The sorry state of IPv6 reverse DNS
Just noticed that reverse DNS for IPv6 addresses doesn't work over IPv6-only for any of my VPSes.
For alphaVPS and KTS24 the DNS servers responsible for the reverse zone don't have any IPv6 address and for InceptionHosting the DNS server do have IPv6 addresses, but are not reachable via IPv6.
Are others any better?
  • gbshousegbshouse OGServices Provider
    Yeah, just in case we are fully dual-stack, with /64 or higher you should be able to delegate it to us, just ask your provider is it possible
    Auth DNS and anycast provider Rage4
  • @gbshouse said: with /64 or higher you should be able to delegate it to us, just ask your provider is it possible
    Well... not sure that would actually help. Presumably, the delegation would then be done on that name server that isn't reachable via IPv6, so you still have an IPv4-only part in the whole chain.
  • I have a VPS KTS24 and reverse DNS for IPV6 work fine
    F. Battiato ---
  • edited March 2023
    I have InceptionHosting in .DE and .NL
    Just tested .NL and reverse DNS for IPV6 work fine.
    edit.
    Checked also for .DE location and there also work fine.
  • @carlin0 said: I have a VPS KTS24 and reverse DNS for IPV6 work fine
    @Mumbly said: Just tested .NL and reverse DNS for IPV6 work fine.
    Just to be extra clear - it works fine over IPv4, but not for IPv6-only hosts (and not using any dual-stack resolver)
    Thanked by (1)Mumbly
  • Aaaah... thanks for pointing out (again). My bad. I don't have IPv6-only setup.
  • Not exhaustive but of the 15ish providers I've used, here are the ones that allow IPv6 rDNS:
    AWS (hit or miss approval)
    GCP
    RamNode
    Ethernet Servers
    xTOM v.ps
    Scaleway (Dedi)
  • @gshapiro
    @cmeerw said: Just to be extra clear - it works fine over IPv4, but not for IPv6-only hosts (and not using any dual-stack resolver)
  • Ah, understood. That is not something I have tested.
    That’s because no one but IPv6 hobbyists lack IPv4 connectivity. It’s an entertaining exercise to go v6 only but that’s really all it is.
    Thanked by (1)crunchbits
  • NeoonNeoon OGSenpai
    edited March 2023
    Funny you say that, some ISP are selling IPv6 only Internet access.
    IPv4 NAT is optional and overloaded.
    Despite that shit, they charge the same price.
    Thanked by (2)yoursunny adly
  • Why not just use a DNS resolver that is also IPv4 capable, the way I see it if you decide to use a IPv6 only capable resolver then you run into there kind of issues, from the top of my mind I know a few major websites that got IPv6 but there nameservers are IPv4 only.
  • @Razza said: Why not just use a DNS resolver that is also IPv4 capable, the way I see it if you decide to use a IPv6 only capable resolver then you run into there kind of issues
    But the point is that these issues need to be resolved, otherwise, why bother with IPv6 at all?
    Thanked by (4)yoursunny Mumbly rcy026 adly
  • It's because ipv6 smells. If anyone needs me, I'll be hiding from @yoursunny 😁
    🌐 Blesta.club - Blesta Modules, Plugins, Gateways and more
    💬 Join our community today and start your journey!
  • have you resolved it?
  • JabJab Senpai
    Stop spamming useless posts if you don't understand topic.
    It will not help you getting that NanoKVM :D
    Thanked by (2)AlwaysSkint lukast__
