Need Help Fixing OS Raid 1
Hello,
The server OS RAID 1 is failed one disk.. now It has been replace new disk.
I need someone to rebuild the raid. via rescue mode
Hello,
If you're not comfortable doing it, you should hire a tech.
@skorupion was looking for work?
If I had time I would rebuild it for him. Just a little bit in my plate for now. @skorupion should be able to handle it. If he isn't able or something comes up feel free to PM and we will see if we can sort it
Steps to replace a broken disk in software RAID array.
Mark the disk as failed:
mdadm --manage /dev/md0 --fail /dev/sdb1
Verify:
cat /proc/mdstat
Example output:
Personalities : [linear] [multipath] [raid0] [raid1] [raid5] [raid4] [raid6] [raid10]
md0 : active raid1 sda1[0] sdb1 [2] (F)
976773168 blocks [2/1] [U_]
md1 : active raid1 sda2[0] sdb2[1]
976773168 blocks [2/2] [UU]
Remove disk from array:
mdadm --manage /dev/md0 --remove /dev/sdb1
P.S. You need to do the step 2 for each array, respectively replacing the partitions.
Replace disk on machine.
Copy partition table from the healthy disk to the replaced one.
sfdisk -d /dev/sda | sfdisk /dev/sdb
Add the replaced disk back to the array:
mdadm --manage /dev/md0 --add /dev/sdb1
P.S. You need to do the step 5 for each array, respectively replacing the partitions.
Verify with:
/sbin/mdadm --detail /dev/md0
or again:
cat /proc/mdstat
First step should be taking a full backup of all data while it's still accessible. If the remaining disk dies during rebuild you'll be f*cked. Any sysadmin taking on such jobs should clarify on the risks before and whose liability that is. Just saying. π
@skorupion did this get sorted or what? I want to drop it off my radar and move on.
Yeah fixed itself, and was resynchronizing.
Contact me at: +1 (509) 606-3569 or [email protected]
Ok π off to do some writing.
