Convoy 512MB KVM VPS Open Beta
Main IP:
Root pass: [redacted]
IP address allocation:
ServerName: [redacted]
WHM Access
http://xxxxx:2086
Username: root
Password: [redacted]
Custom DNS Server Addresses
The custom DNS addresses you should set for your domain to use are:
Primary DNS: ns1
Secondary DNS: ns2
You will have to login to your registrar and find the area where you can specify both of your custom name server addresses.
After adding these custom nameservers to your domain registrar control panel, it will take 24 to 48 hours for your domain to delegate authority to your DNS server. Once this has taken effect, your DNS server has control over the DNS records for the domains which use your custom name server addresses.
SSH Access Information
Main IP Address: xxxxxxxx
Server Name: [redacted]
Root Password: xxxxxxxx
The [redacted] was me, but not the xxxxxxxx. Nor the empty spots. Oops.
Great!
My Order Number is: 2110517763
Looking forward to try this.
Thank you.
Please keep this feature in new panel, it's helpful.
A bit late but my order number is 4822527774, thanks!
Order number 8815047336
Thank you
what 256 CAN'T
I would like to try this.
Order Number: 1283629154
Thanks.
Why?
Your Order Number is: 9348602521
No hostname available. affbrr
I had the image load turned off, or perhaps i am blind and need to see it written in text, oh well, should i try it or not?
Your Order Number is: 2908032305Reading requirements is very hard...
That's a feature built into the billing panel rather than the VPS panel
10GB of storage is included
Perhaps @Not_Oles can try this with metalvps
order number: 3785011661
thx
Your Order Number is: 9824950323
Order Number is: 5445158347
Sign up at Dynadot [aff], spend $9.99 within 48 hours, and get $5.00 DynaDollars for domain registrations!
Your Order Number is: 1499616233
Interested to try out my first ipv6 only server & this gorgeous panel
Order Number: 1506634695
@Advin , I don't think the following applicants quality:
@omegaxd @TrK @reyokh @Aitilos @warmingforg
Those who didn't read requirements are more likely to abuse resources.
Can i have mine?
Order number: 6959211240
Oh the mighty fuck lord, did you any where see me begging or my application? either you are same as me(blind) or just a stupidly awestruck zombot.
One of my favourite flashlight brands Convoy now as control panel? :P
The kinky one?
Yeah
Thank you for sorting it out for me
I'll get to the orders maybe later today or tomorrow
68 comments, 52 thanked.
Join august 2022
Got activated now!
Thank you @Advin @ewang for the opportunity.
Yet-Another-Bench-Script
v2022-12-29
Wed Feb 22 02:59:58 UTC 2023
100 41169 100 41169 0 0 148k 0 --:--:-- --:--:-- --:--:-- 148k
Uptime : 0 days, 0 hours, 19 minutes
Processor : Common KVM processor
CPU cores : 1 @ 3499.998 MHz
AES-NI : ❌ Disabled
VM-x/AMD-V : ❌ Disabled
RAM : 473.4 MiB
Swap : 0.0 KiB
Disk : 1.9 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-17-amd64
Less than 2GB of space available. Skipping disk test...
Clouvider | London, UK (10G) | busy | busy | 20.3 ms
Scaleway | Paris, FR (10G) | busy | busy | 15.5 ms
NovoServe | North Holland, NL (40G) | busy | busy | 11.8 ms
Uztelecom | Tashkent, UZ (10G) | busy | busy | 101 ms
Clouvider | NYC, NY, US (10G) | busy | busy | 99.0 ms
Clouvider | Dallas, TX, US (10G) | busy | busy | 125 ms
Clouvider | Los Angeles, CA, US (10G) | busy | busy | 150 ms
mkdir: cannot create directory './2023-02-22T02_59_58+00_00/geekbench_5': No space left on device
Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
YABS completed in 1 min 34 sec
Hm, something went wrong with the calculations for the disk space in the module. I'll fix it.
@Advin
The disk in hardware section of panel show as 10G, but in vps, it's 2G?
Should be fixed, stop/start the VPS. Sorry about that.
