I'm almost tempted to try it out on my work machine (Ryzen 7 5800X, 64GB RAM, 3080 12GB and 4x2TB Samsung 980 PRO, the newest 2 are striped in a RAID0), but I have a very strict rule about not installing anything not work related.
I also followed my usual yabs standard practice of creating a new user just for that, but noticed that under WSL2, even if you su to a new user, you still have the windows permissions of the user that ran wsl, so it seems a bit dangerous still.
Was playing with WSL2 a bit - apparently this version runs a full VM, but it has a proprietary kernel and seemingly no modules loaded by default. But apparently, it can run wireguard if you build the module yourself, which is interesting. The main network interface seems to be overlapped onto the same interface as windows, so for instance you can access the "other side" using localhost. I might try that out another time. But in any case, having a "real linux drive" stored as a .vhdx is a definite improvement over the old version of WSL which I gave up on after a few hours, after I discovered that I couldn't even reliably run git on a directory from the Windows side and Windows couldn't access the Linux side properly either - if you can any changes to the Linux directory on the Windows side, it used to just corrupt the files. This new version of WSL2 exports the Linux stuff under \\wsl$\Linux\Debian which is now.
Special offer from Central.so, a quite young yet vivid brand I think, with 1 vCore, 1GiB RAM, located in Dallas. Not bad so far, and will keep an eye on the stability.
# Yet-Another-Bench-Script #
# v2022-12-29 #
Sun Jan 8 03:46:26 EST 2023
locale: Cannot set LC_CTYPE to default locale: No such file or directory
Uptime : 5 days, 16 hours, 44 minutes
Processor : Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz
CPU cores : 1 @ 3299.998 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 987.3 MiB
Swap : 256.0 MiB
Disk : 24.3 GiB
Distro : Debian GNU/Linux 10 (buster)
Kernel : 4.19.0-5-amd64
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 625
Multi Core | 598
Full Test | https://browser.geekbench.com/v5/cpu/19769644
YABS completed in 3 min 16 sec
Build in a friends basement in London , nothing public-facing because it's residential internet but it's constantly processing data and uploading the results to s3 storage. Also use it to remote into when deploying large projects because my home internet is trash. Might end up just switching to a hetzner dedi when the kWh price here jumps 5x in April... at the moment it's only costing ~£15/mo.
I didn't even know this was a thing, so I just tried it out on my crappy old desktop:
wsl, so it seems a bit dangerous still.Was playing with WSL2 a bit - apparently this version runs a full VM, but it has a proprietary kernel and seemingly no modules loaded by default. But apparently, it can run wireguard if you build the module yourself, which is interesting. The main network interface seems to be overlapped onto the same interface as windows, so for instance you can access the "other side" using localhost. I might try that out another time. But in any case, having a "real linux drive" stored as a .vhdx is a definite improvement over the old version of WSL which I gave up on after a few hours, after I discovered that I couldn't even reliably run git on a directory from the Windows side and Windows couldn't access the Linux side properly either - if you can any changes to the Linux directory on the Windows side, it used to just corrupt the files. This new version of WSL2 exports the Linux stuff under
\\wsl$\Linux\Debianwhich is now.My command log:
As administrator in powershell:
As normal user:
ReckNerd's sale back in 2022. KVM with 3 vcores and 3GiB RAM. Bought it 324 days ago, and it's been up ever since.
Virmach Flash Sale
KVM – 1 GIGABIT
4340MB DDR4 RAM
3 vCORE (RYZEN 3.4GHz+)
25GB SSD (NVMe)
2560GB MONTHLY DATA
SEATTLE, WA LOCATION
1 DEDICATED IPv4
SpartanHost, 3 vcores, 2.5GiB RAM, Seattle.
price?
$18.68/yr.
GreenCloud, San Jose, 0.5TB (BF Special, 2022)
GreenCloud, Hong Kong, 2222
looking for a yabs from this offer: https://virmach.com/special-offers/ -> Ryzen Special 1024
LowHosting.org RKVMPROTECTED16 with little more discount than normally
Hosthatch BF2022 New York storage, 104.5 dollars every three years
Virmach Frankfurt Flash Special, 36 dollars / year
@chimichurri
Virmach Frankfurt Flash Special, 36 dollars / year - LINK? flash sale is over?
https://virmach.com/flash-sale/ (but yeah, it's over
lucky you. nice machine in frankfurt am main. ryzen in ffm 👍
Wrong thread
v2022-12-29
Fri Jan 13 12:30:04 PST 2023
Uptime : 0 days, 0 hours, 5 minutes
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 32 @ 4500.000 MHz
AES-NI : ✔ Enabled
RAM : 125.0 GiB
Swap : 976.0 MiB
Disk : 3.6 TiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.15.83-1-pve
Test | Value
Single Core | 2206
Multi Core | 22061
Full Test | https://browser.geekbench.com/v5/cpu/19869874
YABS completed in 5 min 36 sec`
hostiko.com.ua
PL-2:
PL-PERF-2:
Young Ukrainian hosting provider (VPS, dedicated servers)
@hostiko beast! waiting for 200.000 code
Contabo SSD Storage Singapore - Lifting the I/O limit
Virmach, 7$/y
