , I will try in the next weeks to install a server to be able to offer this type of service
    Regards,
    Calin
    Thanked by (1)jmaxwell
  • I guess I'll wait for 50 GB HDD plan instead.
    It would be my replacement of PulsedMedia seedbox.
    I just need to download 4~7 TV episodes per week.
    Thanked by (1)mikewazar
    Regards,
    Calin
    Yay waiting for that offer !!
    Why?
  • 16 HDDs x 4 TB = 64 TB HDD , for cheap Storage VPS deals , coming soon
    Regards,
    Calin
    Regards,
    Calin
    4TB drives in 2022? And are these used?
    You can get Toshiba 14TBs for 160€ ex.VAT
  • Hello @foxone , we chose the option of smaller HDDs because there will be vps with small resources, and we want to combine several HDDs in raid 10 for read/write and higher IOps, in the next weeks for example we have scheduled more another batch of 20 HDDs of the same model
    It makes a tiny bit of sense when it comes to iops, but yeah those are probably 8-10 year old HDDs that he got for ~$25 each. At least they'll be running somewhat redundantly so when they fail in a year or two some innocent sucker isn't going to lose all their data.
  • Nice.
    I just need:
    • 40 GB HDD, 3 MB/s speed
    • 25 Mbps unmetered network
    • IPv4 NAT with 2 TCP ports
    • IPv6 /112
    • public tracker allowed
    See if you can do for less than €7/year.
    Thanked by (1)Ganonk
  • @yoursunny said:
    Nice.
    I just need:
    • IPv6 /112
    LowestEndSeedbox
    Thanked by (2)yoursunny Ganonk
    Why?
  • @jmaxwell that it s very good name for future Little VPS Packet ;)
    Regards,
    Calin
    Nice.
    I just need:
    • IPv6 /112
    Something similar
    • 15GB - 20GB HDD, 10MB/s Speed
    • 100Mbps connection, 1TB monthly bandwidth is more than enough
    • Public tracker allowed
    Willing to buy one for €5/year.
    Same usage as mentioned by @yoursunny .
    Hardly 1 - 2 movies per week. VPS will be Idle for rest of time.
    So... I do not want to spend more on something which will be idle for 350+ days out of 365 days :sweat_smile:
    2 TCP Ports needed for torrent clients or similar software/clients
    Looking forward ........ :)
  • @adwsislife said:
    Nice.
    I just need:
    • IPv6 /112
    Something similar
    You could as well just use something like webtor.io for free
    Why?
  • 12 bays per server :open_mouth:
    does this mean .. 100GB disk offers come soon?
  • @Calin said:
    Hello @ehab yes
    I'm in
    just do your setup and ping us back.
    I have tried it. it's not good for low seeds torrents.
    I use telegram bot (running via vpn docker) for most of things and it works fine.
    I am looking for a small vps (has to be cheap as well because it will idle 95% of the time) to run some custom codes/client which works best for low seeded torrents.
    I used to do so with ide.goorm.com container lol (only grabbed 2 torrents till date using it. Was just testing it out. Not abused or something). But now, even that option is not feasible anymore. Need to upgrade to a paid plan :(
    and...
    that custom client will work
    • in any virtualization. So.... it does not matter if its KVM or OVZ7
    • without sudo/root access
  • I'd probably snap this up if had some ports forwarded on the IPv4 side. no ports = no fun
    lex.st - Free Shared Hosting in 4 Locations. fk ipv6.
  • Looks like it's coming!
    No pricing information yet.
    If it's same €5.40/year, 2x stack would make a usable micro seedbox.
    VPS Storage NAT 2
    0 Available
    • 1 vCPU (25 cpu alocated)
    • 512 MB Ram OpenVZ
    • 50 GB HDD SAS (raid 0)
    • 2 TB bandwidth with 1 GBps speed/month (if the limit is exceeded, it is limited to 100 mbit/s unlimited until the following month)
    • 1 IPv4 nat (with 4 ports open and 1 port for ssh)
    • 1x /64 IPv6
    • (If several VPSs of the same model are purchased, they can be combined into one)
  • edited November 2022
    so if i want open ports its will be a ipv6 ports?
    and i want to test the vps if i dont like it can u refund?
