@localhost said:
I am running into a small challenge. I want to install AlmaLinux 9.1 via ISO. So, I go to SolusVM, mount netboot.xyz and start the installer.
Due to low RAM (1.2GB) only, the installer fails immediately.
In a regular scenario, creating a ticket to mount ISO would be the way, but, here, it may take time...
AlmaLinux 9.1 once installed, works wonders even with 1GB RAM. Question is, can I mount the ISO somehow via rescue and start the install?
It would be nice if there is an alternative to get me up and running with AlmaLinux 9.1?
My go-to for these systems is
Install locally using my own qemu instance , targeting a small (eg, 2GB disk )
Boot the VPS into rescue mode
Push the image directly unto /dev/vda (curl -o /dev/vda )
Reboot into the image
use 'growpart' and 'resize2fs' to snag the full disk size
this is now my go to for a preinstalled LUKS setup now, works so much better and I can have all of my default apps preinstalled, just change hostname, LUKS key, etc
Thanks in advance
Does Alma 8.7 sound bad for you?
Alternatively, you can use Netboot or CentOS to Alma converter, they works as intended.
Is kickstart a option for almalinux?
Never used it for alma but for debian you can install with preseed file on boxes with lower than 512MiB ram since netboot.xyz utilizes initrd and linux image rather than full iso to boot on preseeded installations.
Any pointers on how I can do this on windows? Or wsl?
This is the new target vps. Correct?
Can you share the full command?
What does this mean? Just rebooting the vps regularly?
but I do it via ssh transfer.
I want this exactly. Luks...
Can you share your steps here or DM please?
Thanks in advance
I tried 8.7. But installer failed same way via netwoot.xyz
How do you do this in Debian? Maybe I can improvise off the same.
I would be surprised if AlmaLinux doesn't support Kickstart
I suggest WSL - You can run qemu (slow mode) without tweaks; and there are guides to enable "qemu-kvm" in WSL2 if you do this often enough.
All commands are 'as root' - prepend 'sudo' or 'sudo bash' first
Make space for the disk image (I 'cheat' and do a netboot overlaid on the disk image, then wipe it during the install - you can also do the distinct disk image
(If you enable KVM in WSL2, you'd change that to '-cpu host -enable-kvm) .. '-cpu EPYC' might be closer, but doesn't matter unless you are doing Linux-From-Scratch
You connect in with your choice of 'vnc client' to port 5902 on localhost (WSL allows linux ports to be accessible to windows clients
You will find it at the 'netboot prompt' and can install normally - Qemu sets up outgoing NAT internet by default ( but you can't ssh in yet)
I'm not sure this will work under qemu on wsl to test the SSH:
THis means exitting rescue-mode on the solusvm side - at which point when the VPS reboots, it boots from the drive image
If anything was messed up in the above steps, you'll see it on the novnc window
I just checked with almalinux, and the option is there, too.
just upload your kickstart file to an easy-to-type url and submit it to this option in netboot.xyz after selecting your desired version, and hopefully, it will take care of everything else.
This is terrific. Appreciate your detailed notes here. I will definitely give it a go later. I may pick your brain again in sometime.
Well I haven't worked with Kickstart. Will need to read off that first and get a little familiar
I remember the RHEL would generate a kickstart file after a standard manual installation. You can get one on another vps or local qemu instance. Red Hat has a tool to generate it online but requires registering. Docs for Centos 8
So, i got a kickstart config created (from fresh install) and put it on a temp web server and set the URL in netboot.xyz kickstart file location.
After that, what do I need to do? I selected the Graphical Install, and it failed.
When I run the above, it is not able to find the cdrom disc... where I have validated the same available in the said location
Any help? Thanks
Which 'stage' are you getting the error?
Is it the initial Linux command-line where it says "cannot find file /tmp/ ... "?
Or is it aftre you connect with 'vnc', and you get the error that the SEABIOS cannot boot from cdrom?
If it's the seabios, there's some wierdness in some qemu installs with the emulated bios .
If the ISO is "hybrid" (eg, you can write it to a USB stick and boot), you could just do -hda path-to-iso -hdb path-to-image
If you are trying to run qemu-kvm on the target system ( /dev/vda as target ) - check whether the ISO properly transfered
"Rescue mode' basically is attaching an ISO and booting it into a ramdisk overlay - so you are in the same position as netboot where you are splitting limited memory between the AlmaLinux ISO and the operating system
Any help? Thanks
Here, when the qemu is running and trying to boot
I think i found the issue, the ISO was not completely downloaded, as the target system under rescue has just 1GB of disk available... I missed the abrupt download stop of the ISO.
Guess, I am back to square 1.
Not necessarily.
Try partitioning the disk, so that you have 1 big partition (which will get deleted while you install), and a smaller ~4GB partition at the end where you'll download the ISO to.
