IP Whitelisting w/ Dynamic IP
Hey,
I have reason to access something via a whitelist system not controlled by me. Problem is, I seemingly now have a dynamic IP half the time. I would rather not bother them with new IP's every few days. How would you resolve this so you could access via one IP?
Proxy, VPN, specifics, generics?
Cheers
You'll have to resort to either a proxy or a VPN I suppose.
I was thinking of buying a private proxy, I have no idea who is a reputable and safe supplier tho.
May even be more convenient to buy a VPS with Windows. Probably too expensive though as I am not expensing this to the third party.
Don't you have a low end VPS like everybody?
I would add a wireguard VPN with specific route for the destination to go within the VPS connection. Just leave that VPN always on, almost no resource wasted when not using it.
or check how theirs whitelist (racist, it's allow-list now, duh) works - maybe you can provide DDNS name and it is resolved on connection - so your only job (your router mostly?) would be updated that hostname at DDNS provider
// However no idea if you want to trust some random DDNS provider and maybe run yourself via one of your domains that you control and that have nice API to update DNS or something (cloudflare?)
Cheap box with a VPN solves the problem.
Hell you have boxes with VPNs already probably so just use one of those.
Don't make things to complicated.
You'd be better off running your own WG on a VPS.
VPN is fine, but if what you're trying to access is just a fixed web server then you can even do a port-forward with iptables and let the endpoints handle their own security.
I also use a tiny vps box with ovpn/wg for a whitelist login site of mine.
Random VPS with wireguard should do
Contact me at: +1 (509) 606-3569 or [email protected]
That leads me in to asking.. any provider recommendations? π
As for NAT VPS for VPN, I have been happy with @natvps_uk
Current promo is a FR vps for under 2GBP/year.
Regarding the fact that you just need the IP and no super high speed, that should be more than sufficient.
If you want a dedicated IP for yourself rather than shared (NAT), get a budget KVM line vps from @NDTN for 15β¬/year 10Gbps
I have a dynamic IP too, here's how I worked around it/solutions that I found:
Been using this kind of setup for 6 months and going strong.
Great! I remember starting out when GreenCloud were becoming somewhat established on the same forums years ago (not green). Itβs cool to see theyβre still here.
Will check if locations would cause conflict and probably go for that.
