52$every month/Dedicated Server/192 GB Ram/8c-16t/1x 960 GB SSD/69 TB BW/EU/1$ extra IP/Ignore DMCA
Hello LES , recently I got my hands on a lot of RAM and several servers so I managed to create this super delicious deal
Only 6 in stock , and coming soon added other 16
Dedicated server
192 GB Ram DDr3
2x l5630 8c/16t 2.13 GHz
1x 900 GB SSD
Raid 0/1 available and for more 4+ HDD it s possible to raid 10
69 TB bandwidth upload / 69 TB bandwidth download
1x Dedicated IPv4 (Additional IPv4 it s 1$ per IP)
Replacement of defective hardware
No minimum contract period and no setup fee
Romania Locations
Windows/Linux or Custom ISO
850 MBps port speed shared
Only 6 in stock! Purchase fast
On this server allow next things:
TOR Exit/Tor Relay
Public Torrent
Adult Websites
Ignore DMCA
Free speaks websites
For only 52$/month recurring price CLICK HERE FOR ORDER
69% uptime?
vps9hostname is available. affbrrThere's a little bit of me that's tempted
I'd have no idea what to do with it though
Calin make it $25 and it will all go
--- off course
Idle it and watch it play ping pong.
It makes more sense than anything I can think of doing with it..
About all you could do from what I have seen so far
Hello , i m change from 2x 900 GB HDD SAS to 1x 960 GB SSD , SSD receive new with 0 hours usage
Regards,
Calin
11$ per hdd,what hdd it is
Hello @taizi right now i m have HUS724020ALS640 , that model receive
how much hdd can i add to the server? and only 2TB/hdd?
Hello for this configuration unfortunately maximum 2 TB per HDD it s possibto addded
Server support 4x 2 TB or it s possible 6x 2 TB but receive 2x x5650 CPU no 2x L5630 CPU
Regards,
Calin
so with x5650 i can set like
1 x 960GB SSD
4x2 TB HDD at price 4 x 11 usd
correct?
Yes that it s very corectly
Regards,
Calin
cool, open ticket for this order
#PCM-874952
thanks
Done , i m answer you
Regards,
Calin
Because lot of people ask
Yabs:
Yet-Another-Bench-Script
v2022-12-29
Tue 21 Feb 2023 06:31:19 AM UTC
Uptime : 0 days, 0 hours, 48 minutes
Processor : Intel(R) Xeon(R) CPU L5630 @ 2.13GHz
CPU cores : 16 @ 1649.648 MHz
AES-NI : ✔ Enabled
RAM : 188.9 GiB
Swap : 0.0 KiB
Disk : 878.6 GiB
Distro : Ubuntu 20.04.5 LTS
Kernel : 5.4.0-125-generic
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 415
Multi Core | 3438
Full Test | https://browser.geekbench.com/v5/cpu/20701513
any looking glass ?
http://iHostfART.com
vps9hostname is available. affbrrhad to do a double-take on the link, impressive
In general direction or upwards ?
Why?
Just finished ordering,
and wait for server information!
The upload speed doesn't look good to me. The Diks performance is not that good either.
I came to LES after a while and found Calin here. He is gem.
Hello @mgcAna Thanks
Hello @qeba it s speed.ihostart.com but have lot of firewalls and performance no good but try
Hello @rainvnc thanks! For you trust
Hello @SeederKun well depend , network it s shared and it s SSD with 0 hours usage , model of SSD it s Kingston a400 , SU650 or SU630 , depend what I m find on stock
Regards,
Calin
Before that I was using a server in Germany provided by Advinserver. But then I had a problem with the server, it took the tech support team to do it.....waited almost 4 days in vain. After seeing this article I decided to give up this server, even though it's only been nearly 10 days since I bought it.
I got the server this morning and next to it was the enthusiastic support from Calin. Very pleased with Calin's professional attitude towards work.
Completed relocation of all websites to new homes. The speed from Romania to my country is very fast, especially at this time the network operator has announced that the problem of fiber optic cable going to the international network has a problem with 5/5 lines.
Regarding the specifications I will update later. Now that I mention it, I love the numbers from the IP address that Calin gives me. If possible, I will buy another IP running in parallel.
Hello , other 6 servers added on stock
PS: delivery should take around 7-10 days, billing starts from the date you receive the server I'm waiting for SSDs to be delivered to me that's why it takes so long
Regards,
Calin
Doesn't look good at all. a Dedicated server with a shared 850 Mbps uplink? I can see consistent DL speed at 830-820 which is fine but the UL speed is really slow 300-380 Mbps? 69TB counted in/out or for each direction is a dedicated 69TB?
Hello @SeederKun for each direction is a dedicated 69TB
Regards,
Calin
You should explicitly stating that the Uplink port is shared and not guaranteed.
