Convoy v3 • Open Source VPS Panel Using Proxmox • Open Beta • Free 512MB VPS (IPv6 Only)
245
  • Great!
    My Order Number is: 2110517763
    Looking forward to try this.
    Thank you.
  • Please keep this feature in new panel, it's helpful.
  • A bit late but my order number is 4822527774, thanks!
  • Order number 8815047336
    Thank you
  • @selalumenang said:
    what can 512 GB ram do?
    what 256 CAN'T
  • I would like to try this.
    Order Number: 1283629154
    Thanks.
    Why?
  • Your Order Number is: 9348602521
  • @vyas said: The Panel screenshots show 10 GB disk if you see carefully.
    I had the image load turned off, or perhaps i am blind and need to see it written in text, oh well, should i try it or not?
  • Your Order Number is: 2908032305
    Reading requirements is very hard...
  • AdvinAdvin Hosting Provider
    That's a feature built into the billing panel rather than the VPS panel
    Thanked by (1)warmingforg
    10GB of storage is included :)
  • Perhaps @Not_Oles can try this with metalvps
  • order number: 3785011661
    thx :)
  • Your Order Number is: 9824950323
  • Order Number is: 5445158347
    Sign up at Dynadot [aff], spend $9.99 within 48 hours, and get $5.00 DynaDollars for domain registrations!
  • edited February 2023
    Your Order Number is: 1499616233
    Interested to try out my first ipv6 only server & this gorgeous panel
  • Order Number: 1506634695
  • @Advin said: You must have at least 25 non-spammy posts/comments on LowEndSpirit.
    @Advin , I don't think the following applicants quality:
    @omegaxd @TrK @reyokh @Aitilos @warmingforg
    Those who didn't read requirements are more likely to abuse resources.
  • Can i have mine?
    Order number: 6959211240
  • TrKTrK
    Oh the mighty fuck lord, did you any where see me begging or my application? either you are same as me(blind) or just a stupidly awestruck zombot.
  • One of my favourite flashlight brands Convoy now as control panel? :P
    The kinky one?
    @TrK said:
    The kinky one?
    Yeah :)
    Thank you for sorting it out for me =)
    I'll get to the orders maybe later today or tomorrow
  • Your Order Number is: 9944000547
    68 comments, 52 thanked.
    You must have at least been a member of LowEndSpirit for 2 weeks.
    Join august 2022
    Got activated now! :)
    Convoy 512MB KVM VPS Open Beta
    Main IP:
    Root pass: [redacted]
    IP address allocation:
    ServerName: [redacted]
    WHM Access
    http://xxxxx:2086
    Username: root
    Password: [redacted]
    Custom DNS Server Addresses
    The custom DNS addresses you should set for your domain to use are:
    Primary DNS: ns1
    Secondary DNS: ns2
    You will have to login to your registrar and find the area where you can specify both of your custom name server addresses.
    After adding these custom nameservers to your domain registrar control panel, it will take 24 to 48 hours for your domain to delegate authority to your DNS server. Once this has taken effect, your DNS server has control over the DNS records for the domains which use your custom name server addresses.
    SSH Access Information
    Main IP Address: xxxxxxxx
    Server Name: [redacted]
    Root Password: xxxxxxxx
    The [redacted] was me, but not the xxxxxxxx. Nor the empty spots. Oops.
  • Thank you @Advin @ewang for the opportunity.
    Yet-Another-Bench-Script
    v2022-12-29
    Wed Feb 22 02:59:58 UTC 2023
    100 41169 100 41169 0 0 148k 0 --:--:-- --:--:-- --:--:-- 148k
    Uptime : 0 days, 0 hours, 19 minutes
    Processor : Common KVM processor
    CPU cores : 1 @ 3499.998 MHz
    AES-NI : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM : 473.4 MiB
    Swap : 0.0 KiB
    Disk : 1.9 GiB
    Distro : Debian GNU/Linux 11 (bullseye)
    Kernel : 5.10.0-17-amd64
    Less than 2GB of space available. Skipping disk test...
    Clouvider | London, UK (10G) | busy | busy | 20.3 ms
    Scaleway | Paris, FR (10G) | busy | busy | 15.5 ms
    NovoServe | North Holland, NL (40G) | busy | busy | 11.8 ms
    Uztelecom | Tashkent, UZ (10G) | busy | busy | 101 ms
    Clouvider | NYC, NY, US (10G) | busy | busy | 99.0 ms
    Clouvider | Dallas, TX, US (10G) | busy | busy | 125 ms
    Clouvider | Los Angeles, CA, US (10G) | busy | busy | 150 ms
    mkdir: cannot create directory './2023-02-22T02_59_58+00_00/geekbench_5': No space left on device
    Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    YABS completed in 1 min 34 sec
    v2022-12-29
    AES-NI : ❌ Disabled
    RAM : 473.4 MiB
    Swap : 0.0 KiB
    Disk : 1.9 GiB
    Hm, something went wrong with the calculations for the disk space in the module. I'll fix it.
    @Advin
    The disk in hardware section of panel show as 10G, but in vps, it's 2G? :)
    Uptime     : 0 days, 0 hours, 5 minutes
    AES-NI     : ❌ Disabled
    RAM        : 473.4 MiB
    Swap       : 0.0 KiB
    Disk       : 1.9 GiB
    Kernel     : 5.10.0-21-amd64
    Clouvider       | London, UK (10G)          | 931 Mbits/sec   | 922 Mbits/sec   | 19.9 ms
    Scaleway        | Paris, FR (10G)           | 933 Mbits/sec   | busy            | 15.7 ms
    NovoServe       | North Holland, NL (40G)   | busy            | 923 Mbits/sec   | 11.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 873 Mbits/sec   | 468 Mbits/sec   | 95.9 ms
    Clouvider       | NYC, NY, US (10G)         | 879 Mbits/sec   | 608 Mbits/sec   | 90.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 847 Mbits/sec   | 323 Mbits/sec   | 125 ms
    Clouvider       | Los Angeles, CA, US (10G) | 818 Mbits/sec   | 310 Mbits/sec   | 147 ms
    @hotsnow said:
    @Advin
    AES-NI     : ❌ Disabled
    RAM        : 473.4 MiB
    Swap       : 0.0 KiB
    Disk       : 1.9 GiB
    Should be fixed, stop/start the VPS. Sorry about that.