So you'll have VDA1 which will be 20GB or so (guessing from flash sale)
and VDA is 4GB whihc should be enough for the ISO
use 'curl -o /dev/vda2 https://ALMAISOURL'
and just change your command-line to point the cdrom to /dev/vda2
(I think qemu will let you get away with vda as the hda and vd2 as the cdrom at the same time ... if not, this gets a little bit more complicated)
Not necessarily.
I liked this approach. I created 2 partitions on /dev/vda1 = 25Gb, /dev/vda2 = 10GB
I mounted /dev/vda2 on /mnt/iso and was able to start the qemu and check the same via vnc...
Now, I see the AlmaLinux 9.1 install screen. I select the first option to install. Next, there is nothing but a blank window... its been like that for a long time. Is there a way to add some debug options for qemu?
command I run: /tmp/qemu-system-x86_64 -net nic -net user,hostfwd=tcp::2222-:22 -localtime -enable-kvm -cpu core2duo,+nx -smp 1 -usbdevice tablet -k en-us -cdrom /mnt/iso/AlmaLinux-9.1-x86_64-minimal.iso -boot d -hda /dev/vda1 -vnc :1
Or its going crazy because /mnt/iso = /dev/vda2 and -hda /dev/vda1 is pointing to the same disk...
@localhost said: Or its going crazy because /mnt/iso = /dev/vda2 and -hda /dev/vda1 is pointing to the same disk...
since you are doing it on the same system as you are installing on
I would suggest installing like wireguard or something, to mount a nfs drive to mount the iso. or maybe you can try using rclone mount to mount the http of the alma iso, I will give this a try shortly and let you know.
looks like it is not booting past that, I would suggest using qemu locally, install it to a raw image, then ssh the raw image to the server and resize it.
So, please if you don't mind, walking me through this once?
I have access a few idling vps where fresh AlmaLinux 9.1 is installed (via iso).... 1gb ram and 10gb disk.
Is there any way I could dump these on the virmach rescue?
Thanks in advance
Ps sorry I thought it was an easy task, but I am getting info overload on so many things and I am feeling a little lost. So your guidance and patience will be highly appreciated.
Thanks in advance
Install CentOS and convert to Alma
Thanks, thats an option I have tried before and would like to put it back on the cards as the last resort.
https://microlxc.net/
Is
kickstart
a option for almalinux?Never used it for alma but for debian you can install with preseed file on boxes with lower than 512MiB ram since netboot.xyz utilizes initrd and linux image rather than full iso to boot on preseeded installations.
Any pointers? Thnx
That sets up the disk image, and you can tweak the 'count' if you need it larger
this forwards '2222' (abitrary) to the guest's port 22 so you can ssh in
Setting up Almalinux with Luks is left as an exercise - I do it on Debian (with the initramfs cryptunlock).
Once you are done with this, save the image somewhere.
Yes.
I put the image up on a web server with an obscure name . Yes, it's mildly insecure (although with LUKS, it's encrypted... )
In rescue mode on the target vps:
(You may need to add '-k' depending on whether letsencrypt certs are recognized by the rescue mode install )
The ssh version is probably easier to do this once:
in WSL:
dd if=disk.img bs=1M | ssh root@RESCUEIP dd of=/dev/vda status=progress
Thank you
Docs for Centos 8
What am I missing? Thanks
Ok, some new updates.
I remembered my post from a long time ago to install Windows on Kimsufi, and I do recollect using Windows Server iso for a fresh install via qemu...
I am currently in Rescue
AlmaLinux ISO is available at /tmp/AlmaLinux-9.1-x86_64-minimal.iso
/tmp/qemu-system-x86_64 -net nic -net user,hostfwd=tcp::2222-:22 -localtime -enable-kvm -cpu core2duo,+nx -smp 1 -usbdevice tablet -k en-us -cdrom /tmp/AlmaLinux-9.1-x86_64-minimal.iso -boot d -hda /dev/vda -vnc :1
Any help? Thanks
Not necessarily.
command I run:
Thanks
Thanks so much, ill wait for your finding
using rescue image
enjoy
seems it is not going past that for me, sshfs mount now, will post again
I got this same screen and didn't move past!
Thanks for the effort and will wait for your next update 😊
Thanks in advance
Thanks again.
dd if=/dev/sda | gzip | ssh root@target 'gzip -d | dd of=/dev/sda'
if is my source, of is new target?
Is this something which would work?
if you just want to clone a vps from one to another,
boot both systems into rescue
on the one already installed
dd if=/dev/vda bs=4M | ssh root@SECOND dd of=/dev/vda status=progress
then reboot the destination, login via ssh, I would also suggest resetting the ssh fingerprints
