What are some useful commands that you discovered or learnt on the terminal?
2»
  • On a tmux session, open multiple panes, then do this:
    Ctrl+B, Shift+;
    Then type:
    setw sync on
    All panes will now type the same thing - Makes it easy to set up many systems at once in a ad-hoc fashion. Press the command sequence again and type setw sync off to turn it off again.
  • Whether or not you watch anime, paste this command in your terminal window.
    telnet 2001:7b8:666:ffff::1:42
    This command is fun and safe. Nothing offensive or harmful. No special account privileges needed. Trust me and try it.
    Note:
    It works with IPv6. The original IPv4 version still works but blocks many (most?) locations. It started years ago without explanation.
    Thanked by (1)evnix
  • I'm surprised how no one has mentioned nload yet.
    nload - shows per interface network usage live on a graph on your terminal. very handy at times. (eg. uploading something via curl)
    apt install nload
    nload
    Thanked by (3)webcraft CamoYoshi evnix
  • zfs send -w tank/dana@snap1 | ssh host2 zfs recv newtank/dana
    iftop
    iostat -m 10
    ss -tupan
    scp file user@remote:
    Thanked by (1)evnix
    Note:
    Oh, this is a classic. Good old towel.blinkenlights.nl
    Thanked by (2)evnix xleet
