@vitobotta said:
Added Planka for project management. Looks awesome!
Do you like Planka more than KanBoard ?
and of course MariaDB, Postgres, Nginx Proxy Manager, Caddy etc.
Which operating systems do you manage with mesh central? I’m using RustDesk at the moment. Last time I checked mesh central didn’t support multiple displays on mac
Nothing fancy actually. 3 vnc Linux (Debian and Fedora) servers and several ssh servers.
I’m curious, why exim over postfix nowadays? When I looked at exim years ago, config felt overly complicated vs postfix so I’ve been with postfix for at least 10 years now. Maybe it’s changed?
Ok. The problem for me is that it doesn't support multiple displays with macos
Planning to set up SaaS for personal use, self hosted as a backup for personal
The above recommendations help create a shortlist.
e.g.
Simplenote for personal, Joplin for backup (for now)
JotURL, with Yourls
Koofr, with Nextcloud as alternate
Squats are the new Push-ups
Kudos @vitobotta for starting this really good thread.
404 Error: Signature Not Found
Yep, it looks A LOT better
A couple of screenshots:
https://share.botta.me/-vWxb4Sn56J/Screenshot 2023-02-18 at [email protected]
https://share.botta.me/-yiEfPEKdmV/Screenshot 2023-02-18 at [email protected]
Added Roundcube to my list. It's a nicer webmail than Hetzner's
Try RainLoop
No docker image?
https://hub.docker.com/r/hardware/rainloop/
Seems like the main docker image isn't updated anymore but found this one.
https://hub.docker.com/r/wernerfred/docker-rainloop
https://github.com/wernerfred/docker-rainloop
ytdl.pro
Isn't snappymail the better option?
What is the advantage over Roundcube?
It looks like rainloop is discontinued. See this github issue: https://github.com/RainLoop/rainloop-webmail/issues/2185
Added YoPass (https://github.com/jhaals/yopass) to my list. It's a handy tool to share secrets securely
I'll stick with Roundcube then. I don't use the webmail often anyway
Thank you for update I am remiss in the rainloop recommendation. Time to update my hosting offers.
Try PrivateBin.
https://microlxc.net/
all of them
Tried EasyPanel out on a VPS earlier for a way to test a GUI...pretty happy with it, seems more flexible than swizzin.
That's cheating
While we are on the topic:
90 odd episodes, so about 45 40 odd hours of talk on self hosting apps.
nice sir vyas !!!
Dentistry is my passion
Here is my list;
Just a few
How do you use code server? I mean do you store the code locally anyway? and how do you run apps while developing?
