In Reinstall Server section, Firefox recognizes the Template box as a username input, and shows a password manager box.
If I press ESC to close the password manager, the dropdown menu disappears too.
I see autocomplete="off" is already in place, so I don't know what's causing the problem.
Yeah, it's been helpful
Most of these issues have pretty much just been with the WHMCS module (rather than being Convoy related), I'll probably revise the WHMCS module in a few days and open source it soon. I'll also probably make a module for Advin Servers that integrates with our current platform and move some of our beta VPS over to Convoy.
@Advin said:
Most of these issues have pretty much just been with the WHMCS module (rather than being Convoy related), I'll probably revise it in a few days and open source it soon. I'll also probably make a module for Advin Servers that integrates with our current platform and move some of our beta VPS over to Convoy.
Thank you for open source, wish for Proxmox VE + WHMCS + Convoy solutions.
Accessing GitHub is not easy, maybe it needs an ipv4.
After reinstalling the system, I need to log in to vnc to restart, otherwise I cannot connect to the network.
@spiritlhl said:
Not quite sure if the "Used Bandwidth" is working properly, I always see 0 Bytes in the Convoy panel.
This is an issue with data types. Convoy converts bytes to mebibytes and this process losses a lot of precision if the number is less than a mebibyte. Though, I will assess the impact of this precision and issue a patch if necessary.
Founder, Lead Developer, Lead Designer, Marketing Lead, Sales Lead, Janitorial Staff, Plumber, Support Lead, Legal Team, I.T., Accountant, Electrician, System Administrator for Performave and ConvoyPanel
Tried using the VM through the panel. Here is my observation:
1. noVNC flashes every second on my computer, very annoying
2. xterm.js response is very slow, like, I typed something into it, and it only shows what I have typed after a noticeable delay.
3. Looks like they are on the output side of a virtual serial port, probably contributing to the issues above.
4. Nano is garbled.
5. Can't reach the router at fe80::1%eth0
Seems buggy
Can you PM me your customer email? Seems like an issue with the WHMCS integration
Your Order Number is: 3236753756
really thx!
Sorry but I can't find IPv6 address anywhere.
Not in the "Client Area", or the "New Dedicated Server Information" email.
This is interesting.
Doesn't look like the panel likes setting IPv6 nameservers:
you can find it in Convoy panel
ok now, thanks
I see
autocomplete="off"is already in place, so I don't know what's causing the problem.We are known to be "dangerous". affbrr
very nice and easy-to-use panel! and the VPS moves very well!!!! gg @Advin
Thank you, but I don't know where Convoy panel is. Is this?
Or here:
yes, the bottom of your image, the link in the green part
Thank you, there it is. Can't believe I was so stupid.
Same here.
GB5 Single Core
817Good job advin!
YABS
Convoy has a beautiful and clean UI, I want to try. Builtin
xTerm.jsis more comfortable thannoVNCDo you has the same problem like me ( ##Comment_130773)?
IPv6 is in the control panel
looks like the beta is working as people are reporting issues
brilliant idea @Advin
Hi @Advin,
It's better to rename
Account PasswordtoPasswordorSystem (OS) Password,Account Passwordis ambiguous with WHMCS account password.Yep.
This is what I see, not sure which IP to connect to.
Edit: ipv6 is pinging and working now.
mine keeps freezing, and needed to be rebooted! twice today... @Advin
i think its has something to do with the nameservers, NOT 100% sure
its not !
log intro the panel, and you can find your ip there
4. Nano is garbled.
blog | exploring visually |
I also get this. I can be reproduced by the following:
