Utility to download fonts, js etc
Some time ago I read a post either here or on OGF, where someone gave a tip about a utility that parses a website and downloads all webfonts and js files referenced and saves them locally.
I have googled and searched everywhere but I just cant find that utility again, does anyone know what I'm talking about?
wget --mirror?
β¨π Low end deals Telegram tracker: https://t.me/lowendweb
https://www.httrack.com/ ?
I might have expressed myself a bit unclear.
I'm talking about webdesign here. A lot of templates and themes use webfonts or libraries that are referenced with their full URI. This utility would parse such a template/theme/website and download the content and rewrite the code to point to the local copy instead.
you're going to need a web scraper, just learn them on your own with python+beautifulsoup to parse the web page. upon css/font type, do a GET request.
if you that lazy look at github with 'web scraper' tag
https://explainshell.com/explain?cmd=wget+-k
Just to clarify, I'm talking about when designing websites here, not scraping websites. It's a utility that you can point to a css file on your harddrive that is part of a website project and it will parse the file and download the dependencies.
This is not a webscraper.
https://gulpjs.com/
Chat GPT says:
Here's an example of how you can use Gulp to parse a CSS file and download its dependencies:
Install Gulp by running the following command in your terminal:
npm install --global gulp-cliCreate a new project directory and navigate to it:
mkdir my-projectcd my-projectCreate a new package.json file for your project:
npm initInstall Gulp and its plugins:
npm install gulp gulp-postcss gulp-sourcemaps autoprefixer cssnano --save-devCreate a new gulpfile.js file in your project directory:
touch gulpfile.jsOpen gulpfile.js in your text editor and add the following code:
This code defines a Gulp task called styles that reads your CSS file, parses it using PostCSS, and applies the Autoprefixer and CSSnano plugins to it. The resulting CSS is then saved to a destination folder with sourcemaps.
Run the styles task by running the following command in your terminal:
gulp stylesThis will execute the styles task and generate a new CSS file in the specified destination folder, along with any dependencies it requires.
That's it! You can now use Gulp to parse and download dependencies for your CSS files.
GDPress does this for WordPress, kinda.
OMGF for gfonts on wp sites.
This is the kind of thing I was talking about. It's not the one I had in mind, but it is similar.
