New KS-LE
2»
  • @berkay said:
    Has anyone recently gone through their VAT exemption process? My old Kimsufi account is exempt but OVHcloud doesn’t care about that I guess.
    I think they don't do this anymore, just like netcup. There's been to many false claims. I heard they do it once in a while but require many documents and in english or french only.
    Thanked by (1)berkay
  • MicronodeMicronode Hosting Provider
    @Abdullah said:
    I got one to make fun $1 nat vps dealz. But unable to install iso working 🥲
    Easy enough to get vz7 on there. DM me if you need a hand.
    I installed vz7 using qemu-kvm trick mounting the ssd drives and it boots but no network
    I'll DM you
    @Abdullah @natvps_uk Seems like a network interface problem? You might need to adjust it manually.
    I'll DM you
    I've sent you the script we use to setup all of our nodes :)
    Thanked by (2)ehab Abdullah
  • just FYI, these don't have ECC RAM so the viability as a host node might not be great.
    @natvps_uk said:
    I'll DM you
    Is this open? Wouldn't mind seeing something like this for personal use as I grabbed one of these servers to trial some IPv6 projects at home. :-)
    Syuh - sftp, rsync & rclone accessible storage from 50GB to TBs.
    Just checked, the one I got is in fact ECC although not fully buffered.
    @ialexpw said:
    @natvps_uk said:
    I'll DM you
    It can be, its just a script for converting centos7 to openvz7.
    Thanked by (1)ialexpw
    @ialexpw said:
    @natvps_uk said:
    I'll DM you
    Ah gotcha! Not quite what I'm after then - thanks anyway. :smile:
