There's a PR in the repo that would add an additional info section to the YABS output with network details of the host machine (retrieved from https://ip-api.com/). Sample output:
# Yet-Another-Bench-Script #
# v2023-02-03 #
Sun Feb 19 21:53:54 EST 2023
Uptime : 46 days, 8 hours, 2 minutes
Processor : Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz
CPU cores : 4 @ 2690.478 MHz
AES-NI : ✔ Enabled
RAM : 1.0 GiB
Swap : 0.0 KiB
Disk : 16.5 GiB
Distro : Debian GNU/Linux 9 (stretch)
Kernel : 3.16.0-1160.53.1.vz7.185.3
VM Type : OPENVZ
Basic Network Information:
Protocol : IPv4
ISP : DA International Group Ltd.
ASN : AS203380 DA International Group Ltd.
Host : AlphaVPS LLC
Country : United States
Question is, should this info be shown by default or should it be invoked via an option flag (-n or something). Not sure how people feel about their network info being shown in the results and if it should be default or opt-in only (via the flag). Any thoughts on this would be appreciated.
@Mason said: Question is, should this info be shown by default or should it be invoked via an option flag
bench.monster has it as default, although I never use that. If you invoke it via flag then you would need people to read about the flags. I expect about half the people will never know the flag is there. Just saying.
Region: Global https://bench.monster v.1.5.16 2023-01-25
Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -Global
OS : AlmaLinux 8.7 (64 Bit)
Virt/Kernel : KVM / 4.18.0-425.13.1.el8_7.x86_64
CPU Model : AMD Ryzen 9 5950X 16-Core Processor
CPU Cores : 1 @ 3393.622 MHz x86_64 512 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled
Load Average : 0.07, 0.02, 0.00
Total Space : 9.8G (4.6G ~50% used)
Total RAM : 964 MB (419 MB + 376 MB Buff in use)
Total SWAP : 511 MB (336 MB in use)
Uptime : 0 days 1:43
ASN & ISP : AS23470, Server24 Network by INCUBATEC GmbH - Srl Premium Hosting Service Provider
Organization : Webhosting24 Los Angeles
Region : Florida
Last yabs on @alwyzon EcoServer 2022 before turning it off and retiring it. It was great for the whole year and finished its mission without single issue.
Fri Feb 24 22:17:21 CET 2023
Uptime : 364 days, 2 hours, 40 minutes
Processor : Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz
CPU cores : 1 @ 2599.996 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 900.0 MiB
Disk : 20.5 GiB
Distro : Slackware 15.0 x86_64
Kernel : 5.15.19
Read | 59.53 MB/s (14.8k) | 664.22 MB/s (10.3k)
Write | 59.66 MB/s (14.9k) | 667.72 MB/s (10.4k)
Total | 119.19 MB/s (29.7k) | 1.33 GB/s (20.8k)
Read | 1.28 GB/s (2.5k) | 1.32 GB/s (1.2k)
Write | 1.35 GB/s (2.6k) | 1.41 GB/s (1.3k)
Total | 2.63 GB/s (5.1k) | 2.74 GB/s (2.6k)
Clouvider | London, UK (10G) | 895 Mbits/sec | 982 Mbits/sec | 22.0 ms
Scaleway | Paris, FR (10G) | 992 Mbits/sec | 978 Mbits/sec | 21.2 ms
NovoServe | North Holland, NL (40G) | 990 Mbits/sec | 980 Mbits/sec | 18.9 ms
Uztelecom | Tashkent, UZ (10G) | 580 Mbits/sec | 939 Mbits/sec | 75.5 ms
Clouvider | NYC, NY, US (10G) | 374 Mbits/sec | 930 Mbits/sec | 98.2 ms
Clouvider | Dallas, TX, US (10G) | 472 Mbits/sec | 914 Mbits/sec | 130 ms
Clouvider | Los Angeles, CA, US (10G) | 366 Mbits/sec | 885 Mbits/sec | 166 ms
Clouvider | London, UK (10G) | 988 Mbits/sec | 532 Mbits/sec | 22.2 ms
