What are some useful commands that you discovered or learnt on the terminal?
evnixevnix OG
edited November 2022 in Technical
as for me, it has been,
history | grep searchTerm
ctrl+a and ctrl+e move to the beginning or end of the line.
also, installing fzf was a massive productivity booster while doing things like ctrl+r (https://www.youtube.com/watch?v=qgG5Jhi_Els)
Update:
I 'll use the comments below to write a summary article here, these might be more useful than random commands on the web as these are likely heavily used by the community here.
search through history:
Install fzf to introduce partial/fuzzy search for history, files etc.
ctrl+LEFT|RIGHT arrow to jump words
CTRL+L clear screen
TAB for autocomplete
fdupes -Sr . FDUPES is a program for identifying duplicate files residing
within specified directories.
jdupes a faster fdupes
ncdu to work out where all the storage space went
tldr <command> an easy to read manpage
last reboot Shows reboot history
findmnt -l list all mounts
iftop realtime bandwidth monitoring
iostat -m 10 report to better balance the input/output load between physical disks
ss -tupan socket statistics.
scp localFilePath user@remote:/remote/file/path remote file transfer.
nload - shows per interface network usage live on a graph on your terminal.
Cool Stuff:
telnet 2001:7b8:666:ffff::1:42
Won't tell you what it is, but it is safe.
ani-cli animename episode
watch anime on the terminal
apt-get install sl sl
cures bad habit of mistyping ls
Combinations:
zfs send -w tank/dana@snap1 | ssh host2 zfs recv newtank/dana
ZFS send and recv.
du -k ./* | sort -nr | cut -f2 | xargs -d '\n' du -sh | less
useful for debugging diskspace
ls -a; uptime; exit
ps -C sshd o user,pid,comm,lstart as alternative to who
On a tmux session, open multiple panes, then do this:
Ctrl+B, Shift+;
Then type: setw sync on All panes will now type the same thing
type setw sync off to turn it off again.
*sh aliases: https://tldp.org/LDP/abs/html/aliases.html
external Tools:
https://doublecmd.sourceforge.io/
https://github.com/junegunn/fzf
https://github.com/nvbn/thefuck - auto corrects last command
https://github.com/kellyjonbrazil/jc - terminal output as json
http://www.figlet.org/ - text to ascii
https://books.goalkicker.com/BashBook/ - there are other good books there
Contributors: @jperkins @typicalGta @xleet @ralf @CamoYoshi @Neoon @ehab @legendary @hornet @shallow @Ympker @Encoders @iansss @Mumbly @msatt @cold @Calin @g4m3r @havoc @vyas @TheDP
Thanks for all the contributions :smile:
Thanked by (2)ehab lemoncube