Scaleway | Paris, FR (10G) | 977 Mbits/sec | 962 Mbits/sec | 20.9 ms
NovoServe | North Holland, NL (40G) | 992 Mbits/sec | 973 Mbits/sec | 18.8 ms
Uztelecom | Tashkent, UZ (10G) | 578 Mbits/sec | 939 Mbits/sec | 75.2 ms
Clouvider | NYC, NY, US (10G) | 513 Mbits/sec | 922 Mbits/sec | 98.0 ms
Clouvider | Dallas, TX, US (10G) | 306 Mbits/sec | 892 Mbits/sec | 131 ms
Clouvider | Los Angeles, CA, US (10G) | 345 Mbits/sec | 868 Mbits/sec | 166 ms
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 532
Multi Core | 515
Full Test | https://browser.geekbench.com/v5/cpu/20739603
YABS completed in 10 min 11 sec
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 900.0 MiB
Disk : 20.5 GiB
Kernel : 5.15.19
Test | Value
Single Core | 532
Multi Core | 515
@Mason said:
Moving forward, Geekbench 6 is now the default GB test performed. Use flags to trigger GB4 and/or GB5.
Nice job, both the GB6 and the new network information segment!
But wouldn‘t it make more sense to show something like Protocol: ✔ IPv4 ✔IPv6? Could be tested by pinging an IPv4-only and an IPv6-only target once, if your current data source doesn't include this info. To me, that would seem more useful than the current Protocol: field.
— Michael
Good suggestion! Definitely makes sense. I believe the person who added this piece included the Protocol IPv4 or IPv6 in the network info section so you knew which address was being used for the lookup, which also makes sense.
IPv4 and v6 connectivity are already being checked elsewhere in the script, so adding that will be simple. Will try and tweak it so it's apparent which address is being used for the lookup as well as add something showing v4/v6 status.
Unesty VPS IPv6 (€9/year)
Input requested from my fellow YABSers
-nor something). Not sure how people feel about their network info being shown in the results and if it should be default or opt-in only (via the flag). Any thoughts on this would be appreciated.Head Janitor @ LES • About • Rules • Support
As the new Geekbench is out now, I thought I'd do a quick GB5 vs GB6 comparison on my M1 Macbook Air:
GB5: 1734 / 7177
https://browser.geekbench.com/v5/cpu/20719550
GB6: 2310 / 7960
https://browser.geekbench.com/v6/cpu/263801
Personally I'd rather this would be optional (alternatively, if enabled by default, let people hide their network info with a flag)
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
You turn your idle boxes off?
That one was the only in few which weren't idling
Hosthatch APAC 1TB storage
GreenCloud Budget KVM DE-2 (25$/year)
Alwyzon Storage Server 1T | 7.61(with Taxes) EUR/m | with FDE
AlphaVPS 512GB Storage | 3.5 EUR/m | with FDE
Fastpipe (combahton) SE-2 | 3.99 EUR/m
server-factory.com 4 cores (Ryzen 5950X), 16 GB RAM, 200 GB NVME storage, 32TB@1Gbps for 17 euros per month (location The Netherlands)
SprintPulse - Retrospectives for Teams That Ship
MadCityServers $7/m Chicago
Hetzner EX43
Amadex • Hosting Forums • root.hr
Let me test the GB 6 on my babies
greencloud $20/3m EPYCDE-3, DE
greencloud 10GbpsNLPromo-2 $60/year
Protocol: ✔ IPv4 ✔IPv6? Could be tested by pinging an IPv4-only and an IPv6-only target once, if your current data source doesn't include this info. To me, that would seem more useful than the currentProtocol:field.— Michael
Oh, and to stay on-topic, here is a YABS.
Greencloud 9999 Epyc Kansas, to test GB6
